Forum Index > Historical Arms Talk > Hanwei Saxon converted - new custom hilt by Alojz Krišto Reply to topic
PostPosted: Sun 20 Feb, 2011 4:03 pm    Post subject: Hanwei Saxon converted - new custom hilt by Alojz Krišto         Reply with quote
What do you guys think about it? I think this new hilt fits the blade much better than Hanwei type L one... It's a Petersen type H hilt made by Alojz Krišto, it has the correct two piece pommel construction but with tang peened over the top for easier repeening if the need arises... Fittings are steel with brass inlay in the grooves and twisted brass wire between the upper guard and the pommel. Grip is slightly shortened, it's 9cm now and the cross guard sits a bit more down the blade than the original one so the fuller start is closer to the guard now which looks more natural... I understand the pictures are not very good but the fittings are quite shiny and reflective so it's hard to capture their true color. I posted pictures taken under to different lighting conditions, the truth is somewhere in between... Wink
PostPosted: Sun 20 Feb, 2011 4:04 pm    Post subject:         Reply with quote
Stephen Curtin
Likes: 110 pages
Reading list: 18 books
PostPosted: Sun 20 Feb, 2011 7:23 pm    Post subject:         Reply with quote
Hey Luka, very nice hilt. You said that the hilt has been shortened, (and this might be because its 3.25am here in Ireland) but to me it still looks a little on the long side. Anyway nice sword hope you enjoy it.
Éirinn go Brách
Hadrian Coffin
PostPosted: Sun 20 Feb, 2011 8:05 pm    Post subject:         Reply with quote
Hello,
It is a lot better than it was, but there are a few tweaks that could make it better. The grip must have been truly massive if 9cm is it reduced! The grip really should be under 7.5cm. The fullers generally do not terminate below the guard (taking a bit of metal off the shoulders, or sinking the blade deeper into the guard could mitigate this problem).
There are a few other problems with it... but most of those are not easily correctable.
The hilt components seem to be shaped well, a big improvement.
Cheers!
Historia magistra vitae est
PostPosted: Mon 21 Feb, 2011 6:27 am    Post subject:         Reply with quote
It still looks long because I have very small hands. I think 9cm is quite typical for a viking age sword. The original grip was 10cm, still not too big, but 9cm is much better if you don't have huge hands.
PostPosted: Mon 21 Feb, 2011 6:41 am    Post subject:         Reply with quote
Hadrian Coffin wrote:
Hello,
Cheers!
The grip was 10cm (4") and now it's 9cm (3.5"). 7.5cm (3") would I think be a bit too small. It might work for me because I have very small hands, but it would be too small for most people.
I agree about the fuller but I didn't want to shorten the blade, it's short enough already, 69.5cm (27")...
Btw, what other problems do you think about?
S. Christiansen
PostPosted: Mon 21 Feb, 2011 3:26 pm    Post subject:         Reply with quote
Not a huge fan of the blade but it certainly could be worse. Loving the hilt though. While the grip is a bit long, it's far from too long. Overall a very nice conversion. Happy
Sonni
Hadrian Coffin
PostPosted: Mon 21 Feb, 2011 11:38 pm    Post subject:         Reply with quote
Sorry typo above. I meant under 8.5cm not 7.5... although 7.5 isn't out of the question for swords of this type either. I have seen grips on these swords go up to 10cm, it is just less common. The blade really does look a bit wonky... I'd get some work done on it if I were you.
Cheers!
J.D. Crawford
PostPosted: Tue 22 Feb, 2011 1:44 pm    Post subject:         Reply with quote
Nice, Luka, I like it much better than the original sword. I like Anglo-Saxon hilts, but that particular one seemed a bit off. The inlay on your hilt furniture is terrific - something a real Viking would like. And less 'non-fuller' showing is an improvement.
Another good customization 'under your belt'. Keep it coming. Happy
PostPosted: Tue 01 Mar, 2011 12:48 pm    Post subject:         Reply with quote
Thanks J.D. Alojz really did a good job with the inlay. Happy
Johan Gemvik
PostPosted: Tue 01 Mar, 2011 2:03 pm    Post subject:         Reply with quote
Very nice! Superb craftsmanship.
I'd also love to see what he can do with this blade and a vendel/Carolingian age layered hilt.
PostPosted: Wed 02 Mar, 2011 4:22 am    Post subject:         Reply with quote
If I ever buy another Saxon, or just the blade, it will be mounted with Vendel era ring hilt fittings.
E. Storesund
PostPosted: Wed 02 Mar, 2011 6:05 am    Post subject:         Reply with quote
That's one beautiful sword right there!
