Scott Hrouda
Posted: Fri 20 Aug, 2010 8:48 am Post subject: Hafting my Poleaxe Head |
Recently I was inspired by this thread to get off my duff and do something with my poleaxe head lying about the shop collecting dust.
The GDFB Poleaxe, Head Only (XB0099) is a nice piece for the money, although some minor file work was required.
An ash wheelbarrow handle from the local hardware store was used for the haft. I ripped it down to 1.25 inches square on my table saw, then used a spoke shave and hand plane to give it a moderately octagonal shape below the langets.
I decided to not inset the langets into the haft as I had been told “this is a special kind of hell”. Maybe next time. I did sand it lightly while leaving some "flaws" as I will be distressing the piece. The haft was liberally rubbed with boiled linseed oil several times.
As Sean Flynt mentioned, “There's a shocking lack of proper langet nails these days.” I resorted to peening standard 8 penny nail heads, which gave a less manufactured look, then cut the nails to length. I cut them so that they would just barely poke through the other side of the haft. As this piece will be for decoration only, I did not cut them long enough to protrude from the haft in order to peen them over. I did cheat a little and added epoxy into the head mount just to be safe.
The hammer head has a simple waffle pattern. Wanting little pyramid shaped nubs instead of little square ones, I spent a quality evening with my trusty files.
Attached below is a progress shot taken a few days ago. It should be obvious that I am no photographer. I decided to have a little fun and took a moderate strength stab at an old shield leaning against my work bench. This half-hearted stab with an unsharpened point protruded 2 inches through 0.5 inches of laminated plywood!
Currently the poleaxe is undergoing “forced aging” using techniques in the The Instant Antique feature article. I will post photos of the distressed poleaxe when the process is complete.
Attachment: 17.21 KB
Attachment: 16.85 KB
Attachment: 14.47 KB
Attachment: 16.39 KB
Attachment: 13.32 KB
Attachment: 18.29 KB
Attachment: 11.79 KB
Attachment: 12.32 KB
Scott Hrouda
Posted: Fri 20 Aug, 2010 9:34 am Post subject: |
I've managed to correct the picture issue.
A special thanks goes to Sean Flynt for advice, inspiration, as well as many well written articles and posts.
Thank You,
-Scott
Posted: Fri 20 Aug, 2010 10:44 am Post subject: |
That looks outstanding, Scott! So you have, what, $50 invested? I'm especially impressed by your work on the hammer face. I wish I had your langets! Mine are rather thin.
Scott Hrouda
Posted: Fri 20 Aug, 2010 11:49 am Post subject: |
I have a total investment of $63 USD and several hours in this project.
Thank you for the filing compliment. I wish the hammer face had more "meat" to it as there wasn't enough to get the pyramid heads to a sharp point. I had to settle for a Mayan-like flat topped pyramid as a Snefru shape would have looked rather silly.
You are correct, the langets are very hefty. Because I didn't inset the langets into the haft, some minor filing was required at the ends to prevent injury to my hands when changing guards. It is worth noting the langet-to-head welds are very suspect. I was liberal with epoxy in this area because it scared me a little.
I dished a stop-guard last night and rolled the edge. Mounting will have to wait until next week.
Your aging tip regarding salt and vinegar in a spray bottle was spot on. There’s been some serious corrosion after just one night!
Posted: Fri 20 Aug, 2010 12:11 pm Post subject: |
Yeah, I slightly beveled the edges of my langets with the file, too. I hope I didn't forever turn you off insetting langets I inset langets for a couteau de breche many years ago. The result was nice but not necessary or even appropriate for many polearm forms. Mainly, with a long, broad and thick pair of langets, by the time you get them marked, chiseled out so cleanly that the langets lie flush and bevel the haft accordingly you have almost as much time invested as you'd need for an historical scabbard core. To me, it just ain't worth it for an inexpensive head. Those with better shop skills, sharper chisels and more time would offer a different perpsective, I'm sure. But if I could buy an unmounted Arms & Armor pollaxe head and langets, you bet I'd invest the time.
I'm eager to see your rondel!
