Posts: 671 Location: The Netherlands
Wed 28 Jul, 2010 1:40 am
Thanks Johan, but the neckline is already done. I did it by cutting out a shaped facing sewn to the outside. Then I pressed the seam allowance, understitched it to the facing, pressed the facing to the back and secured it with blind stitches all around. I finished the arm holes and the splits in the front and back in the same way.
It took some time to figure out how to do it, but with the German tutorial that Thomas posted and
this tutorial I managed to figure it out. Mine is a little simpler than these examples because my neckhole is round, not keyhole shaped.
It's a lot of work but almost all of it can be done on the sewing machine. The only thing I do by hand is securing the facing to the back with blind stitches. But this goes quite fast as the stitches are wide apart.
All that remains is securing the facing of the front and back split, hemming the lower edge and sewing a cross on the left of my chest. With a little luck I will be done either tonight or tomorrow night.
All-in-all it has been much more work than I estimated. I think I have easily sunk 30 hours into it when I'm finished. But, it's finished to a much higher standard than I though I would be able to when I started this. Also, it's been slow going because this is my first real sewing project (aside from a marble bag) so I had to do a lot of research on the internet on how to sew and operate my machine.
Pics to follow when it's finished!
