Forum Index > Historical Arms Talk > Authentic armour finishes Reply to topic
Tim Jones
PostPosted: Sat 21 Feb, 2015 12:36 pm    Post subject: Authentic armour finishes         Reply with quote
Hello all,
I'm an occasional armour maker, and have found it very difficult to get nice finishes to my pieces (it's probably due to the fact that I'm terrible at planishing) and was wondering if anyone had some examples of historical finishes. To be more specific, the low to mid-end armour in a late 14th century to mid 15th century context.
Thanks
Jonathan Fletcher
PostPosted: Sat 21 Feb, 2015 1:11 pm    Post subject:         Reply with quote
Searching under armour polish throws up a few threads about this, though mostly later armours and not low-medium quality so maybe not too useful:
http://www.myArmoury.com/talk/viewtopic.php?t...mor+polish
http://www.myArmoury.com/talk/viewtopic.php?t=20995
http://www.myArmoury.com/talk/viewtopic.php?t...=polishing
The Churburg armour is quite bright, again not low-medium end at all.
I am sure I have seen other posts on here asking about this too. Have a search and see what comes up.
I suspect little of the lower quality armour survives (in a condition that can tell you much about the finish)
 Attachment: 138.98 KB
Tyler Jordan
PostPosted: Sat 21 Feb, 2015 6:45 pm    Post subject:         Reply with quote
Armor was expensive, but a good polish on armor could be several times the expense of the harness itself. Needless to say your bright mirror polish would be quite a conspicuous declaration of wealth. So low-mid end armor, though not raw, would probably have a pretty simple working polish. There's a lot of evidence that many armor pieces were originally painted as well.
Tim Jones
PostPosted: Sun 22 Feb, 2015 3:28 am    Post subject:         Reply with quote
It is as I feared. The matter is not helped by museum staff in the Victorian period cleaning original surfaces off because it didn't "look medieval enough".
I really like the finishes put on by Albert Collins and Radoslaw Ciszewski. They're done by hand and give a far more likely portrayal of the armour of an ordinary soldier. I've been trying to recreate the finish, albeit with an angle grinder and polishing mop....
I believe the main cause of my problems comes down to my planishing skill. It's far easier to polish something up if you've got a smooth surface to deal with. I think I'm going to have to go and buy some more tools...
Tim Jones
PostPosted: Sun 22 Feb, 2015 6:54 am    Post subject:         Reply with quote
I've done some experimenting. The one on the right was finished about two weeks before the one on the left, and at a time when I was trying to get a mirror finish. The one on the left is a more "munitions grade" piece.
 Attachment: 246.91 KB
Jeffrey Faulk
PostPosted: Sun 22 Feb, 2015 10:09 am    Post subject:         Reply with quote
It was also common, especially in earlier periods-- not sure about later on-- to cover armour with fabric or leather. You could do this in various ways such as bunching or slashing the material to form various patterns. Velvet (or a modern synthetic alternative might be more durable) was a common choice, I believe.
Adam Bodorics
PostPosted: Sun 22 Feb, 2015 12:03 pm    Post subject:         Reply with quote
Try working from the inside on an anvil, makes planishing redundant. You'll end up with a surface very similar to the originals in Landeszeughaus Graz (which is later than what you asked, but I think the method was the same at your specified date), which is neat in itself but is also pretty easy to polish if you're into that.
Tim Jones
PostPosted: Sun 22 Feb, 2015 12:55 pm    Post subject:         Reply with quote
That's the method I've already tried. I've found that it leaves a fairly nasty surface that has to be ground or planished, but that might just be me.
James Arlen Gillaspie
PostPosted: Sun 22 Feb, 2015 7:07 pm    Post subject:         Reply with quote
Water powered grinding and finishing wheels were often used on production armour, especially during the time of the popularity of the 'alwhite' style. There are a few pieces that show working -life finishes, but they are, as you might expect, very rare. I came across a helmet in my own work that shows some areas more or less protected by the decorative liner washer rivets. I'll post one or two when I figure out what folder they're in. It's second half of the 16th c., but it looks about the same as a late 15th c. Italian celata I saw in Munich years ago that had an intact finish under its brow reinforce.
jamesarlen.com
Mark Griffin
PostPosted: Mon 23 Feb, 2015 9:40 am    Post subject:         Reply with quote
But also legislated against to avoid shoddy work being hidden under expensive coverings. The basic rule. inspect the armour before it gets covered in velvet etc.
Tom, where in UK are you? I have a range of armour here made by different makers as well as original pieces. happy to help if I can.
But the bottom line is, what does the client want?
Tim Jones
PostPosted: Mon 23 Feb, 2015 10:13 am    Post subject:         Reply with quote
I'm in Birmingham. I've managed to re-create Radoslaw Ciszewski's hand-finished style using an angle grinder and polishing mop, but I think I could do with getting the shapes nailed first.
It's not for any particular client, more my wish to get it "right".[/quote]
Mark Griffin
PostPosted: Mon 23 Feb, 2015 10:59 am    Post subject:         Reply with quote
Not too far from me and i pop into Brum from time to time. You are also very close to Matt Finchen who is pretty hot on surfaces. He's hand filing a Mantua B1 for me sometime soon.
Basically there is no 'right' finish, although plenty wrong. Saw one completely Hammerited once... You can have everything from very rough from the forge to mirror bright and perfectly smooth. You'd need that before you went on to most other decorative stages. No point trying to blue something that's not absolutely perfect to start off with.
PostPosted: Mon 23 Feb, 2015 11:03 am    Post subject:         Reply with quote
Found it! Note the fact that the mirror polish is slapped on top of a rather coarse finish. Actual size of the polished area is about 3/4 inch.
 Attachment: 96.16 KB
jamesarlen.com
Tim Jones
PostPosted: Mon 23 Feb, 2015 12:23 pm    Post subject:         Reply with quote
I've found it to be quite a useful base...
I think I'll probably have to have a browse through some websites and see what kind of thing I want to do, or god forbid, just do it and see what happens.....
That's the kind of thing Radoslaw Ciszkewski does. It looks really nice when it's almost highlighted by the polishing compound or general forge crud.
Willy M
PostPosted: Wed 25 Feb, 2015 6:04 pm    Post subject:         Reply with quote
The finish James shows is good at hiding slight imperfections and can still be quite shiny. Without that texture every imperfection even in the polishing itself is revealed.
Best and quickest way to polish I found is with a Baldor or similar buffer. The shafts are long and thick and the motor is vibration free so it does not transfer marks to your work. The 555 polish will give the highest polish you will ever need.
Use only one wheel for one size of grit polish then use soft or[img] hard felt wheels to finish.
With the buffer wheels free of guards and well out from the motor you should be able to reach any part of an object.
Works well on sword blades.
Of course this set up is not cheap, over $500 for a buffer and felt wheels run $80 or more and then add your polishing compounds.
 Attachment: 316.62 KB
 Attachment: 359.58 KB
Mart Shearer
PostPosted: Fri 19 Jun, 2015 11:10 am    Post subject:         Reply with quote
Another Italian painting with a helmet on the ground reflecting the world around it.
https://www.flickr.com/photos/andrea_carloni/18644184929/in/album-72157654587962932/
https://www.flickr.com/photos/andrea_carloni/18648544869/in/album-72157654587962932/
https://www.flickr.com/photos/andrea_carloni/18211949884/in/album-72157654587962932/
