Lancelot Chan
Lancelot Chan
Posted: Sat 30 Jan, 2016 9:55 am Post subject: Re: Third tatami test cut |
| Lancelot Chan wrote: | https://youtu.be/txdzumZm6CI
The third tatami practice recently, for practicing tip cuts, finishing cuts and close cuts. |
Very very impressive and scary, but at least you are still human with a couple of failed cutting attempts, but 99% of your cuts seem effortless.
SCARY SCARY SCARY ..... congratulations.
Lancelot Chan
Posted: Sat 30 Jan, 2016 10:00 am Post subject: Re: Third tatami test cut |
Hheheh thanks!
The single handed upward cut failed for the first time because it was not aimed to hit that high by design but I was trying to save money by hitting the top part first. :P
So in the end I just let it hit where it was meant to thus it worked.
For the next couple failed cuts, I was giving evaluation for the swords that the students used, to see if they did good enough or not by trying the same technique with the sword as they did. That showed at least they did good already with the given tools.
| Jean Thibodeau wrote: | | Lancelot Chan wrote: | https://youtu.be/txdzumZm6CI
SCARY SCARY SCARY ..... congratulations.  |
