Posts: 717 Location: Winchester, VA
Sun 13 Mar, 2016 2:34 am
Some people are asking what I mean about this set up being left handed.
The dagger itself isn't left handed, however the scabbard is set to be worn on the left hand side. Since it is a single sided blade, if you draw it out with your right hand then the sharp side will be pointing up instead of down.
In addition the by knife has a (brass/bronze?) knob that when gripped should touch your palm. Since it is a single sided blade, If you use it right handed, then the knob will not be facing the "right" direct. It is a minor thing but important to some people.
Hope this helps and doesn't make it more confusing.
