Forum Index > Off-topic Talk > 13th century surcoat projectDIY Project Reply to topic
Sander Marechal
Reading list: 17 books
PostPosted: Sat 24 Jul, 2010 5:22 pm    Post subject: 13th century surcoat project         Quote
Alongside fabricating shields on my new shield press, I have been learning how to operate a sewing machine so I could make my own Hospitaller surcoat. My design is very basic. It's two squares (64x123cm) sewn together to make the body, with triangular gores sewn in on the lower half. I'm pretty pleased with it so far, considering this is just my second sewing project (the first one being the traditional marble bag).
I am probably going to trim the bottom a bit to just below my knees (or simply use wide hems). I also still need to put splits in the front and back so I can ride a horse. But I have a question about the shoulders. Because the body is a basic tube, the shoulders are quite wide. You can see that on the left shoulder in the attached picture. I am contemplating making then narrower. The right shoulder in the picture had some of the fabric folded back, making it narrower (although it bunches up when folding, especially in the arm pit).
What do you think is best? The wider shoulder or the narrower shoulder? This is supposed to be 1250-ish.
Thanks in advance (and apologies for my ugly smirk in the picture :p )
 Attachment: 81.01 KB
Profile PM E-mail Website
Michael Ekelmann
PostPosted: Sat 24 Jul, 2010 7:14 pm    Post subject:         Quote
I think the narrower shoulder looks more in line with images from the Maciejowski bible, so that would put it at around 1250.
“Men prefer to fight with swords, so they can see each other's eyes!" Sean Connery as Mulay Hamid El Raisuli in The Wind and the Lion
Chuck Russell
Reading list: 46 books
PostPosted: Sat 24 Jul, 2010 10:00 pm    Post subject:         Quote
i am currently making the same. you want the shoulders to be free and clear of movement. take your finger and place it on the top of your shoulder. now move your arm around you should find where the top of the ball is. i would not make the shoulder any wider than that point. also remember to allow under arm movement. you see this in the Mac Bible where the slit gaps open a little bit. you could even taper the hole too so it doesn't look like a tube on the body. great start though! can't wait to see it finished
Profile PM YIM MSN
Mihai Ionita
PostPosted: Sun 25 Jul, 2010 12:36 am    Post subject:         Quote
Your cat seems to be watching you intently. By its gaze, it seems to approve what it sees.
I also concur with the chaps. Narrower is somewhat better than wide (and more functional, I would assume).
Profile PM E-mail
Thomas R.
PostPosted: Sun 25 Jul, 2010 1:57 am    Post subject:         Quote
Hey Sander, good work.
You are doing a really inspiring work there. But I would advise narrower arm and big arm holes. Ahm... like slits going down from armpit to mid-waist, so you will have a maximum of movement allowed. I planning on doing a second surcot as well for my 1250 kit.
Thomas
Profile PM Website
Sander Marechal
PostPosted: Sun 25 Jul, 2010 3:44 am    Post subject:         Quote
Thanks for your advice everyone. The arm holes are already quite big but it's hard to see in the picture. They end about 15cm below the armpit of my gambeson (which is already much wider than my actual arm at that point). The arm hole is 70cm around.
I will be making the shoulders narrower.
Some more advice if you please: Does anyone know how to properly hem the round neckline? I have found a couple of articles online that try to explain this, but most are short on detail and usually deal with stretchy fabrics like T-shirt material. Linen has a lot less stretch. I'm having trouble wrapping my head around it (no pun intended).
Thomas R.
PostPosted: Sun 25 Jul, 2010 3:53 am    Post subject:         Quote
Hi Sander,
as you stated earlier, that you can read german, I have posted you a link to excellent instructions. Its for a keyhole neckline and I used it for my under garment, but you can apply it to any regular neckline with minimal alterations.
http://www.isarviking.de/kleidung/tunika/tunika.htm
Sorry@all english readers, it's too much text to translate.
Thomas
Profile PM Website
Eric Allen
PostPosted: Sun 25 Jul, 2010 9:12 am    Post subject:         Quote
Do it like a regular hem, just take it very slow. It is a little easier to do by hand, since you'll likely have little fabric to work with and have only a little seam allowance, but you can do it on a machine if you take it slow.[/i]
Sander Marechal
PostPosted: Sun 25 Jul, 2010 11:19 am    Post subject:         Quote
Thank you both. I'll post more picture when I am further along!
