Karl Knisley
Posted: Mon 01 Aug, 2011 12:13 pm Post subject: Need some Knecht suspension advice |
Hello
Does this suspension baldric thingy,work (period-ish wise) with a, Albion Knecht?
Regards to all
Attachment: 56.64 KB
Posted: Mon 01 Aug, 2011 1:32 pm Post subject: |
Nope. It'd be akin to painting a Ferrari with a rattle can. Assuming you have a scabbard (please let it be a proper wood core scabbard,) all you need is a long, narrow top-grain leather belt and historical buckle type--either homemade or bought from Historic Entreprises, etc. You can have a belt cut at any leather shop. If you're not more than about a 38" waist you can just modify an English lead from a pet store. Either way, you just add a buckle and tie the typical scabbard knot around the scabbard. If you can get a very long piece you can use the basket-weave knot seen in many images of the period (or use a piece to make the basket knot and just run the belt through the knot). This route is simpler, cheaper and far more historically appropriate..
Karl Knisley
Posted: Mon 01 Aug, 2011 1:48 pm Post subject: |
Hello
Thats the thing.I dont have a scabbard for it. I was thinking, that half scabbard thing, instead of $1000 for a scabbard.
Regards
T. Arndt
Posted: Mon 01 Aug, 2011 2:46 pm Post subject: |
I agree. People wearing sharps in those kind of exposed scabbard/fogs terrifies me. Something as simple as slipping on wet ground could lead to a horrible accident.
Where they used historically?
Dustin R. Reagan
Posted: Tue 02 Aug, 2011 8:15 am Post subject: |
T. Arndt wrote: | I agree. People wearing sharps in those kind of exposed scabbard/fogs terrifies me. Something as simple as slipping on wet ground could lead to a horrible accident.
Where they used historically? |
I recall a woodcut, i believe, of a landsknecht wearing a kreigmesser in a similar sort of rig (no scabbard, but suspended at the hip). I could be wrong...as I couldn't seem to find it in my brief search.
Dustin R. Reagan
Posted: Tue 02 Aug, 2011 8:18 am Post subject: |
Here is what I was thinking of:
Ok, now I'm not certain that the blade is bare. It could just be a very form-fitting scabard, with no chape?
Russ Ellis
Posted: Tue 02 Aug, 2011 8:24 am Post subject: |
Dustin R. Reagan wrote: | Here is what I was thinking of:
Ok, now I'm not certain that the blade is bare. It could just be a very form-fitting scabard, with no chape? |
Either way I'm liking that knot on the top and am going to use it on the next Knecht scabbard I do if the customer is willing. It will be on a scabbard though, as was noted previously carrying that thing around with a bare blade around a crowd would give me the heebie jeebies.
Karl, if you don't want to put the money in a scabbard (the horror ) then you might consider having a sheath made for it. I suspect that's actually what's in Dustin's photo.
TRITONWORKS Custom Scabbards
Posted: Tue 02 Aug, 2011 8:51 am Post subject: |
That's the typical suspension for the Katzbalger and other short-bladed weapons of the period and culture. It's a specialized knot, either of a piece with the belt or only on the scabbard itself, with the belt passing through it. The saber/messer shown here is in its scabbard. The knot covers most the integral scabbards of the by-knives but the tops of those knives can be seen below the nagel, in the gap between the top of the scabbard and the top of the knot. Tod has covered the creation of such knots in a couple of threads, most recently in his Katzbalger thread. Not as difficult as it looks
JE Sarge
Posted: Tue 02 Aug, 2011 9:50 am Post subject: |
Karl Knisley wrote: | Hello
Regards |
A quality, historically-accurate scabbard does not have to cost $1000. You can get a base model wooden core scabbard for around $200 at CSS: http://www.customswordshoppe.com/shoppe/produ...dq9ma0jhh0
Then design your suspension around the scabbard. Or, just have CSS do the suspension for a little bit more. This is IF you are considering buying a scabbard.
I will say that learning how to make them is greatly rewarding. When I am at home, I enjoy making my own scabbards. It's easier than it looks and once you know how to do it, you can save more money for swords and even increase the value of your collection by doing your own scabbards.
Here is a good tutorial for you:
http://www.yeoldegaffers.com/project_scabbard.asp
Good luck on your quest, sir...
J.E. Sarge
www.crusadermonk.com
Dustin R. Reagan
Posted: Tue 02 Aug, 2011 10:00 am Post subject: |
Nathan Robinson wrote: | It would have had a scabbard. |
Sean Flynt wrote: | The saber/messer shown here is in its scabbard. |
Ah, good to hear that this seems to be the consensus.
Karl Knisley
Posted: Tue 02 Aug, 2011 10:02 am Post subject: |
Hello
Thanks for the input, all-ya`ll :-) I`am thinking, your`re right ,about a bare blade.I`d hate to sit down, and stab somebody in the butt :-) The CSS route sounds good. I`am a welder, so wood is my kryptonite. I would like to try my hand at the belt though.
Regards
Russ Ellis
Posted: Wed 03 Aug, 2011 6:46 am Post subject: |
Sean Flynt wrote: | Tod has covered the creation of such knots in a couple of threads, most recently in his Katzbalger thread. Not as difficult as it looks  |
Thanks for pointing this out, it will make life a lot easier, it looks very simple when it's explained, not so much from looking at the picture above. Plus I checked up on Tod's katzbalger thread at the same time. <Shakes head> Simply amazing work...
