Posts: 257 Location: Overland Park KS
Thu 07 Jul, 2011 10:39 pm
Gladiatoria Armour
Iv been studying the Gladiatoria as of lately and have really admired the helms depicted in the manual. I have been curious about its construction: for the helms appear to either be formed around the jaw, or they appear to be using an early bevor? Its hard to tell, cuz nowhere in the manual do you see them having their visors raised :/
They look very formed to the wearer, and looked to resemble great
bascinets or armets?
Are either of these that style of helm, or something completely different?
Thanks in advance!
-Reece
Attachment: 117.41 KB
Attachment: 17.12 KB
mid 15th century armet
Attachment: 97.08 KB
Another view of the helm
Posts: 678 Location: Australia.
Fri 08 Jul, 2011 1:55 am
Hullo Reece,
I too am rather fond of this style of helmet.
In fact it would seem so are quite a few others.
Check out these two threads:
http://www.myArmoury.com/talk/viewtopic.php?t=5957
http://www.myArmoury.com/talk/viewtopic.php?t=16526
Attachment: 23.32 KB
Bicoque. Source: One of those threads.
Fri 08 Jul, 2011 4:16 am
Bycoque helm
wow! Thank you for this :) Probably should have tried to search for this before creating the thread :\
What was the exact date of this helm?
Fri 08 Jul, 2011 6:51 pm
The search function is a great thing... So long as you know how to spell what you're looking for :lol:
The only reason I was even able to find those threads is that someone told (Nathan I think) about them.
I believe it's meant to date from the early/mid 15th Century Germany, often seen in conjunction with a kastenbrust.
Posts: 519 Location: 831
Fri 08 Jul, 2011 8:43 pm
You must be really pissed to be throwing your sword pommel at the other guy :eek: :lol:
Posts: 1,525 Location: Sydney, Australia
Sat 09 Jul, 2011 4:57 am
by rights, shouldnt his sword have falllen apart by now...
Posts: 616 Location: Toronto, Canada
Sat 09 Jul, 2011 6:01 am
| Ben Sweet wrote: |
| You must be really pissed to be throwing your sword pommel at the other guy :eek: :lol: |
Probably wouldn't be in a judicial duel with that guy unless you were! :lol:
Also, one of the duellists was required to throw a weapon to begin the duel in that time and place. A purpose made duelling sword wouldn't fall apart like an Indian wall hanger so its actually a good idea in context. ;)
Sat 09 Jul, 2011 6:48 am
| Kel Rekuta wrote: |
| Ben Sweet wrote: | | You must be really pissed to be throwing your sword pommel at the other guy :eek: :lol: |
Also, one of the duellists was required to throw a weapon to begin the duel in that time and place. A purpose made duelling sword wouldn't fall apart like an Indian wall hanger so its actually a good idea in context. ;) |
well i guess then the tang ISNT affixed crucially to the pommel. like most normal swords are, for example my practical norman has a mean ass tea cozy pommel. which if i threw at you would hurt, except since thats what the tangs peened over exactly 1 second laer my sword would fall apart wih the blade dropping onto my foot.
Sat 09 Jul, 2011 8:04 am
AFAIK, there are some original swords (both singlehanders and bastards) with rivet hole/s in the tangs, which are somewhat wider than average. This'd allow for a dismountable pommel without weakening the hilt, and IF the tang is not only wider, but somewhat thicker than average, the resulting pommel-less sword would be still more or less balanced. Also, I never really understood the mostly modern idea of using the pommel to hold the hilt together...
The other neat thing about Gladiatoria is that it shows quite a few of those vertically striped breastplates. (first image, left side. Sharp lines and rivets hint at a multi-plate construction - compare that with the guy on the right, who has the same shape and arcs on the breastplate, but the arcs are drawn with softer lines hinting at fluting) I always loved those...
Sat 09 Jul, 2011 11:49 am
Hey Reece, if I could ask, where did you find those pictures? I've had a (pretty brief) look online for scans of the Gladiatoria, but all I could find were low-quality, black-and-white scans. Is there a collection of better images out there?