JG Elmslie
Posted: Fri 20 Aug, 2010 12:24 pm Post subject: Re: Hafting my Poleaxe Head |
Scott Hrouda wrote: | I decided to have a little fun and took a moderate strength stab at an old shield leaning against my work bench. This half-hearted stab with an unsharpened point protruded 2 inches through 0.5 inches of laminated plywood! |
this rather does raise a question I've been pondering for a little while - does anyone know of good pollaxes suitable for WMA/Reenactment fighting, with rebated edges and a blunt spike?
I've been thinking over them for a while now, and struggling to think of solutions... I could probably make one, but not easily, so would love to know of any reccommendations
Scott Hrouda
Posted: Fri 20 Aug, 2010 3:19 pm Post subject: Re: Hafting my Poleaxe Head |
JG Elmslie wrote: | this rather does raise a question I've been pondering for a little while - does anyone know of good pollaxes suitable for WMA/Reenactment fighting, with rebated edges and a blunt spike? |
The first option that springs to mind is the Arms & Armor Knightly Pole Axe. This is arguably the finest recreation on the market today. I'm sure you could ask them to produce one with rebated edges and a blunted spike.
Another option is the Complete Talhoffer Poleaxe.
Hanns Wiechman
Posted: Fri 20 Aug, 2010 3:46 pm Post subject: |
Hey, I recognize that shop and the shield in the background? Nice work on the poleaxe! You could always bore through the head and langets and put in a larger pyramidal rivet to hold them better together in case the poleaxe is used on a ham or turkey at our next gathering.
Scott Hrouda
Posted: Mon 23 Aug, 2010 6:08 am Post subject: |
Hanns, thank you for the compliment. We'll have another group feast around Thanksgiving. Let's roast a turkey on the spike and tenderize the steaks with the hammer.
Scott Hrouda
Posted: Wed 25 Aug, 2010 10:13 pm Post subject: |
Progress has been made. 5 days after applying the "aging spray" the poleaxe was well oxidized. An initial cleaning with 0000 steel wool revealed some nice results. There's still work to be done...
Attachment: 21.39 KB
Attachment: 28.89 KB
Bill Grandy
Posted: Wed 25 Aug, 2010 11:04 pm Post subject: Re: Hafting my Poleaxe Head |
Keep in mind that a blunt poleaxe is still a poleaxe. Quite frankly, a rubber poleaxe hits pretty damn hard, too.
I use the Revival.us "Talhoffer" ones that Scott linked to above. There is also the Historic Enterprises one, but I haven't actually seen these in person, so I don't know if they are worthwhile or not.
http://historicenterprises.com/pollaxe-simula...th=101_207
Virginia Academy of Fencing Historical Swordsmanship
--German Longsword & Italian Rapier in the DC Area--
"A despondent heart will always be defeated regardless of skill."
Blaz Berlec
Posted: Thu 26 Aug, 2010 8:59 am Post subject: |
Scott Hrouda wrote: | Progress has been made. 5 days after applying the "aging spray" the poleaxe was well oxidized. An initial cleaning with 0000 steel wool revealed some nice results. There's still work to be done... |
Nice!
I have the same GDFB polaxe head, but mine is a bit uglier - hammer head is not quite aligned with the central axis. But I can live with it, all the welds seem OK. I'll reshape the hammer face as you did, and I've already made the haft - 1,5 meter ash, rectangular at top and octagonal at bottom. I made it from 33 x 33 mm piece, which tapers slightly to the bottom. I also chiselled grooves for the top part of the langets, and since the haft tapers, it does't bend them too badly - I don't want to chisel the whole langets into the haft.
I'm not really impressed with the surface finish of the polaxe head - some parts are almost mirror finish, and other (welds) are pretty rough. This "instant ageing" process looks like it could give it a more uniform appearance, I might just try it. Before I nail the head to the haft.
Brad Lilly
Posted: Thu 26 Aug, 2010 10:56 am Post subject: |
Being a new guy around here.... Are the heads of warhammers and poleaxes inlet for the handle or are the langets all that hold it on?
Looks great by the way.
