Posts: 158 Location: Tiny RED Dot
Fri 15 Sep, 2006 8:22 pm
Medieval Sword Help
Hi,
I am presented the choice of the 2 following Medieval sword replicas:
Can anyone advise which is the more 'authentic' of the 2?? I mean, in terms of pommel design, shape of guard, the blade shape, the fuller length... etc.
N.B. I must admit these are not 'real', expensive, high-end replicas, but somethng for my novice pocket, and I'll get the one that's MOST representive of Medieval swords, according to all your feedbacks & advise.
Many thanks~
Larry
Attachment: 23.18 KB
Fri 15 Sep, 2006 8:25 pm
Re: Medieval Sword Help
This is the 2nd one...
Hope to hear from you guys.....
Many thanks!
Larry
Attachment: 19.68 KB
Posts: 1,435 Location: California, Maryland, USA
Fri 15 Sep, 2006 8:49 pm
Who's the makers?
Both look reasonably authentic in design, though that scabbard is obviously not period.
They're not by Windlass Steelcrafts are they?
M.
Posts: 1 Location: Louisville, KY
Fri 15 Sep, 2006 11:08 pm
Whats wrong with windlass?
Larry
Posts: 1,606 Location: Chicago, Illinois
Sat 16 Sep, 2006 12:14 am
Larry-
The blade of the first one looks a bit mismatched to the hilt. It seems to be a type XVI which is from a later period than the cocked hat type pommel. The second one's blade looks like a Xa or XI, which would be a good match for the hilt. I would highly recommend reading the following in the features section of this website:
Ewart Oakeshott: The Man and his Legacy. This article will help to explain what authentic swords looked like thus helping you to make a better decision. The spotlight articles on the different sword types are all also very well written and informative. Hope this helps.....
-Tim
Posts: 9,580 Location: Dayton, OH
Sat 16 Sep, 2006 6:12 am
I'd go with the second one. The blade on the first is off, as many are in this price range. The fuller is too long to make it a typical Type XVI, though. I think many of these companies start with a diamond
cross-section blade and then cut a fuller into it. I've run across this with Windlass stuff before. For swords of this era, a lozenge (aka lenticular) cross-section past the fuller would be more appropriate.
The second one just looks closer to my eye, though I'm not a big fan of the guard. It looks clunky to me.
As for Windlass, there's not too much wrong with them if you take into account their price tag and intent. They're not high-cost, high-end replicas, nor do they try to be so. Corners are cut in R&D and in production to keep costs down. The more recent ones I have seen are normally functional for light-duty cutting and are reasonably attractive. Are they as good as more expensive swords? Absolutely not. I don't believe they're intended to be, though.
Posts: 630 Location: San Diego, California
Sat 16 Sep, 2006 7:41 am
I'm not sure that the the first one really fits perfectly in the typology, but I'd call it closer to a Type XII than a Type XVI. It doesn't have as much of a
profile taper as most XVIs I've seen. I think I'd go with the first one, myself. The hilt on the second one really bugs me for some reason. Maybe it's the inch thick guard followed by the pencil thin grip. However it's actually balanced, it looks like it handles like a baseball bat. I like the lines and aesthetics of the first one better. But in this case, I think you might be better advised going with the one you like better, rather than the one that's more accurate. You could nitpick both weapons if you really wanted to.
As far as Windlass, they have a reputation for poorly researched blades made with improper weight and mass distribution and manufactured with substandard materials and quality control. I still have a few old Windlass pieces lying around somewhere that validate that description. But there are two points to be made about that. First, I've heard they've improved a great deal in recent years. Second, things like research, quality control and materials cost money. For what you pay, you're not being robbed. They cut those corners to keep their prices down. It's just a matter of what you want in a sword balanced against what you can pay.
Sat 16 Sep, 2006 8:08 am
| Sam Barris wrote: |
| I'm not sure that the the first one really fits perfectly in the typology, but I'd call it closer to a Type XII than a Type XVI. It doesn't have as much of a profile taper as most XVIs I've seen. |
The Type XVI attribution is coming from the combination of the diamond cross-section and fuller. It doesn't fit any one Oakeshott type, which is pretty typical of swords in this price range.
