Posts: 371 Location: Klein, Texas
Tue 22 Nov, 2016 10:00 am
Scott - go to the two sites linked below and submit pictures in the newbie sections. There are also resources on both that have data on markings, etc. You'll want some additional pictures, including a good shot from the top, showing the date and toggle stamps clearly, and everywhere a number or symbol is stamped - this includes the disassembled pieces. If you don't feel comfortable disassembling the gun, you will get less info.
Basically, on these guns, practically every piece that could be stamped with a serial number was. Your primary serial is 1466, but I couldn't see the post-script letter on the end (this is important for determining date range of manufacture within the given year). All of the smaller pieces with a stamp (including the inside of the grips) will be stamped with a "66" if they match. Appears it was produced by DWM, Deutsche Waffen und Munitionsfabrike, (the large mark on the toggle that is hard to see in the photos), which is the original manufacturer of lugers and is considered highly prized. The magazine looks like it is of the right era (wood base, nickel rather than blue), and should also have a full serial number stamped on the wooden base (including letter). If the magazine has a "+" after the serial number, it means it was the "second" magazine and not the "primary" magazine. Also, you may want to look through your dad's papers - soldiers that brought lugers back with them were supposed to file paperwork with the military that approved the "bring back" and provided data on the gun and some of its markings. Even if it wasn't brought back by your dad, he may have acquired it from the soldier, or the family of the soldier, who did and have that paperwork. The more of the story you have and the documents you have to back it, the greater the value. I can tell you that since there is no seer safety, it is likely a military gun. Without seeing the toggle markings, etc., I can't say whether army, air force or navy, but I doubt navy since the anchor and the Kriegsmarine "K" typically stand out and should be visible even in the shot provided of the top of the gun.
If there is a holster and tool with a matching acceptance mark, with matching year and all other elements lining up (Army issue, Air Force issue, German, Swiss, Portuguese), this also adds value. For the barrel length gun you have (i.e., not an "artillery" luger), Air Force and Navy are most sought after, generally, since they were the least likely to survive the demise or surrender of their original owner.
Good luck!
Myself, I have a 1939 Mauser Army, 5555p, all matching except magazines. Mine has a bit of deterioration in the bluing on one side. It has been speculated that the deterioration is due to organic biological staining that wasn't immediately removed. It was a WW2 piece, recovered by a US soldier - I'll let you work out how it was stained...
http://luger.gunboards.com/forum.php
http://forum.lugerforum.com/index.php
