Forum Index > Historical Arms Talk > Cinquedeas: What's out there? Reply to topic
David Donovan
PostPosted: Fri 11 May, 2007 9:16 pm    Post subject: Cinquedeas: What's out there?         Reply with quote
I've dug around the forums and through the albums looking at various antique and reproduction cinquedeas (cinquedee?), but I don't think I've ever seen a topic specifically dedicated to them.
I actually picked up an MRL "15th Century Cinquedea" off of ebay a couple of years ago for fairly cheap (due to some problems with the fit of the hilt, as well a noticeably off-center tang!). Despite being a less than ideal introduction to the cinquedea, it nevertheless built up my interest in the type (plus, I think it's a good candidate for trying out some of those antiquing techniques - I'll post the results if I get around to it).
I've been looking around to see what else is out there in terms of reproduction cinquedeas. I've seen MRL's more recent "Classic Cinquedea" which looks like a bit of an improvement over the one I've got, but I'm thinking I might move up a step.
I'm especially looking at Lutel's offering at the moment, but I thought I'd ask about any other makers or examples of custom jobs anyone may have had done. I'm particularly curious about any makers who offer a dagger-sized cinquedea, since I've really only seen sword-length reproductions.
"Do something meaningful in this meaningless world."
Takasugi Shinsaku (1839-1867)
Randall Moffett
PostPosted: Fri 11 May, 2007 9:46 pm    Post subject:         Reply with quote
The Royal armoury has a good number of them,mst in storage.
I think they lookcooland have such a interesting balance to them. There is speculation they originlly started out as heafty short swords capable of major cutting but sounds like a possible myth.
I aksed an italian friend regarding the name and he said it does sound related to five fingers thoug (anyone familair with latin can kindof see it).
Roger Hooper
PostPosted: Sat 12 May, 2007 6:42 am    Post subject:         Reply with quote
Del Tin makes a Cinquedea - DT6151 - http://www.deltin.net/6151.htm
They also make a dagger, DT2165, that has the characteristics of that type - http://www.deltin.net/2165.htm
David Donovan
PostPosted: Sat 12 May, 2007 12:11 pm    Post subject:         Reply with quote
I thought I might add this link I found to a cinquedea waster by Raven Studios, I don't think I've seen anyone else who offers them. I also remember seeing some information a year or two ago about a cinquedea training seminar at Gallowglass academy... if they ever offer it again, I've got a friend in the area who I could go visit as an excuse to head up that way.
Craig Peters
PostPosted: Sat 12 May, 2007 12:15 pm    Post subject:         Reply with quote
David,
I suspect that a lot of the teachings for dagger work from the various historical masters would apply quite nicely to the cinquedea, keeping in mind that you can probably cut with a cinquedea quite a bit more effectively than you can with most daggers.
David Donovan
PostPosted: Sat 12 May, 2007 4:07 pm    Post subject:         Reply with quote
Thanks, I'll keep that in mind, I've been meaning to check around my area to see if there are any local organizations who do any Medieval/Renaissance martial arts, since I'm about to finish school and will finally have time to pursue something (or so I think, anyway).
One question for everyone about cinquedea tips: a lot of the examples I've seen are pretty pointy, but I've also seen a number with what's been described as an "ogive" or "spatulate" rounded tip. I actually think it's a neat shape, and while I'd imagine it would do nasty things to an unarmored target, it seems like it would run into problems against anyone wearing some sort of light armor or even heavy cloth. It just seems kind of odd for what I've usually seen described as primarily (though as Craig mentioned, not exclusively) a thrusting sword. Of course, if it was primarily a civilian weapon to be used against other civilians, I guess it might not have been an issue...
EDIT: Thanks for the links to the Del Tins, Roger, I'd seen an earlier model but hadn't seen the newer one. I also just found a Deepeeka Cinquedea, goes for $96 at www.by-the-sword.com. Might be good for a costume piece, if anyone is ever looking for the budget option. I'll keep hunting around, maybe get a solid list of what's available and post it back at the top of the thread.
Michael S. Rivet
PostPosted: Sun 13 May, 2007 5:15 am    Post subject:         Reply with quote
A myth? Certainly the Type XXI swords bear a resemblance.