Sat 16 Sep, 2006 8:30 am
Re: ~Thanks
Hi everyone, many thanks for all the informative & insightful inputs :-)
In the beginning, I kinda like the 1st sword due to its unique pommel shape, sweeping hilt, and tapered blade. But I begin to be doubtful after flipping through some books & online resources - cos' I did NOT come across any mentioning of medieval swords having those pommel shape! Most of the medieval swords mentioned seem to come with wheel / brazil-nut pommel... That's why I wanted some feedbacks, as I do not want to be ignorant in what I buy :-)
Hope I did not stir up any dissentment betw "pro-Windlass" and the otherwise.. I do not expect this to happen :-( And for the record, NO, those are not Windlass swords.. But I do own a couple of Windlass swords & they're rather decent stuff, I must say, for the amt. I paid :-)
Please continue your feedback / comment to me... in particular, the 2 swords pix I put up.
Larry
Sat 16 Sep, 2006 8:37 am
The pommel form on the first sword did indeed exist.
Ewart Oakeshott classified similar shapes as pommel Types C & D, commonly called "cocked hat" pommels. These are laid out in our article on Oakeshott, which is worth a read. They are a late development of the lobated Viking pommels.
Sat 16 Sep, 2006 9:15 am
Re: Sword Pommel
Thanks for the quick response, Chad :-)
All this while I thought the
Ewart Oakeshott classifications only concerns the blades! Oops. Thanks for the clarifications, Chad.
Larry
Sat 16 Sep, 2006 9:33 am
Re: Sword Pommel
| Larry Lim wrote: |
All this while I thought the Ewart Oakeshott classifications only concerns the blades! Oops. Thanks for the clarifications, Chad.
Larry |
Larry,
Glad I could help. If you look through our Oakeshott article (which we hope will become a one-stop resource for info on Ewart Oakeshott), you'll see his typologies for blade, pommel, and guard explained as well as the concept of sword families, which ties all the other typologies together. In his European Weapons and Armour, he even puts forward a basic typology for warhammers. :)
Sat 16 Sep, 2006 11:01 am
| Sam Barris wrote: |
I'm not sure that the the first one really fits perfectly in the typology, but I'd call it closer to a Type XII than a Type XVI. It doesn't have as much of a profile taper as most XVIs I've seen. I think I'd go with the first one, myself. The hilt on the second one really bugs me for some reason. Maybe it's the inch thick guard followed by the pencil thin grip. However it's actually balanced, it looks like it handles like a baseball bat. I like the lines and aesthetics of the first one better. But in this case, I think you might be better advised going with the one you like better, rather than the one that's more accurate. You could nitpick both weapons if you really wanted to.
As far as Windlass, they have a reputation for poorly researched blades made with improper weight and mass distribution and manufactured with substandard materials and quality control. I still have a few old Windlass pieces lying around somewhere that validate that description. But there are two points to be made about that. First, I've heard they've improved a great deal in recent years. Second, things like research, quality control and materials cost money. For what you pay, you're not being robbed. They cut those corners to keep their prices down. It's just a matter of what you want in a sword balanced against what you can pay. |
Even if they are not windlass, they look the usual kind of aesthetically pleasant replica that will suit the beginenr reenactor as well as the public looking at what hey will feel as a real sword.
But blade geometry will besorely wrong for the experts, as long as you haven't found a philantropic manifacturer that cares for distal tapers, balance and other details that are knon to the best manifacturers only through costly RD.
You will know that in both cases you will have a decent toy that will impress bystanders but won't be ever considered a real sword.
They are good for training, however, even if their wrong geometry will not teach you what a real sword is.
After all historical training weapons were made of wood ...
Last but not least, you could receive swords with teh so called rat tang, i.e. a hidden feature that will likely yeld a broken sowrd.
rat tangs are tangs made of a small bar of low quality steel soldered to the blade.
A good hit and the tang detaches from the blade, leaving you with nothing.
At least ask them if they will provide you with a full tang sword, or you will possibly incur in an incident when parryng.