Scott Hrouda
Posted: Mon 30 Aug, 2010 6:33 am Post subject: |
Sean Flynt wrote: | I'm eager to see your rondel! |
I'm having rondel/stop-guard issues.
Currently, it's 4.5 inches in diameter which just feels too large. Does anyone have a good idea what diameter they are supposed to be?
I would have no problem trimming it as I'm totally dissatisfied with my edge rolling. I hurried the job and did not roll the edge over wire.
Posted: Mon 30 Aug, 2010 7:32 am Post subject: |
I think you could reduce it to 4" if it bothers you. It seems to me that it's meant only to prevent a blade from sliding down the haft and cutting the forefinger and thumb. I don't think it's meant to offer much protection to the rest of the hand. These seem too small for that.
Scott Hrouda
Posted: Tue 31 Aug, 2010 6:49 am Post subject: |
Brad Lilly wrote: | Being a new guy around here.... Are the heads of warhammers and poleaxes inlet for the handle or are the langets all that hold it on? Looks great by the way. |
Welcome Brad!
Poleaxe hafts typically fit up into the head and may be affixed with nails or rivets depending on the period and type of pole weapon. Langets may also be used to secure the head and/or provide some protection for the wooden haft. There's really quite a variety and I am by no means an expert. I simply like to read, dabble, have fun making cool things then hit inanimate objects with them.
There are more knowledgeable people on this forum that may provide a better or clearer answer for you. The book Hafted Weapons in Medieval and Renaissance Europe: The Evolution of European Staff Weapons between 1200 and 1650 (History of Warfare 31) has been recommended as a very important read, but I have yet to pick up a copy.
Gabriele A. Pini
Posted: Tue 31 Aug, 2010 9:39 am Post subject: |
Good work Scott.
You confirm my theory that you don't have to spend huge sums to make a good kit to parade, and not even a great deal of work. Now if only I could convince the rest of my company...
Scott Hrouda
Posted: Thu 02 Sep, 2010 7:06 am Post subject: |
Sean Flynt wrote: | I think you could reduce it to 4" if it bothers you. It seems to me that it's meant only to prevent a blade from sliding down the haft and cutting the forefinger and thumb. I don't think it's meant to offer much protection to the rest of the hand. These seem too small for that. |
I carefully cut off the poorly executed rolled edge and took my time re-rolling the edge over wire. I'm very pleased with the results. The diameter is now 3.75 inches which both looks and feels ALOT better.
Some issues have arisen while mounting the rondel with custom made brackets. I chewed that fat a little bit last night with my buddy and sparing partner Hanns Wiechman and I think a solution is at hand. Pictures will follow after the holiday weekend.
Chris Arrington
Posted: Fri 03 Sep, 2010 8:51 am Post subject: |
Nice thread ! I've been considering this very same project.
Has anyone tried the ash shafts that Kult of Athena sells? My metal working skills are adequate, but my wood working totally stinks.
Scott Hrouda
Posted: Tue 07 Sep, 2010 8:36 pm Post subject: |
Chris Arrington wrote: | Nice thread ! I've been considering this very same project. Has anyone tried the ash shafts that Kult of Athena sells? My metal working skills are adequate, but my wood working totally stinks. |
Thank you Chris! You probably want to use octagonal shafts / hafts whereas the KOA shaft is round in cross section.
Here are some more progress pictures. I managed to make four mounting brackets out of 1/8" round stock. The rondel is 3.75 inches in diameter and the center has been filed out to match the profile of the haft, including langets. I mounted the brackets to the rondel using little brass rivets for some contrast in color. The brackets were then nailed to the haft with some more homemade arming nails.
The last part was the trickiest. A lot of time was spent bending the brackets "this way and that" to get everything to line up just right.
The last photo clearly shows one of the dents I made by whacking the haft with all manner of tools in the shop. That was a FUN evening of "antiquing"!
Everything has been sprayed and is "aging" again, just sitting there getting rusty...
Attachment: 30.94 KB
Mounting brackets
Attachment: 28.45 KB
Rondel
Attachment: 30.68 KB
Brackets attached
Attachment: 22.85 KB
Rondel finished