PostPosted: Sun 13 May, 2007 7:02 am    Post subject:         Reply with quote
From our Spotlight Article on Types XXI and XXII:
Type XXI consists of swords seemingly influenced by the famed civilian dagger/shortsword known as the cinquedea. So named for its blade (said to be five fingers in width), the cinquedea consisted of a wide blade that was often elaborately etched and gilt. The blade could range in size from a regular dagger to a typical single-handed sword, though many examples fell in-between. Cinquedea guards were usually short and curved down towards the blade, and most examples possess U-shaped pommel caps.
Swords of Type XXI share the wide blades and short curved guards of their civilian cousins. As with the rest of Oakeshott's typology, this group is limited to examples of sword length, which disqualifies the highly popular dagger-length true cinquedea. Pommels on swords of this type can be U-shaped like a cinquedea or can be a more common style of the period, such as one of the wheel varieties. Blades usually show multiple fullers. Most examples seem to be Northern Italian in origin, though the influence of Italian fashion resulted in swords of this type showing up elsewhere in Europe, notably in England.
It should be noted that while a typical sword-length cinquedea will likely be able to be classified as a Type XXI, not every example of Type XXI can be classified as cinquedea, as will be seen in this article's Historic Examples section below. The defining features of the type are blade width, blade form, and a short, down-curved cross, clearly drawn from the cinquedea.
Oakeshott thought there was a connection.
Randall Moffett
PostPosted: Sun 13 May, 2007 10:08 am    Post subject:         Reply with quote
I mean that they did not start out as a short sword. I figure they were swords shortened intended more for a civilian environment and made smaller to be excluded in the normal sword limitations in towns and cities not that they were not heavy cleaving weapons. Most cities create weapon regulations that people cannot walk around town with swords. I assume each town had its own legal definition of what length qualified as a sword, likely very similar to each other and then this was born, the answer to the problem. A sword capable of cutting but legal inside towns. I have been told on a number of occasions that this sword was a continuation of heavy short sword like the gladius and I do not see it personally. I think legal urban codes are the case at least in italy where these were popular.
I have no doubt that Oakeshott is right that a relation exists but makes more sense to me it started large and got small as explained above.
Hisham Gaballa
Reading list: 7 books
PostPosted: Sun 13 May, 2007 10:45 am    Post subject:         Reply with quote
I scanned this picture from an old book a while back. I think the book was "Arms and Armour" by Aldo Cimarelli.
http://i4.photobucket.com/albums/y110/Nephtys...eas_AC.jpg
Craig Peters
PostPosted: Sun 13 May, 2007 4:08 pm    Post subject:         Reply with quote
If you haven't already got it, I would recommend picking up Jason Vail's book on medieval and renaissance dagger combat. It has a lot of different techniques interpreted from various manuals, and would work quite well for cinquedea, keeping in mind of course that like a gladius, the cinquedea would be used for cutting. I would think that a mixture of dagger fighting and arming sword fighting is about the best approximation we have at the moment for the cinquedea. My guess is that the techniques historically may have been more closely related to those of arming swords, but on the other hand, we know of rondel daggers with immensely long blades too, so who can say for sure.
http://www.myArmoury.com/books/item.php?ASIN=158160517X
Bruno Giordan
PostPosted: Mon 14 May, 2007 11:52 am    Post subject:         Reply with quote
Cinque dita= five fingers ( in old italian I remember having found sometimes deda for dita (fingers), so cinquededa then cinquedea for simplicity)..
I was told it was referred to the width of the blade, as well as to the fuller division (perhaps one could put his hand's fingers on the blade matching somehow the fullers.
We have fine examples at the Marzoli collection (almost impossible to replicate without hiring a bladesmith and a handle specialist for a long, long time ...).
The few replicas I have seen online appear quite crude and will not withstand comparison to the sophisticated originals.
Allen Reed
PostPosted: Mon 14 May, 2007 1:38 pm    Post subject:         Reply with quote
The seminar on use of the cinqudea was taught by Scott Wilson from Darkwood.
Drop him a note about buying his wasters or getting some training.
