Jared McClelland
Posted: Fri 02 Dec, 2016 10:43 am Post subject: Shoulder armour in this 15th century Italian Manuscript |
http://manuscriptminiatures.com/4608/12984/
For a while I've been trying to put things together so that I can have a fairly accurate armour harness made based on Italian armour from around the 1430s, the only thing I haven't been able to find actual artifacts for is shoulder armour. Artwork I've found from the time (as seen in the link I included) doesn't depict it too well (I usually can't even tell if it's supposed to be spaulders or pauldrons). Anyone know what that drawing might be representing in terms of shoulder armour?
Mark Moore
Posted: Fri 02 Dec, 2016 11:13 am Post subject: |
Looks to me like a simple, dished pauldron with segmented upper arm. The cloak is hiding most of the pauldron, so the actual shape is unknown. But, a simple, rounded shape would be most likely. .....McM
Mark Moore
Posted: Fri 02 Dec, 2016 1:14 pm Post subject: |
If you are just wanting them for costuming purposes, Epic Armoury sells the Merc Steel pauldrons in 18 ga. steel. One piece shoulder, with two lower lames. Buckled belt at the top, and adjustable upper arm buckled belt. The shoulder belt can be used with either the buckle or strap end, or the whole belt---depending on what you are attaching it to. Looks very similar to the picture, though they are not taken from any historically based armor that I know of. I guess you could say they are 'generic'. If you are planning on any SCA/HEMA fighting, something in a thicker gauge steel would serve you better. The Merc's are available at KoA...not a bad price either. ..........McM
Jared McClelland
Posted: Sat 03 Dec, 2016 9:35 am Post subject: |
Mark Moore wrote: | If you are just wanting them for costuming purposes, Epic Armoury sells the Merc Steel pauldrons in 18 ga. steel. One piece shoulder, with two lower lames. Buckled belt at the top, and adjustable upper arm buckled belt. The shoulder belt can be used with either the buckle or strap end, or the whole belt---depending on what you are attaching it to. Looks very similar to the picture, though they are not taken from any historically based armor that I know of. I guess you could say they are 'generic'. If you are planning on any SCA/HEMA fighting, something in a thicker gauge steel would serve you better. The Merc's are available at KoA...not a bad price either. ..........McM |
At the moment I am m getting armour more for costume purposes, but I may eventually get into reenactment or living history, so I'm trying to get the armour as historically accurate as possible. So I'm not really interested in Epic Armoury armour, thanks for the suggestion though.
James Arlen Gillaspie
![](images/avatars/14920799634383e73f788e2.jpg)
Posted: Mon 05 Dec, 2016 2:52 pm Post subject: |
Google 'Mantova ducal palace Pisanello' and you will see frescos from the mid 1430's showing very large pauldrons They go back further than that.
Attachment: 94.19 KB
![Mantova Pisanello.jpg](files/mantova_pisanello_107.jpg)
jamesarlen.com
Jared McClelland
Posted: Mon 05 Dec, 2016 7:40 pm Post subject: |
James Arlen Gillaspie wrote: | Google 'Mantova ducal palace Pisanello' and you will see frescos from the mid 1430's showing very large pauldrons They go back further than that. |
Thank-you for this, I've been searching for a good source on shoulder armour for several months, this helps me tremendously.
Posted: Tue 06 Dec, 2016 8:49 am Post subject: |
Here's another painted by Fabriano c. 1425.
Attachment: 52.81 KB
jamesarlen.com
