Jarno-T. Pälikkö
Posted: Mon 29 Apr, 2013 7:21 am Post subject: Sosun Pattah for Solingen |
Hi fellows,
I’ve been busy with a last minute project so I am a bit late posting this, but better late than never… I am going to participate in the Solingen show this year and here’s a new piece I got ready for the occasion. This is another version of the lovely Indian sosun pattah-sword design. The sword is markedly bigger than the previous sword (that is still looking for a home), but the biggest difference is the hilt that is made of cast bronze.
Here are the basic stats: oa. length 85cm, blade length 71,5 max blade width 4,2cm, blade thickness 9mm, weight 1,326kg and point of balance 12,3cm from the guard.
The T-ribbed blade is forged of 990-carbon steel and the hilt was cast by my next-door foundryman after the wax model I made. As I knew that the casting process is somewhat primitive I left out all decorative work from the wax. Also, as the weight of the hilt was likely to be excessive it was necessary to be able to work with the lines of the hilt without being hindered by cast-in decorations. The casting process went fairly well - there were only a few disturbing shuts and bubbles.
Because bronze is such heavy material it took some inspired grinding and LOTS of filing to get rid of the extra weight. The problem is that the original hilts are often so tiny that no normal-sized hand will fit in them so when the size of the grip is increased to accommodate a bigger hand the weight also grows rather radically…
The decorative work technique on the hilt was something that I had done earlier only in a much smaller scale. In my eyes it turned out ok, giving out a slightly rough outlook that just what I was trying to achieve. The “makara” on the knuckle-guard is my version of the mythical beast -clearly this one is more closely related to ducks than tigers or lions!
The blade is decorated with free-hand etchings to simulate the koftgari-decorations of the originals.
Unlike the originals in which the blade is held in place only by glue, this sword has the tang riveted to the pommel the same way I do with the European-style swords.
To complete the piece, there is an all leather scabbard for the sword, with decorated scabbard mouth and chape of the same material.
I include some pictures of the work process also - the transformation of the hilt from green wax to decorated bronze is somehow so impressive…
I hope you enjoy the pics.
JT
Attachment: 87.67 KB
Attachment: 50.93 KB
Attachment: 123.6 KB
Attachment: 52.82 KB
Attachment: 143.75 KB
Attachment: 68.89 KB
The wax model of the hilt sans knuckle-guard
Attachment: 85.35 KB
The hilt parts cast with some pores visible
Attachment: 96.17 KB
Filing (and filing) the hilt to shape
Jarno-T. Pälikkö
Posted: Mon 29 Apr, 2013 7:27 am Post subject: |
And here’s a few pictures more…
JT
Attachment: 117.26 KB
Attachment: 66.86 KB
Basically a ready and working hilt
Attachment: 94.4 KB
At the beginning, the amount of decoration was a bit intimidating…
Attachment: 108.33 KB
And even more so when moving down the hilt…
Attachment: 101.32 KB
The work almost done, the hilt needs to be patinated for full effect
Stephen Curtin
Posted: Mon 29 Apr, 2013 9:10 am Post subject: |
Stunning work JT, thanks for sharing.
Éirinn go Brách
Isaac H.
Posted: Mon 29 Apr, 2013 11:30 am Post subject: |
I'm not normally a fan of Eastern style weapons, but this is stunning. Absolutely breathtaking finished product.... I'd be proud to own this blade.
Wounds of flesh a surgeons skill may heal...
But wounded honor is only cured with steel.
We who are strong ought to bear with the failings of the weak and not to please ourselves.
Each of us should please his neighbor for his good ,to build him up.
Romans 15:1-2
Boris Bedrosov
Posted: Mon 29 Apr, 2013 11:39 am Post subject: |
Absolutely wonderful piece of art!
I don't know what more could be said.
Tokugawa Ieyasu
Find my works on Facebook:
Boris Bedrosov's Armoury
Peter Johnsson
Posted: Mon 29 Apr, 2013 12:54 pm Post subject: |
Magnificent JT!
-And I will get to see this sword this coming weekend.
Great :-)
Jeremiah Swanger
Posted: Tue 30 Apr, 2013 12:52 am Post subject: |
Wow! Beautiful workmanship!
...and that blade looks like it's perfectly-capable of taking off some heads!
Out of curiosity, would that hilt also work on a Tulwar sabre? It looks similar in some ways.
"Rhaegar fought nobly.
Rhaegar fought valiantly.
Rhaegar fought honorably.
And Rhaegar died."
Jarno-T. Pälikkö
Posted: Tue 30 Apr, 2013 1:22 am Post subject: |
Thank you very much gents!
I know that Indian-style weapons are not everybodys’ cup of tea, so it is very rewarding to see that folks here at the forum appreciate this kind of stuff as well.
Peter, it’s going to be fun at Solingen, we’ll be poking each others’ swords and sticking fingerprints on them! Can’t wait!
Jeremiah: The hilt of the sword IS a tulwar hilt - the Indians used the same hilt type on various blade types. The sleek shamshir blades were often mounted with these hilts as were on occasion bigger kukri-blades…
I’ll be lugging four swords to Solingen: Two sosun pattahs, the JTMEFECIT-inscribed X-type and a custom order wheel-pommeled single-hander that I just got ready twelve minutes ago, plus two or three knives.