Johan S. Moen
PostPosted: Wed 28 Jul, 2010 1:51 am    Post subject:         Quote
If rolling the edge proves to be too much of a problem, you can always stitch a piece of linen tape to it. Take the tape(simply cut out a strip about 2 cm wide and as long as the circumference of the neckline, plus a few centimeters), pin it on all the way round on the outside of the garment, sew a seam along the edge of the neckhole, and then fold/roll the tape to the inside and stitch it down. I'd definately do this by hand though, unless you're really good with a sewing machine.
Johan Schubert Moen
Sander Marechal
PostPosted: Wed 28 Jul, 2010 2:40 am    Post subject:         Quote
Thanks Johan, but the neckline is already done. I did it by cutting out a shaped facing sewn to the outside. Then I pressed the seam allowance, understitched it to the facing, pressed the facing to the back and secured it with blind stitches all around. I finished the arm holes and the splits in the front and back in the same way.
It took some time to figure out how to do it, but with the German tutorial that Thomas posted and this tutorial I managed to figure it out. Mine is a little simpler than these examples because my neckhole is round, not keyhole shaped.
It's a lot of work but almost all of it can be done on the sewing machine. The only thing I do by hand is securing the facing to the back with blind stitches. But this goes quite fast as the stitches are wide apart.
All that remains is securing the facing of the front and back split, hemming the lower edge and sewing a cross on the left of my chest. With a little luck I will be done either tonight or tomorrow night.
All-in-all it has been much more work than I estimated. I think I have easily sunk 30 hours into it when I'm finished. But, it's finished to a much higher standard than I though I would be able to when I started this. Also, it's been slow going because this is my first real sewing project (aside from a marble bag) so I had to do a lot of research on the internet on how to sew and operate my machine.
Pics to follow when it's finished!
Sander Marechal
PostPosted: Fri 30 Jul, 2010 10:59 am    Post subject:         Quote
Yesterday evening I finished my surcoat as planned. Here are some pictures. The third picture show a detail of the cross. I have folded under the edges and pressed them. Then I blind-stitched it to the front. The fourth picture shows a detail of the inside finishing. All the edges are finished with facings, pressed, understitched, pressed again and then blind stitched. You can't see anything on the front. It's mostly made on a sewing machine but the blind stitches and the hemming was done by hand.
 Attachment: 112.12 KB
Front view. The cross looks off, but it's really straight.
 Attachment: 113.62 KB
Side view, showing the size of the arm holes.
 Attachment: 124.79 KB
Detail of the cross.
 Attachment: 167.17 KB
Detail of the inside finishing.
Shae Bishop
Likes: 9 pages
Reading list: 9 books
PostPosted: Fri 30 Jul, 2010 12:04 pm    Post subject:         Quote
Looks great Sander. I'm glad you narrowed the shoulders, looks right to me. It's really cool to see people's historical sewing projects. I'm working on sewing some much later period stuff right now, but I would really like to start working on a fourteenth century soft kit in the future. I have wondered before how many people have made their own surcoats.
Thomas R.
PostPosted: Fri 30 Jul, 2010 12:57 pm    Post subject:         Quote
Looks like you really spent a couple of hours on this! The cross looks indeed a bit off. How comes?
Thomas
PS: You've lost your cool beard during the sewing... :p
Profile PM Website
T. Hamilton
PostPosted: Fri 30 Jul, 2010 2:24 pm    Post subject:         Quote
Nice work, Sander! Thanks for the shots of the inside and close up of the cross. I like your gambeson, did you make that as well?
"What we do in life echoes in eternity."
Profile PM Website
Chuck Russell
PostPosted: Fri 30 Jul, 2010 2:29 pm    Post subject:         Quote
looks great. really like the arm openings now
the cross should not be centered if that's what you meant Thomas, it should be more over the heart.
Profile PM YIM MSN
Thomas R.
