Posts: 11,553 Location: San Francisco
Fri 25 Aug, 2006 4:44 pm
Two-handed poleaxe from the British Museum
This was posted by
William M in another topic. I've split it into its own.
It is a two-handed pole-axe from the British Museum.
The museum card says this:
Steel two-handed poll-axe, the quillon block engraved with the arms of the Commonwealth
English, about 1619-53
Here is a photo I took of it last year:
Posts: 144 Location: Amarillo TX
:wtf: It looks like a really demented Tuck
Posts: 4 Location: Columbus, OH
Sat 26 Aug, 2006 8:52 am
I really like this very interesting warhammer---but do you recall its date? Has anyone ever seen it reproduced, or anything like it?
Posts: 1,812 Location: Washington DC metro area, USA
Sat 26 Aug, 2006 9:04 am
| Shawn Henthorn wrote: |
| ... It looks like a really demented Tuck |
Actually, I think it is a neat idea, so maybe that makes me demented :D . But point control when you use it as a tuck might be a little more difficult with all of that mass out near the tip.
Posts: 410 Location: Washington and Yokohama
Sat 26 Aug, 2006 12:11 pm
It really looks like a civilian remount from battlefield debris.
The size dosen't seem long enough for a pole axe, but maybe as a tourney/joust weapon? I could see it as a that more.
Sat 26 Aug, 2006 2:22 pm
I can get some idea of size by the other items in the picture, but I'd be curious to know it's exact dimensions.
Michael
Posts: 5,981 Location: Birmingham, Alabama
Mon 28 Aug, 2006 6:25 am
Is that a tube welded to the blade? If it's for a panache, this might be some sort of odd bearing sword.
Mon 28 Aug, 2006 10:09 am
There's always something new isn't there? It seems like this thing ought to be called a two handed hammer or something though, since I do not see an axe head there at all...
Mon 28 Aug, 2006 10:38 am
The length and shape of the hammer has me wondering if this is a one-of-a-kind cavalry weapon from the late 16th c. The Commonwealth mark and "panache holder" could have been added later as the weapon proved ineffecient or obsolete for field use. It would make an impressive bearing weapon.
Mon 28 Aug, 2006 11:57 am
| Russ Ellis wrote: |
| There's always something new isn't there? It seems like this thing ought to be called a two handed hammer or something though, since I do not see an axe head there at all... |
Poleaxes don't always have axe heads. In fact, most do not.
Mon 28 Aug, 2006 12:58 pm
| Nathan Robinson wrote: |
Poleaxes don't always have axe heads. In fact, most do not. |
Really? I'd always thought a pole axe was a rather specific configuration. That is an axe head, a back spike or hammer and usually a top spike. A polehammer on the other hand would be something with a back spike, a hammer face and perhaps a top spike. Interesting. I will consult Waldman and see what he has to say on the subject as well as Oakeshott...
For the moment:
Poleaxe, pollaxe, polaxe: "A knightly staff weapon, its head being an axehead, usually balanced by a hammerhead, and surmounted by a steel spike. The shaft was protected by steel checks and the hand by a steel rondel. Used from the fifteenth century for foot combats and for war. The component 'pole' in the name refers not to the staff, but to the Old English word 'head.'"-David Edge and John Miles Paddock, Arms and Armour of the Medieval Knight.
Which seems reasonable since one would expect his axe to be an axe... :)
Of course the definitions of any and all pole arms have always been a bit fluid I suppose. Do a lot of you all see a poll axe as often not having an axe blade?
Mon 28 Aug, 2006 1:16 pm
Hmm a little more online looking and I find Henry the VIIIs pollaxe armor supposedly displayed with a pollaxe...
Which I would have called a bec de corbyn.... curiouser and curiouser... it may be that I am merely a victim of our ancestors not bothering to get really very specific about things. A modern habit perhaps...
Mon 28 Aug, 2006 1:20 pm
A bec de corbyn is a form of poleaxe. I'll dig up further detailed info for you in about a week.
Posts: 354 Location: Dijon
Tue 29 Aug, 2006 3:20 pm
I lectured last October for the second IAAC in Vienna about the history of the poleaxe.
And I must say Nate is right :)
Even in the Burgundian treatise Le Jeu de la Hache, the weapon used has a hammer head, back spike (called bec de faucon) and top spike. Also, in the earlier Fior di Battaglia by Fiore dei Liberi, his Azza is of the same type. In Talhoffer too...
Same again, nearly all the poleaxes mentionned in the various Pas d'Armes that took place in Burgundy in the XVth century were of the 'hammer' type.
Fab
Posts: 616 Location: Atlanta Ga
Sat 02 Sep, 2006 5:55 am
| Russ Ellis wrote: |
Russ, the correct term isn't pole axe. It's Pollax, which isn't english and roughy translates as 'head crusher' or some such. (Can someone here give us a better translation?)
But as we so often do, we have modified the term to modern english, 'pole axe' since that does describe what many of them were. The term pole axe is a good term, but we should know the root isn't the same term.
Posts: 634 Location: UK
Sat 02 Sep, 2006 3:19 pm
Poll is english for head, as in poll tax, redpoll, polling etc.. Ax is english for axe (or a metathesis for ask, but the former version seems more probable in this context). As for not having an axe blade as we conventionally recognise it now, neither does a dagger axe. Maybe it was some reference to a 'nasty bit that you use at right angles to the shaft', or maybe they all started with axe heads and the name stuck when the blade didn't. We still call people plumbers, though copper and plastic have long since replaced lead.
Geoff
Edit: and then there's the pickaxe ............
Sat 02 Sep, 2006 8:28 pm
| Al Muckart wrote: |
| George Hill wrote: |
root isn't the same term. |
Fascinating. Do you know which language pollax comes from? |
Er, Strike that, it is English, but it's old or middle Engish, which isn't like modern English.
Bear in mind that "ye olde whatevere" isn't old, but middle English. Middle is much MUCH closer then old.
You
cannot post new topics in this forum
You
cannot reply to topics in this forum
You
cannot edit your posts in this forum
You
cannot delete your posts in this forum
You
cannot vote in polls in this forum
You
cannot attach files in this forum
You
can download files in this forum
