Forum Index > Historical Arms Talk > Inexpensive Sallet Upgrade: DIY Project Reply to topic
PostPosted: Wed 04 Aug, 2021 7:37 am    Post subject: Inexpensive Sallet Upgrade: DIY Project         Reply with quote
Here's another inexpensive armour project for the DIY crowd. This $88 "Burgundian Sallet" (mine is from Kult of Athena, but you can find it under that name worldwide.) is aiming for an Italian/Franco-Burgundian form like that of the Metropolitan Museum of Art's heavily restored example: https://www.metmuseum.org/art/collection/search/26451
You can see the reproduction from various angles here: https://www.kultofathena.com/product/burgundian-sallet/
It seems to me that this the most historically plausible off-the-rack sallet currently available at the low end of the market. I'd like it to be deeper, but the form is pretty good overall, and even the turns of the plates correspond to the Met's sallet. Lining is of historical style, but glued-in rather than riveted. It pulls out easily and can be reinstalled with a proper lining band. Straps are the right shape, but of modern stitched construction. The 16 ga. bowl is too shallow to be worn without the brow reinforcement and articulated nape defense, but those plates have good form and decent fit. It's not oversized, and it can be bent here and there to customize fit. This piece is easily upgraded to something relatively plain, as in the Met example. That's pretty much free. If you want to invest in a handful of fancy brass rivets for the back and plates, and maybe add a plume holder and blued finish, you could have a high-status sallet of ca. 1480.
My current aim is for a plain finish with a new and properly secured liner and straps. So far, I have:
• Pressed in the sides of the bowl slightly to customize the fit.
• Removed the four rivets that secured the brow reinforcement and nape defense. I'm using wing nuts for easy assembly/disassembly during the upgrade process.
• Used CitriStrip to easily remove the flaking glossy black paint from the interior of the bowl and plates.
• Sanded the bowl and plate exteriors to reduce the very bright factory polish. I haven't yet decided on the final finish.
• Marked the rivet line for the lining band. As shown here, I've planned for eight standard domed steel rivets across the back, four large decorative rivets to secure the plates, six or eight flush rivets under the brow defense, and one flush rivets below the decorative rivet on each side of the brow reinforcement. The nape defense requires free articulation.
• Cut a lining band.
I'll add photos as I go through this project.
 Attachment: 582.82 KB
 Attachment: 556.61 KB
 Attachment: 546.83 KB
 Attachment: 219.16 KB
Tyler C.
PostPosted: Mon 09 Aug, 2021 5:19 pm    Post subject:         Reply with quote
This looks like a fun project. Looking forward to seeing your updates!
PostPosted: Fri 13 Aug, 2021 10:06 am    Post subject:         Reply with quote
Here's the original liner, with the start of a new lining band in the background. You can see that the ends of the liner are overlapped to create the proper fit. The thin black material visible in that overlap is the very thin original lining band. The lining is stitched separate from that band, so removal of the band stitches will not affect the liner apart from unstitching the overlap. I'll make a new liner and band, though the original liner is better than what you'll find in some reproduction sallets costing far more. The only reasons not to use it (with a proper lining band) are if you just want to say you did as much as possible yourself, or if you find it too thin. I'm in both of those camps.
 Attachment: 406.57 KB
PostPosted: Thu 19 Aug, 2021 7:27 am    Post subject:         Reply with quote
The bowl is drilled for a variety of rivet types. The rivets under the brow defense will be modified flat-head nails. The row of rivets over the nape defense will be standard domed rivets. The brow defense will have on each side one decorated rivet and one flush or almost flush rivet. The nape dense will pivot on two decorated rivets.
Flush rivets would be most appropriate for use under the brow defense but I think the bowl is a bit too thin to create the necessary recess.
The first image below shows how I mark the position of lining rivets for drilling. Note the poor weld where the halves of the bowl were joined. This flaw is concealed by the nape defense.
The second image shows my quick/crude decoration of the nails that will become rivets at the sides of the sallet. These are loosely based on the rivets of the Met sallet, which might have been added as part of the sallet's renovation. In the background, the rivet-punched band is temporarily in place (with wing nuts) to ensure fit before I trim the length and punch the holes for stitching.
 Attachment: 430.29 KB
 Attachment: 354.79 KB
PostPosted: Tue 07 Sep, 2021 9:02 am    Post subject:         Reply with quote
Here a few more shots of the process. These include making washers for the lining rivets, developing new straps and making/mounting the steel buckle.
 Attachment: 335.62 KB
 Attachment: 285.66 KB
 Attachment: 439.01 KB
 Attachment: 450.24 KB
 Attachment: 452.56 KB
 Attachment: 318.3 KB
 Attachment: 567.39 KB
PostPosted: Tue 21 Sep, 2021 7:36 am    Post subject:         Reply with quote
Just finished this one. I didn't include a drawstring/thong at the top of the lining peaks. Most one-size-fits-none helmets need that suspension system, but this one fits me so well that it's not needed.
If you want to try a helmet project, I'd say this is a good and cheap introduction to that work. You can do a complete overhaul like this project, but it's wearable (and a good value) in its stock form. You don't have to have multiple rivet types or make your own rivets. Use one kind of readily available rivet and one drill bit. Use manufactured round washers (they won't be seen). Re-use the stock liner until you feel ready to do that work. You definitely should make new straps and buckle to install with the lining band. Buckles are not hard to make, and they have applications across the whole hobby.
 Attachment: 360.14 KB
 Attachment: 258.02 KB
 Attachment: 256.33 KB
 Attachment: 252.96 KB
Bill Grandy
Reading list: 43 books
PostPosted: Tue 21 Sep, 2021 7:45 am    Post subject:         Reply with quote
Awesome work, Sean!
HistoricalHandcrafts.com
PostPosted: Tue 21 Sep, 2021 8:04 am    Post subject:         Reply with quote
Thanks! I hope this company will be rewarded for trying, and turn out some other simple forms that could be used as-is or serve as the foundation for projects. A plain steel cap would be cool. You could line it, add rondels, etc. Black sallet–paint it, cover it. Those helmets are expected to be of indifferent quality and finish, so the historical bar is already pretty low. They just have to try to get the form right. So many manufacturers don't even try.
Julien M
PostPosted: Wed 22 Sep, 2021 9:22 am    Post subject:         Reply with quote
Great work as usual, subtle but clear improvements.
Good to see you back at the workbench Sean Happy
PostPosted: Thu 23 Sep, 2021 2:45 am    Post subject:         Reply with quote
Thanks! Now, back to edged weapons!
Christian Henry Tobler
PostPosted: Mon 27 Sep, 2021 5:04 am    Post subject:         Reply with quote
Nicely done, Sean - this looks great!
Best regards,
Christian
Order of Selohaar