And here’s a close-up on the ‘makara-duck’...
JT
Attachment: 70.72 KB
Joshua L Burrell
Posted: Thu 02 May, 2013 12:31 pm Post subject: |
I personally love the eastern styles and this is a fine interpretation.
This is a terrific level of detail you have achieved on this hilt and the blade. Is the motif on the blade engraved or etched?
very well designed and executed.
Thank you for sharing.
I would love to attend the Solingen event one year, have fun!
Jarno-T. Pälikkö
Posted: Tue 07 May, 2013 6:50 am Post subject: |
Thanks Joshua, I think Peter Johnsson also commented something about the amount of details crammed in the sword.
The decoration on the blade is an etching – that’s something I can do, I would love to know how to do real engravings…
But, the Solingen show is now past and I have to say that it was great fun – Peter and I were the only ones with swords on tables there, the nigh 100 tables were mostly covered with high quality knives of all imaginable styles and designs. The quality of the stuff there was most impressive, I must humbly admit. I had many good talks with quite knowledgeable visitors in the show – some of whom turned out to be swordmakers themselves…
So on the show weekend there were three sosun pattahs’ in the Klingenmuseum premises as I discovered one such in the displays - albeit the blade of the sword is one of the weirdest I have come across so far.
JT
Attachment: 48.92 KB
Me by the table in Solingen - maybe a bit tired in the picture...
Attachment: 77.04 KB
The Klingenmuseum sosun pattah on the right, the blade actually has holes in it...!
Keith L. Rogers
Posted: Thu 09 May, 2013 9:02 pm Post subject: |
I did not understand the size of that sword before the photo on the table with you as reference. It's a beauty and a beast.
Jarno-T. Pälikkö
Posted: Fri 10 May, 2013 4:35 am Post subject: |
Thank you Keith, this one is actually bit on the big side as sosun pattahs’ go, usually the blade length is 66 cms or thereabouts.
For size comparison: the sosun pattah is of the same length as Albions’ Vassal-falchion – only the sosun pattah has almost an inch longer blade…
-And when I Finally get some tatami-mats I am so going to do test-cutting with these swords! –Maybe even do a little video of it…!
JT
Scott Roush
Posted: Fri 10 May, 2013 5:03 am Post subject: |
wonderful humbling work! I love the casting and detail work..
http://www.bigrockforge.com
Mark Griffin
Posted: Fri 10 May, 2013 12:45 pm Post subject: |
Just realised why I'm not fond of this area of swords. i see too many cheaply made bits of tourist rubbish for only a few pounds in junk shops. This has made me look anew, what a stunning bit of work. You've done an entire area of cultural heritage justice, wonderful.
Posted: Fri 10 May, 2013 3:25 pm Post subject: |
The amount of detail and contrasting textures and colours are really fantastic as well as the sword as a whole.
Josh Maxwell
Posted: Fri 10 May, 2013 11:13 pm Post subject: Re: Sosun Pattah for Solingen |
Jarno-T. Pälikkö wrote: | Hi fellows,
JT |
I know examples of pulwar have a pin present in addition to the resin that holds the blades in the hilt. These pins would often be located in the center of the rosette decoration on the quillon block extending through to the other side and riveted in place. Just because pulwar are related to talwar, I'd be curious if other examples of Sosun Pattah also exhibited this trait.
Jarno-T. Pälikkö
Posted: Sat 11 May, 2013 4:54 am Post subject: |
Thank you very much gentlemen!
Scott: That hilt decoration work humbled ME! The crouched working position with the flexi-drill cramped my back so badly that a masseuse was needed to get my back muscles moving again!
Mark: Yes, I know what you mean, those cheapos make me go “Brrrr!” whenever I see them… There are some good quality local-made present day swords about, but they are a bit rare – and so far there have been no modern sosun pattah reproductions that I have come across.
Jean: True, with different textures and patination even a one-piece metallic hilt can be made to look interesting – compared to that picture where the hilt is file-decorated but not textured, the difference is rather striking. But, if it were possible to decorate the hilt in a traditional way – for example with koftgari method – then the end result would be completely from another planet…
Josh: You are right I have come across those rivet pins too, mostly with tulwar-bladed swords. A friend of mine has one that has the riveted pin going through the damascus steel hilt at the waist below the disk. I think I have picture somewhere where there is a pin going through an undecorated cast hilt of a sosun pattah… -let’s see if I can find it…
JT
Jarno-T. Pälikkö
Posted: Fri 17 May, 2013 7:40 am Post subject: |
Right, found the pictures I was looking for. In the first picture the pin goes through the hilt of a tulwar at the waist (or neck?) just below the disk pommel. The second picture I remembered wrong, the hilt on the right has the pin just in the center of the guard, but the blade is of a tulwar-type. The left-hand sword has a very shallowly curving blade that might be a sosun pattah or an undecorated kirach.
-Anyway, this method of using cross-pins or rivets to attach blades to hilts is rather rare in my experience and so far I have never seen it used with sosun pattahs...
When I get a chance to do some test-cutting with this sword, I‘ll be posting the results in this thread.
JT
Attachment: 54.67 KB
Attachment: 58.89 KB
