Forum Index > Off-topic Talk > Third tatami test cut Reply to topic
Lancelot Chan
PostPosted: Sat 30 Jan, 2016 7:30 am    Post subject: Third tatami test cut         Reply with quote
https://youtu.be/txdzumZm6CI
The third tatami practice recently, for practicing tip cuts, finishing cuts and close cuts.
Lancelot Chan
PostPosted: Sat 30 Jan, 2016 8:46 am    Post subject:         Reply with quote
https://youtu.be/S8A8Qd0b12k
https://youtu.be/SpdEsm35PXY
https://youtu.be/bGHZDh2HZF0
PostPosted: Sat 30 Jan, 2016 9:55 am    Post subject: Re: Third tatami test cut         Reply with quote
Very very impressive and scary, but at least you are still human with a couple of failed cutting attempts, but 99% of your cuts seem effortless.
SCARY SCARY SCARY ..... congratulations. Surprised Eek! Big Grin Cool
Lancelot Chan
PostPosted: Sat 30 Jan, 2016 10:00 am    Post subject: Re: Third tatami test cut         Reply with quote
Hheheh thanks!
The single handed upward cut failed for the first time because it was not aimed to hit that high by design but I was trying to save money by hitting the top part first. :P
So in the end I just let it hit where it was meant to thus it worked.
For the next couple failed cuts, I was giving evaluation for the swords that the students used, to see if they did good enough or not by trying the same technique with the sword as they did. That showed at least they did good already with the given tools.
