I named this the Sword of Hope based on the inscriptions I had John put on the blade. I thought it was interesting having a message of hope placed on such a brutal instrument of war...
The stats are:
Total length: 42 3/4 inches
Blade length: 34 inches
Blade width at base: 2 5/8 inches
Blade width at tip: 3/4 inches
Handle length: 7 inches
Weight: 3lb 5oz
POB: 3 1/8 inches from guard
Blade material: Jerry Rados Damascus steel
Furniture material: Antiqued bronze
Handle material: Burl hardwood (have to ask John...)
Pommel design: Carved with cross design, sort of like the sword of St. Catherine
Cross guard inscriptions: DEUS VULT (God wills it) with Maltese Cross
Blade inscriptions: AGNUS DEI DONA NOBIS PACEM (Lamb of God grant us peace) with Maltese Crosses and misc. squiggles...
My directions to Mr. Lundemo were pretty vague...I want a nice Crusader's broadsword with damascus blade, bronze fitings, burl wood handle and the following inscriptions... What he came up with is truly beautiful. It's not a small sword by any means and has some heft at nearly 3lbs 5oz but with the POB at just over 3-inches from the guard, it's deceptively light and fast. It feels simply perfect. I can't thanks John enough for making the custom dream come true.
The fit and finish of this sword are simply impecible. The lines of the blade are clean and straight. The fullers are perfectly executed with absolutely no visible grind marks. The furniture is perfectly tight and the wood work of the handle is absolutely beautiful. Truly a masterpiece in my opinion...of course it's mine, so what would you expect me to say? :)
I also had John do up a scabbard with belt and rigging for which I gave him absolutely no direction as to style, etc. I really don't think John's scabbards get nearly enough credit. It's every bit as artistic and impressive as the sword itself and when they're married up, it's the perfect set. The look of the bronze fittings and wood handle matched to the rich colors of the scabbard are stunning. If you get a chance to work with John and order a custom from him...do it! Really, John...thank you for this. It's truly beautiful and exceeds my expectations in every way.
