Posts: 399 Location: Slovakia
Sun 16 Dec, 2012 12:22 pm
A handful of knives
Another batch of medieval knives reproductions... They are not perfect, but it was fun making them.
They have usual construction, with riveted handles made of brass combined with bone or wood.
(Sorry for crappy pictures, I shall make some fotos during daylinght.)
Attachment: 63.27 KB
Attachment: 76.69 KB
Posts: 144 Location: WV
Sun 16 Dec, 2012 1:56 pm
Very nice! Did you forge the blades yourself?
Sun 16 Dec, 2012 10:22 pm
strictly speaking, they were not forged:) They were grinded and then quenched and tempered. But one day I will finally build my forge, and then... :)
Posts: 114 Location: Missouri
Mon 17 Dec, 2012 5:40 am
"not perfect" blades...
Radovan:
Nice work. There is something about the..."not perfect" gear. It has its own appeal. Not everyone could have a full plate armour, not everyone could have a silver hilted Samuel Bell bowie.
I like them!
Mon 17 Dec, 2012 6:20 am
thank you for encouraging words! In fact, there is a certain level that you can achieve with angle grinder, then one would need more sophisticated tools:) At the same time, "uebung macht den meister", so I just keep on tryin´ :)
Posts: 1,734 Location: Oxford, UK
Mon 17 Dec, 2012 3:51 pm
Looking good.
Wed 19 Dec, 2012 12:51 pm
Thu 20 Dec, 2012 3:28 am
thank you! i have a piece of thick leather from an old belt, somewhere in my workshop, that should work well. thanks again!
Sun 17 Mar, 2013 10:57 pm
Dear all, let me contribute with my latest creations. The first one is a large cooking knife. It still needs some
polishing on its blade, and I will probably re-shape the handle - so please take it as a work in progress:)
The second one was for my fiend´s birthday. I wanted to make it more special (and try a new technique), so it has a brass inlay work on its blade. It´s not perfect, but I´m rather happy with the result.
Attachment: 86.35 KB
Attachment: 57.06 KB
Sun 05 May, 2013 9:59 pm
Posts: 159 Location: Nøtterøy, Norway
Mon 06 May, 2013 1:29 am
Really nice details!
Posts: 551 Location: flagstaff,arizona
Mon 06 May, 2013 5:56 am
Horn finishes well with sandpaper and steel wool, I usually sand to about 600p and then polish with 000 steel wool. Very nice work by the way!
Mon 06 May, 2013 9:06 pm
thank you. i did use sandpaper, but I shall try steel wool.
Posts: 355 Location: Höör, Skane
Tue 07 May, 2013 12:02 am
Lovely, lovely knives. One can't possibly have too many knives..
Thu 06 Jun, 2013 7:04 am
...and here´s another one. this time a larger cooking knife.Shape was inspired by some 15th cent. artwork.
The blade was made from a scrap piece of rusted metal, which was probably a broken blade from grass-cutter. I found it laying in the corner of our garden. I have cleaned it chemically and mechanically, but it still retains a "rustic look" (I know that it´s often just a code-word for "not very well-kept" :))
The scales are from brass and elm, riveted by solid brass rivets. The knife still needs a sheath, but it will have to wait for a smaller brother, to make a nice cooking-set. All comments and criticism are welcome.
Attachment: 81.58 KB
Tue 12 Nov, 2013 10:51 pm
Wed 13 Nov, 2013 4:06 pm
That 'friend's birthday knife' and the knives immediately following it have really neat shapes--were they historically inspired?
Wed 13 Nov, 2013 10:42 pm
Thanks Kai, yes they were inspired by different pieces found in artwork. My main source was this database:
http://tethys.imareal.sbg.ac.at/realonline/
Some of the blades were also inspired by originals - here my main source is Herman Historica auctions.
Posts: 1,091 Location: Philadelphia
Sun 19 Jan, 2014 2:51 am
Was browsing around for your past work Radovan and I think it's really excellent. You have an eye for eating knife design for sure.
It's funny because I recall you said on another of your topic that your work was amateurish (found it: "I have to stress that it´s just very amateurish, learning by doing exercise"). Well you, lean fast! so I really don't agree as the above knives tell me otherwise. Your Bauerwehr makes the point even more. They also tell me you are comfortable with most of the techniques needed to achieve a pro level project (pinning, riveting, cutting and shaping a blade, heat treatment).
The one thing that is a bit of a let down is your finish (blade and sometimes the sides of your wooden handle are a bit rought), which is really awkward as it is the easiest part really. It looks like you are in a hurry to finish :) Granted finishing is often very boring but well worth the effort. You work mostly with an angle grinder, and it leaves grinding marks.
Short answer: you need a belt grinder. I have no room for a backstand at present, but I am finishing blades and hilt components with a small 20£ aldi hand held belt sander, that has attachments to clamp it on a workbench belt facing up. I thought little of it when I bought it when grocery shopping, but I would be unable to complete most of my projects without it. I just bought quality belts on ebay, grit 40 would deal with those grind marks with little efforts. It has variable speed. Now this piece of equipment would make any professional blade smith have a good laugh, but what the hell - it does the job. I've done scabbard cores with it, shaped mild steel guards (angle grinder+this to refine and finish).
Sandpaper also does the trick, but will take more efforts. I use sanding sponge preferably, they speed up the work.
Otherwise clamp you blade on a long wooden slats that will extend beyond your workshop. Use double side adhesive to secure your sandpaper to a piece of hard wood that you will hold with both hands pressing on your blade. Then back and forth with a little oil...boooring yes. but this will work :)
Hope the above will help. In any case I'll follow your projects with great interest.
J
You
cannot post new topics in this forum
You
cannot reply to topics in this forum
You
cannot edit your posts in this forum
You
cannot delete your posts in this forum
You
cannot vote in polls in this forum
You
cannot attach files in this forum
You
can download files in this forum
