Forum Index > Historical Arms Talk > Sinewed wood crossbows? Reply to topic
Andrew V
PostPosted: Thu 08 Jun, 2023 4:47 pm    Post subject: Sinewed wood crossbows?         Reply with quote
Of the 9 extant wood crossbow laths I am aware of, 2 are backed, one of which (Royal Armouries Sweden) is definitely sinewed, the other (Alhambra) may be sinewed, or might only be backed with sinew but translations of the Spanish are not perfect . Sinewing offers significant advantages for crossbows but I am not aware of references in medieval texts to sinewed wooden crossbows. It could be that translators only picked up on crossbows and didn’t expound further, or they were sufficiently commonplace as to not be described separately from other wooden crossbows Does anyone know of any texts/sources mentioning adding sinew to wooden laths, or alternatively any papers or articles on the subject?
If your afraid to ask, you'll never learn
F. Rodel
PostPosted: Fri 09 Jun, 2023 5:14 am    Post subject:         Reply with quote
In some Italian sources of the fourteenth century, there are references of "baliste de nervo", i.e. crossbows of sinew. Probably these crossbows were, so to speak, something in between wooden and horn crossbows.
Andrew V
PostPosted: Fri 09 Jun, 2023 10:29 am    Post subject:         Reply with quote
That’s really useful.! I don’t suppose you could give any references to this?
Ryan S.
PostPosted: Fri 09 Jun, 2023 11:13 am    Post subject:         Reply with quote
A while back I read about Andreas Bichler repairing a yew prod with sinews after it was damaged during tillering. Unfortunately, it was only as part of a preview online, and I am not able to read the relevant section now. I don´t know if he explains the historical background to repairing bows with sinews, but it works.
https://www.google.de/books/edition/Jahrblatt_der_Interessengemeinschaft_His/EJQvEAAAQBAJ?hl=de&gbpv=0
Andrew V
PostPosted: Fri 09 Jun, 2023 11:46 am    Post subject:         Reply with quote
In that instance, the string caught in the nock and split a section of the lath which was glued back in and bound with a sinew wrap. He wrapped the other end as well just to be safe. Sinew is amazing stuff, I’ve seen it described as natural fibreglass by one modern bowyer.
Andrew V
PostPosted: Thu 27 Feb, 2025 2:30 pm    Post subject:         Reply with quote
Been a while but recently I found a translation of some of the regulations concerning the use of sinew on round wood crossbow laths written. by the guild of crossbow makers in the late 13th century. The translation is by S.Manning and on the website “ageofdatini”. The existence of rules controlling the quality of sinew application possibly written before 1270 is a bit of a game changer
Sean Manning
PostPosted: Thu 27 Feb, 2025 7:30 pm    Post subject:         Reply with quote
Glad people are finding it helpful! I am not likely to make any crossbows anytime soon.
There are ballistae de nervo in Hewitt's Antient Armour and Weapons in Europe from 1860 and a 2003 book by Elisabeth Crouzet-Pavan. I think the volume The Cutting Edge by Barry Molloy talks about ancient sinewed wood bows.
weekly writing
~ material culture
Andrew V
PostPosted: Fri 28 Feb, 2025 1:40 am    Post subject:         Reply with quote
So useful! How’s that for poor grammar? Wooden crossbows and wood/sinew crossbows are my current obsession. The insights into correct procedure have changed my own methods- I notice in the 13th item you leave the term”scanellum”, I’m not entirely sure but it might translate to slot or groove?? I guess it maybe a unit of measure for the area around the slot, which I imagine is perhaps the centre of the bow around the bolt groove ?
Andrew V
PostPosted: Fri 28 Feb, 2025 5:01 am    Post subject:         Reply with quote
Thank you for the reading list, a quick search found Hewitt available at project Guetenberg . I spent a very pleasant morning reading his work. Really enjoyed myself Happy
Sean Manning
PostPosted: Wed 05 Mar, 2025 8:27 pm    Post subject:         Reply with quote
Andrew, my Italian and especially my Medieval Venetian are not very good, so I would need to make time and explore some dictionaries to try and clarify that word. Many scholars of European crossbows are from German-speaking Europe or the Low Countries but maybe a Genoese will chip in?
weekly writing
~ material culture
Anthony Clipsom
PostPosted: Thu 06 Mar, 2025 6:29 am    Post subject:         Reply with quote
Intrigued, I had a search around and found
ant. venez. (sec. XIII) scanellum 'pezzo di legno scanellato per unire l'arco al teniere della balestra' (GLI 509)
My very limited Italian and online translation suggests
Scanellum - Piece of fluted wood for fixing the bow to the tiller of a crossbow.
I found this in SCAMONE «CUSCINETTO» DI DELIZIE
Remo Bracchi
Aevum, Anno 72, Fasc. 3 (Settembre-Dicembre 1998), pp. 801-816 (16 pages)
https://www.jstor.org/stable/20860890 (this is free to view on jstor)
Its p. 808. Beware - this is dense text in Italian with limited concession to readability.
Hope this is useful
Anthony Clipsom
Andrew V
PostPosted: Tue 11 Mar, 2025 12:01 pm    Post subject:         Reply with quote
I wrenched my back a little bit and was confined to the sofa for the weekend. I deep dived through a forum I discovered by accident called The Armour Archive, Sean, I think the site contains your translations back in 2020, with notes- absolutely fascinating- and in the wider discussion I think you ( http://forums.armourarchive.org/phpBB2/viewto...e#p2850232 ) agree there with Anthony about a mounting plate. Thanks both, this is a completely new concept to me, every day is a school day!
The concept of a mounting plate would solve a major issue with round wood laths, namely that the weight of the stirrup can make the lath rotate in it’s binding, lifting the string out of the nut causing a misfire- it has happened several times on my lockbow- and a misfire can shatter a wood lath…..
Anthony, thank you for the further reading, I look forward to exploring some more!
Sean Manning
PostPosted: Wed 12 Mar, 2025 2:32 pm    Post subject:         Reply with quote
You're welcome! I think some of the German books have summaries of this rule but I have never seen a full translation let alone an English translation. So I put some of my lockdown time to the task.
When you talk about a mounting plate, do you mean at the front end of the tiller to receive the bowstave?
weekly writing
~ material culture
Andrew V
PostPosted: Fri 14 Mar, 2025 6:21 am    Post subject:         Reply with quote
So the belly of the bow (the side facing the shooter) becomes rounded as you carve it to a shape where it bends well. This round shape fits into a round socket on the tiller (stock). It is impossible to prevent the round bow rotating in this round socket and you constantly have to twist the bow back into line. Normally you leave the centre of the bow flat to prevent this but that can impact on how the bow bends. I think the Venetian makers glued a thin plate onto the bow which they could carve squared off to go into a square receiver in the stock. Because the bow bends it will break the joint between itself and the plate so the joint is reinforced by sinew which contracts as it dries and firmly holds everything together.