And, if this is an ebay "special offering", which is why you don't want to tell who is the builder, well, leave them where they are.
Posts: 5,739 Location: Wichita, Kansas
Sat 16 Sep, 2006 3:06 pm
Neither of these swords are accurate for what they're supposed to represent so I think a detailed analysis of things like fuller length are a bit pointless. There are also many swords from various periods that are hybrids of several features that
Oakeshott uses to define his typology, as such those swords fall outside of Oakeshotts work, so-called "tweeners" yet they exist. So I don't think we need to discount a modern replica because it doesn't strictly adhere to Oakeshott.
Neither sword is a truly accurate representation of a medieval sword, but neither are just about any swords in this price range. They will all lack the finer aspects of shape, design and proportion that separates a true recreation from a mere facsimile. Hilt construction will typically differentiate from the historic norm as well. Consequently, I don't think a decision should neccessarily be made based on things like fullers and pommel designs as most everything else is wrong as well.
In this case I think the decision should really boil down to aesthetics. Which sword looks the most attractive to you? Which one would you be happiest owning? For me it would be the first sword. It at least has a certain amount of grace and aesthetic line to its form. The second one is just plain ugly an clunky to my eye.
Sat 16 Sep, 2006 4:20 pm
Larry,
Albion Armorers offers a higher end version of the first sword you're looking at called the Ritter. Albion even includes a photo of the original sword that served as an inspiration for the Ritter, so you need not worry about cocked hat pommels being historically inaccurate:
http://www.albion-swords.com/swords/albion/ne...tions.htm.
If there's any way that you could afford the Ritter, even if it means saving up for a while longer, I'd say go for it. You won't regret having a sword that looks, feels and handles like an antique type XI, unlike the lower end swords, which you might be happy to have now but less thrilled later. Remember that Albion does offer a payment plan, so if you need to make the payments over a series of months, you can do it. Also, if you ever have to sell the sword for whatever reason, you can put it up here on the myArmoury forum Marketplace and recoup most of your funds, since Albion swords are generally in high demand and tend to sell at good prices even used. In contrast, it is doubtful that you'd get much at all for either of the two swords you're looking at if you tried to sell them used.
The Ritter can be seen here:
http://www.albion-swords.com/swords/albion/ne...ter-xi.htm
For more photos and a hands on review, see here:
http://www.myArmoury.com/review_alb_ritter.html
Sat 16 Sep, 2006 7:38 pm
Hey folks,
Thanks for all the discussions & feedbacks. I've picked up much through it all. Appreciate it very much :-)
I'm neither an enactor nor medieval swordmanship practicioner, so I not quite concerned abt the durability of the swords other than the hazards posed by a broken piece flying off & hurting somebody;
I'm a novice sword hobbyist trying to pick up some affordable yet (as much) representatives of the medieval swords (and also other era); As such, I usu. go for stuffs that attracts me aesthetically, but both these swords looks quite attractive to me, that's why I post this article in order to solicit additional opinions to help me in my decision making :-) I'm aware that such budget replicas are never 100% close to it's original forms, so I'm contented as long it's quite close :-)
For now, most of what I have now are decoratives (or, sword-like objects, as some pro calls them), and I don't have any intention to sell them cos we have very, very, very (note: 3 'VERY') strict arms & explosives laws here in Singapore, and it's quite impossible for me to sell/trade-away them locally, let alone overseas, unless I obtain a license from the relevant Police department. But even then, some restrictions apply. So for now, I'd just stick to collecting :-p
Yea, I've visited the online catalogs from Lutel, Arms&Armor, Albion, Therion Arms.. etc.. And my!!! I'm really tempted to own as many of them as I could afford!!! I've set it my long term goal to own at least one of those, as my hobby & budget grow... so I'm definitely saving up :-)
Larry
You
cannot post new topics in this forum
You
cannot reply to topics in this forum
You
cannot edit your posts in this forum
You
cannot delete your posts in this forum
You
cannot vote in polls in this forum
You
cannot attach files in this forum
You
can download files in this forum