Allen
David Donovan
PostPosted: Mon 14 May, 2007 9:41 pm    Post subject:         Reply with quote
Thanks for the information, both Craig and Allen: I think I will try to order a copy of the book and try to contact Scott Wilson some time. Lots of good information showing up in this thread!
Here's what I've turned up so far with regards to available reproductions, in no particular order:
Lutel Cinquedea
Del Tin 6151 Cinquedea
MRL Classic Cinquedea
MRL 15th Century Cinquedea (discontinued, still available from some dealers)
Deepeeka Venetian Cinquedea
Toledo Cinquedea
Wasters:
Raven Studios Cinquedea Waster
And a few others which are decidedly cinquedea-like:
Del Tin 2165 Dagger
MRL Anelace
MRL Renaissance Short Sword
And this one isn't actually available for purchase, but I thought it was interesting and worth mentioning:
Kevin Harvey Damascus Cinquedea
Turned up a bit more than I expected, although mostly lower price range so far. I'll look a bit more, but I think I've found pretty much everything google has to offer... I guess I'll have to start looking through maker's sites one-by-one.
I also picked up some supplies for polishing/antiquing today, so I hope to get started on my "antiqued MRL cinquedea project" soon. I'm actually going to be traveling for a couple of weeks, but I'll try to get on it in early June and post some pictures of the results. Hopefully I won't botch it too badly. Confused
PostPosted: Tue 15 May, 2007 1:41 pm    Post subject:         Reply with quote
Here's a nice photo for purposes of comparing originals to reproductions (nice view of a scabbard, as well):
 Attachment: 22.14 KB
David Donovan
PostPosted: Sun 20 May, 2007 5:28 pm    Post subject:         Reply with quote
I got some of the antiquing done early, might do a little more work on it when I get back from my trip (I leave tomorrow).
The blade was done with a couple of treatments of vinegar and salt water, and one last treatment of salt water only. The finish on the blade actually takes on an almost dark gold appearance with the light at the right angle.
I tried ammonia fuming on the brass, but got kind of mixed results. The scabbard parts seemed to respond better, if somewhat irregularly, whereas the guard and pommel didn't react as much. My biggest problem has been cleaning some of the more stubborn blue residue off, due to the twists and turns of the parts. I might clean it up and give it another round or two of fuming. I still need to antique the bone grip--I saw another topic which mentioned soaking bone in tea to darken it, so I think I'll give that a try.
Morgan Butler
PostPosted: Mon 18 Jun, 2007 2:09 pm    Post subject: cinquedea         Reply with quote
I just got the MRL Anelace, I'm fairly pleased with it, it definately has the cinquediea feel to it. I like to work it with a small steel punch shield that I have. It reminds me of those 17 to 18 inch long gladiator sword/knives. I'll put some pictures of it up under "the last sword you bought" catagory.
David Donovan
PostPosted: Mon 18 Jun, 2007 2:59 pm    Post subject:         Reply with quote
I as well just found an anelace waiting on my doorstep after returning from my trip, and find it a nice little sword/giant dagger (especially for the marked down price that it's currently selling for). Does anyone know more about the "anelace"? From what I've looked up, the word is of Middle English origin, and appears in the Alliterative Morte Arthure. ("But Arthur with an anlace egerly smites...") MRL describes it as a "comtemporary of the cinquedea," but the precise relationship seems unclear. Is it an English weapon influenced by Italian fashion? Or is it a case of "convergent evolution" in the quest for a dagger-sword hybrid?
Martin Forrester
PostPosted: Tue 19 Jun, 2007 9:20 am    Post subject:         Reply with quote
Arma bohemia do a rather pretty one (at least pretty for such a thuggish weapon)
http://www.armabohemia.cz/Novestr/daggersA.htm
 Attachment: 121.56 KB
Oh, lets just pull out our swords and start whacking at each other, that'll solve everything!
Hugh Fuller
PostPosted: Tue 19 Jun, 2007 1:45 pm    Post subject:         Reply with quote
Michael "Tinker" Pearce has an absolutely gorgeous one for sale for $1,175. Expensive, I suppose, but take a look. If that sort of sword turns you on, this one will. Scroll to the second entry.
http://www.tinkerswords.com/Page%203.html
Hugh
Still trying to walk in the Light
Please see 1 John 1:5
