David Gaál
Posted: Fri 21 Sep, 2012 12:18 pm Post subject: Freiturnier and Ballienrennen |
Hello
I found this two words: Freiturnier, Ballienrennen; if I know well free turney the first and tilt the other does mean. What is the difference between the two? I have seen armours attributed with this two worlds but for me they seem the same: armour made for jousting purpose. So what gives the difference between an armour made for Freiturnier and an armour made for Ballienrennen?
Dávid
Dávid
http://energie-fenster.at/
Michael Curl
Posted: Fri 21 Sep, 2012 12:52 pm Post subject: |
I can't answer your question but I want to give you help on English. Change the spelling of WORLDS, to WORDS. World means Earth or Mars. I can help you more if you want, but I don't want to sound mean.
E Pluribus Unum
Posted: Fri 21 Sep, 2012 3:52 pm Post subject: Re: Freiturnier and Ballienrennen |
David Gaál wrote: | Hello
I found this two worlds: Freiturnier, Ballienrennen; if I know well free turney the first and tilt the other does mean. What is the difference between the two? I have seen armours attributed with this two worlds but for me they seem the same: armour made for jousting purpose. So what gives the difference between an armour made for Freiturnier and an armour made for Ballienrennen?
Dávid |
I guess Freiturnier might be melee and Ballienrennen might be jousting over a barrier.
Scott Woodruff
Posted: Fri 21 Sep, 2012 9:47 pm Post subject: |
That sounds right to me, the first I read as "free tourney" the second as some sort of "race", maybe a "hurling race." That seems like a good description of jousting at a barrier to me. Perhaps someone who speaks German well can correct me, but doesn't ballien have something to do with projectiles or ballistics?
David Gaál
Michael Curl
Posted: Sat 22 Sep, 2012 1:41 pm Post subject: |
Your welcome. Also, I am thinking that your post is supposed to say "I had just finished a lot of hammering."
If you do not want me to correct your English that is fine. I am just assuming that you would want correction.
E Pluribus Unum
Anders Backlund
Posted: Sat 22 Sep, 2012 7:20 pm Post subject: |
Michael Curl wrote: | Your welcome. Also, I am thinking that your post is supposed to say "I had just finished a lot of hammering." |
Or perhaps he meant he made the post after getting hammered?
Ahem, but seriously.... Just based on the context and the words it sounds like they refer to the type of jousting the armors were intended to be used for.
-Homer Simpson.
David Gaál
Posted: Sun 23 Sep, 2012 2:01 am Post subject: |
Or I have hammered my family with a hammer, and after it, they hammered me too with a hammer which was hammered by a hammer. So we had a great "hammer"time! - Sir Hammer (thanks for the good sense of humor)
Yes Michael my English needs sometimes correction but as it is not my mother tongue I suppose it is quite normal. But if you really want to help me in English I would be happy for it. Maybe once or twice if I read something in English and need someone to explain it's meaning or just have something to translate into English and can't find the correct world it would be great if you could help me out.
But back to the main question: I'm interested in any thoughts about the topic.
Dávid
Thomas R.
Posted: Sun 23 Sep, 2012 2:39 am Post subject: |
Hi there,
I've found some german source on the term Ballienrennen:
"Plankengestech, Ballienrennen oder Welschgestech hieß eine Turnierkampfart, bei der die berittenen Zweikämpfer nach kurzem Anlauf beidseits entlang einer trennenden Planke mit der Lanze gegeneinander anritten. Mit der Lanzenspitze wurde dabei auf die Tartsche gezielt, einen auf der linken Brustseite getragenen Turnierschild. Die Trennung der Bahnen bedingte, dass die Lanzen unter einem Winkel von maximal 75° auftrafen, und somit die Wucht des Stoßes deutlich gegenüber jener beim ®"Scharfrennen" gemindert war. Wegen der Gefahr, vom Pferd gegen die Planke gedrückt zu werden, wurde beim Plankengestech ein Beinschutz getragen."
So it's a specific form of tourney, where both riders were separated by a fence of planks.Since the lanes were separated, the lances would collide at an angle of maximal 75 degree, which would lower the impact in contrast to the so called Scharfrennen. At a Ballienrennen the knights wore a Tartsche and leg armor (the latter because of the danger of being pushed at the planks by the horse).
Hope this does help,
Thomas
PS: I think in this video there might be a good example for a Ballienrennen.
David Gaál
Posted: Sun 23 Sep, 2012 8:44 am Post subject: |
Thank you Thomas,
You have found great things. Really interesting. Such planks I have seen before but never thought that they were made so specially. And does Freiturnier mean the same as Scharfrennen?
Thanks
Dávid
Dávid
