Forum Index > Off-topic Talk > Practice Cutting Patterns Reply to topic
Doug B.
PostPosted: Sun 01 Apr, 2012 4:42 pm    Post subject: Practice Cutting Patterns         Reply with quote
Hello all,
I recently saw a poster that had 4 practice cutting patterns. You read the patterns from outside to inside and practiced them in order of 1,2,3,4. The below image IS NOT ACCURATE but this is an example of what it looked like. I cannot recall the name of this pattern, or the person who created it, but it would be a great training tool to have. Does anyone know this? Or any other way to find good practice patterns?
1.........|.........2
..2.......|.......3
....4.....|.....1
......3...|...4
......1...|...2
.....2....|.....3
...1......|.......4
4.........|.........3
Bill Grandy
Reading list: 43 books
PostPosted: Mon 02 Apr, 2012 10:06 am    Post subject:         Reply with quote
Hi Doug,
The pattern is from Joachim Meyer's fencing treatise of the 16th century.
http://www.higginssword.org/guild/study/manua...rd_28r.jpg
HistoricalHandcrafts.com
Gottfried P. Doerler
PostPosted: Mon 02 Apr, 2012 10:58 am    Post subject:         Reply with quote
i dont understand the meaning of this. WTF?!
i suppose you fix this poster an a wall, stand before it and cut in certain directions, suggested by the poster.
a) if you start left above, you can cut along 1,2,3,4 to the center. but moving right you start in the middle, sweeping upwards to 2, passing 3 and cutting down again ?
b) the before doesnt seem practical, so if (what i suppose) you always cut to the center, whats the reason behind the numbers ?
could anyone enlighten me ?
Bill Grandy
PostPosted: Mon 02 Apr, 2012 11:44 am    Post subject:         Reply with quote
The easiest thing to do is to read Joachim Meyer's treatise. That isn't meant to be a sarcastic answer: It's just the truth. Happy
But the basic idea:
Start with cuts using the long edge, and begin on the outside numbers. Cut diagonally down from the right (1), then up from the left (2), then up from the right (3), then down from the left (4). You've completed the first segment. The second segment is for the numbers that below the first segment: Cut diagonally up from the right (1), then down from the left (2), etc, etc. Then you do the same patterns with the short edge, then you can make the downward strikes long edge while the upward strikes are short edge, and then vice versa, etc. You can do them all with passing steps, or with gathering steps, or any number of footwork patterns depending on what you are drilling at the moment.
Also, you can do these where you perform full cuts (i.e. don't stop in the middle) or you can do them as half-cuts (i.e. stop in the middle). Both teach you different forms of preparations.
These are not the only cutting patterns, but they are good ones for people to start learning to move with the sword.
PostPosted: Mon 02 Apr, 2012 1:35 pm    Post subject:         Reply with quote
ah, thats it, thank you.
but honestly
imho theres nothing easy about meyers treatise, not even for a native german speaker,
i could not even fully follow the preamble ( to the illustrious and highborn prince and lord johan casimir, palatine of the rhine...) Laughing Out Loud
all full of endless long and clumsy sentences, weird collocations and expressions long gone...
Doug B.
PostPosted: Mon 02 Apr, 2012 6:56 pm    Post subject:         Reply with quote
Bill, this is exactly what I was looking for! Thank you.
Edit: Bill, I just noticed you are the Director of Historical Swords at VAF. This is where I am taking classes! David showed us this pattern on Saturday! Small world.
Patrick De Block
PostPosted: Mon 02 Apr, 2012 10:44 pm    Post subject:         Reply with quote
Gottfried,
There's a transcription to modern German made by Alex Kiermayer and available at The Arts of Mars webshop of Colin Richards. It has just been published and apart from readable it's a very beautifully produced book.
Bill Grandy
PostPosted: Tue 03 Apr, 2012 11:45 am    Post subject:         Reply with quote
Ha! You won't get much of an argument from me. Happy His long run-on sentences are a little bit of a headache for the modern reader. That said, he was certainly one of the more specific of the Liechtenauer masters, and though he crammed a lot of words into his sentences, there's quite a lot of important material in his treatise.
Actually, almost all of the fencing treatises from his time begin like that, with that kind of verbosity. These fencing masters had to appeal to their benefactors, after all, or they wouldn't get published. Happy
Bill Grandy
PostPosted: Tue 03 Apr, 2012 11:47 am    Post subject:         Reply with quote
Heh, I saw you were local, and I was wondering if maybe you came to VAF and had seen the cutting diagram there. Happy Glad you're learning!
William P
PostPosted: Tue 03 Apr, 2012 11:46 pm    Post subject:         Reply with quote
But the basic idea:
although i guess, unsurprisingly, that requires knowledge of the footwork required. for example i have no idea how your stance is supposed to change as you make a cut, and as well, howyour body, arms etc move as one makes a particular cut.
i.e do you step back during rising cuts and forward during downward cuts? generally speaking
(ive always made that particular assumption, that the stance in longsword or messer is similar to the 'forward stance' used in karate i.e left foot forward, right foot back, to strike downward requires you to step forward with your right foot while making the cut. ) then again ive never been properly taught to use ANY sword, aside from viking style sword and shield. and even that is semi imformal.
Bill Grandy
PostPosted: Wed 04 Apr, 2012 12:20 pm    Post subject:         Reply with quote
It certainly does. Happy There's only so much detail we're going to hit on in a forum post. But these cutting patterns are not meant to be learned in isolation. They are drills to practice in addition to the entire corpus of the martial system, just as a boxer cannot learn purely from a punching bag, and yet it is still a worthwhile practice.
Much like in any martial art, it depends on a lot of factors. Styles that developed during the age of plate tend to have more upright postures with the feet closer together (even when not wearing armor), whereas systems that developed more towards the 16th and 17th centuries tend to have a wider stance. But even that is a big generalization.