PostPosted: Fri 30 Jul, 2010 2:41 pm    Post subject:         Quote
Well, it looks like it's right arm is a bit curving down, compared to the left... but maybe it's just the fabric hanging in an awkward angle...
Profile PM Website
Sander Marechal
PostPosted: Fri 30 Jul, 2010 3:25 pm    Post subject:         Quote
Thanks for the compliments everyone.
Yes, the fabric is hanging down. The cross is exactly straight when you lay the surcoat flat. The right side of my surcoat wasn't properly folded down under my belt when these pictures were taken. You can also see that because the bottom of the armhole is sticking out a bit on the right but is flush with my gambeson on the left.
No, the gambeson was made by Matuls. The gambeson is actually very wrong. It's a 14th/15th century short gambeson that opens to the front. I knew it was wrong when I ordered it though. I don't have a lot of money so I want my kit to be as multi-period as possible. The Netherlands has a lot of 14th/15th century reenactment so I opted to get the wrong gambeson and hide the wrong bits under a surcoat for my mid-13th century Hospitallers kit. That way I can use the gambeson without the surcoat at other events. Judging from your comment, I think it succeeded :lol: When money permits I will get the proper long gambeson that has no front opening.
I have a bunch more projects planned. I still need braies and hosen. Also, I offered my girlfriend to sew a gown and undergown for her birthday. The gown is going to be one of those 13th century gowns with partially attached hanging sleeves. See the image below. The final upcoming project is a medieval-esque tarp/day-shade. Our reenactment group doesn't have the money yet for a period pavilion tent so we're making something simple and cheap that does not look too out of place. Not historically accurate, probably, but most of the general audience can't tell. I'll be sure to make more topics about these projects as they progress.
Picture of a gown with partially attached sleeves:
PostPosted: Fri 30 Jul, 2010 4:30 pm    Post subject: Re: 13th century surcoat project         Quote
What you have looks good and undoubtedly continued to be used through the 13th century.
This time frame is roughly credible for two styles of "over coat" for which the exact time line of transition is not well known. The full surcoat was actually very much so sleeveless (like a "tank top" tee shirt, with minimal upper body coverage. No extant examples of the style you have made survive, while several as I attempt to describe do.) Some minimal upper body examples are shown here. http://www.virtue.to/articles/extant.html
I am wondering if you considered the open sided "tabart" (11th century French for poor man's style overcoat) or "tabard" style. You can see the "3 musketeer" tabard style on priestly subjects in illuminated manuscripts back to early 12th century, identified with one of the kings (Alfred?) as early as 1115, and probably find academic discussion of how ornamented tabards and plain surcoats seem to have swapped social classes around this time. The tabbard was certainly common by 14th century (the assumed name in Chaucer's prologue to the collection that became known as Canterbury Tales.) An example from early 13th century (the closes the period had to a documentary about the crusade of that time) in actual combat shows what I consider to be a tabard, actually suited for mounted use and hotter environment as the hospitalers required.
http://prodigi.bl.uk/illcat/record.asp?MSID=8...;NStart=12
folio 109
 Attachment: 95.26 KB
Sander Marechal
PostPosted: Sat 31 Jul, 2010 1:23 am    Post subject: Re: 13th century surcoat project         Quote
Jared Smith wrote:
I am wondering if you considered the open sided "tabart" (11th century French for poor man's style overcoat) or "tabard" style. An example from early 13th century (the closes the period had to a documentary about the crusade of that time) in actual combat shows what I consider to be a tabard, actually suited for mounted use and hotter environment as the hospitalers required.
Are you sure that shows an open-sided tabbard? The style of drawing in that illimunation looks very much like the Maciejowski bible. Images of mounted knights in the bible look very much like that illumination, but whenever the bible shows dismounted knights, you can see clearly that the split is in the front. Perhaps it's an artifact of the lack of proper perspective in extant drawings?
Anyway, I haven't looked much at tabbards because, according to several books about the Hospitallers, the papal decree from 1248 specifically allowed them to wear surcoats instead of their regular uniform into battle (which we assume is an ankle-length mantle). I haven't read anything about tabbards. But that said, I haven't been able to find the original papal bull to see if the words in it could also be translated as e.g. a tabbard instead of a surcoat.