Sun 10 Jul, 2011 5:59 am
| Adam Bodorics wrote: |
The other neat thing about Gladiatoria is that it shows quite a few of those vertically striped breastplates. (first image, left side. Sharp lines and rivets hint at a multi-plate construction - compare that with the guy on the right, who has the same shape and arcs on the breastplate, but the arcs are drawn with softer lines hinting at fluting) I always loved those... |
well its quite simple really. as a way of hlping keep everything as one piece the tang, for example of many western swords including my own hanwei practical norman sword passes through a whle in the pommel and is peened OVER The pommel. so if you remove the pommel, then there is no tension being delivered by the peening. and thus everything has now room to fall off. unless tangs are helso party held in place by friction against the walls of the grip like japanese blades
Posts: 793 Location: Stockholm, Sweden
Thu 14 Jul, 2011 7:04 am
Don't forget glue.
If someone glues the gavel on with a strong adhesive (i.e. casein glue) and uses a threaded pommel it's no problem removing it to use as a projectile, except that it changes the balance of the blade. In fact it can add some serious blade presence for heavier cuts, though sacrificing finesse and return speed.
Posts: 704 Location: Oxford, CT
Thu 14 Jul, 2011 10:09 am
Hello Johan,
In this case 99% of the actions with the sword are half-swording - there's only one (as I recall) deflective blow shown with the edge in this manuscript. Everything else is using the sword as a short spear, so losing the pommel wouldn't be that detrimental - except that you couldn't use a pommel strike.
Yours,
Christian
Posts: 146 Location: Japan
Fri 15 Jul, 2011 1:24 am
Hi :)
| Quote: |
| Hey Reece, if I could ask, where did you find those pictures? I've had a (pretty brief) look online for scans of the Gladiatoria, but all I could find were low-quality, black-and-white scans. Is there a collection of better images out there? |
You get many edition of Gladiatoria from this site. (This site has lots medival fighting manuscripts!)
open this site and Click [show]
http://wiktenauer.com/wiki/Gladiatoria
Gladiatoria (KK5013)
http://wiktenauer.com/wiki/Gladiatoria_(KK5013)
Gladiatoria (MS Germ.Quart.16)
http://wiktenauer.com/wiki/Gladiatoria_(MS_Germ.Quart.16)
Gladiatoria (Cod.Guelf.78.2 Aug.2°)
http://wiktenauer.com/wiki/Gladiatoria_(Cod.G...g.2%C2%B0)
Gladiatoria (CL23842)
http://wiktenauer.com/wiki/Gladiatoria_(CL23842)
ummm..... I watched these Gladiatoria for the first time!
Posts: 78 Location: Australia
Fri 15 Jul, 2011 3:41 am
| William P wrote: |
| unless tangs are helso party held in place by friction against the walls of the grip like japanese blades |
Japanese blades are pinned to the the tsuka and thats what holds it all together, usually 2 bamboo pins
Posts: 487 Location: Northern California, US
Fri 15 Jul, 2011 11:56 am
I followed one of Ushio Kawana's links and I found this pic.
http://wiktenauer.com/wiki/File:Cod.Guelf.78...._color.jpg
What other evidence do we have for a horse armor that was that spiky?
Posts: 229 Location: Tyrol, Austria
Fri 15 Jul, 2011 1:32 pm
phuuu.
thats difficult, i do not want to discredit the old masters, but i also think some things are pure fantasy.
the same with leonardo da vinci. he surely was a universal genius, despite half of his technical inventiones would never work.
or talhoffers "new" siege technikes, never would this work, and probably nobody ever tried these crazy folding drawbridges on weels with spikes............
Fri 15 Jul, 2011 4:28 pm
Well in the same image I linked there is a tortouise type thing that looks exactly like the one in talhoffers 1456 and they are by different artists.
Posts: 739 Location: San Bernardino, CA
Sat 16 Jul, 2011 6:42 am
| Michael Curl wrote: |
| Well in the same image I linked there is a tortouise type thing that looks exactly like the one in talhoffers 1456 and they are by different artists. |
That's because they are both copied from an earlier work, Konrad Kyeser's Bellifortis, not because anyone actually ever built one.
Sat 16 Jul, 2011 9:08 pm
Sounds perfectly, reasonable, but why couldn't they have built one, doesn't look much more complicated than any other bellfry type device.
You
cannot post new topics in this forum
You
cannot reply to topics in this forum
You
cannot edit your posts in this forum
You
cannot delete your posts in this forum
You
cannot vote in polls in this forum
You
cannot attach files in this forum
You
can download files in this forum
