Posts: 4 Location: australia
Sun 15 Mar, 2009 3:27 pm
cutlass
Posts: 967 Location: Michigan
Sun 15 Mar, 2009 3:32 pm
Well, I'm afraid i'm not knowledgeable enough to speak to its authenticity or not, but it appears to be a Confederate version of the 1860 US naval cutlass.
Hope this helps,
Dan
Sun 15 Mar, 2009 3:37 pm
cutlass
there are no no. only a stamp macon arsenal..seems strange...
Attachment: 26.36 KB
Sun 15 Mar, 2009 3:42 pm
Well, I do believe the Macon arsenal was a fairly large military manufacturing center for the South in the American Civil war, so that would seem to back up the Confederate association.
Dan
Sun 15 Mar, 2009 3:55 pm
cutlass
ok..thanks dan...an ames copy?........
Mick
Mon 16 Mar, 2009 10:07 am
definitely a southern version of the 1860 model cutlass. you can tell by the anchor. to the best of my knowledge the USN never used that style of anchor to mark it's equipment, or uniforms, aside from that, it is definitely an 1860 model cutlass. sorry I can't do more than support what you've already been told.
Mon 16 Mar, 2009 10:17 am
I stand corrected about the anchor. I can also say that it definitely isn't an ames pattern. the basket is too full for it. I do, however, still agree that it is a confederate blade. I just did a search on google, and disvovered that a button for a uniform had the letters CSN arranged around an anchor in similar fashion. I can only guess what they stand for, but I think that it stands for Confederate States Navy. maybe. I may be wrong, I thought that they had a different name for themselves. anyway, definitely a CSN cutlass, and DEFINITELY 1860 model
Mon 16 Mar, 2009 11:21 am
I recommend contacting a specialist dealer or collector. Confederate arms are widely faked, and there are very convincing fakes out there on the market.
Best of luck,
Jonathan
Posts: 5,981 Location: Birmingham, Alabama
Mon 16 Mar, 2009 11:47 am
It's almost certainly an artificially-aged reproduction, with spurious marks.
Mon 16 Mar, 2009 3:10 pm
cutlass
this is my problem,when i started to do the study on the sword...on my mind yes it;s a copy...but after studying quite a few modern swords.i found that this one always had a difference..first the rivits are bigger and fewer on the handguard than aftermarket models,and second..the hand guard is a lot thicker ...
Thu 19 Mar, 2009 1:47 pm
CSN Cutlass
Mick,
I'm new to the forum. I came across your post on the cutlass after a google search. I collect Confederate naval cutlasses. The example you show if a fake and a fantasy piece. It is a reproduction 1861 model of the type made in India or Pakistan (high dome on the pommel) , aged over and false marking added. These fakes are well known by collectors and often show up on ebay.
Hope this helps.
Jerry
Thu 19 Mar, 2009 3:30 pm
Cutlass
The cutlass is a modern reproduction made to look old and the markings were also added. I have seen other examples of this very same item. Jeff
You
cannot post new topics in this forum
You
cannot reply to topics in this forum
You
cannot edit your posts in this forum
You
cannot delete your posts in this forum
You
cannot vote in polls in this forum
You
cannot attach files in this forum
You
can download files in this forum
