Elling Polden
Posted: Fri 15 Jul, 2005 8:30 am Post subject: |
Again, there is confusion over terms.
There are two kinds of padded garments;
A padded garment worn under plate or mail, often reffered to as an Arming Coat
and the independent cloth armour; Acceton, Jack, gambeson... I don't speak medevial french, so I really can't tell what is more correct. Its called Panzar in medevial norwegian...
A picture of cloth armour, in the macieowski bible, ca 1250 (http://www.medievaltymes.com/courtyard/maciejowski_images_27.htm):
A regular man-at-arms would be more likely to wear cloth armour than mail, mainly for reasons of cost. Mail is however predominant in the illustrations, because it's cooler.
Both will do, of course. But you should in any case have a arming coat under the mail...
Joe Fults
Posted: Fri 15 Jul, 2005 8:38 am Post subject: |
So here's an oddball question.
All this wool, how do you keep from scratching yourself to death?
Thomas Hoogendam
Posted: Fri 15 Jul, 2005 9:12 am Post subject: |
Elling Polden wrote: | Again, there is confusion over terms.
Both will do, of course. But you should in any case have a arming coat under the mail... |
Thanks Elling, that cleared up a lot.
Gordon Clark
Posted: Fri 15 Jul, 2005 9:30 am Post subject: |
Joe Fults wrote: | So here's an oddball question.
All this wool, how do you keep from scratching yourself to death? |
Linen under, wool over, so it is not too bad. If you are allergic to wool, however - it might be pretty scratchy.
Joe Fults
Posted: Fri 15 Jul, 2005 11:06 am Post subject: |
Gordon Clark wrote: | Joe Fults wrote: | So here's an oddball question.
Linen under, wool over, so it is not too bad. If you are allergic to wool, however - it might be pretty scratchy. |
Not too bad?
Elling Polden
Posted: Fri 15 Jul, 2005 11:50 am Post subject: |
Or, you just make sure to have finely woven wool. The wool you use for for instance hose is comparable to the one used to make suits. Rough linenen actually itches more, so be careful to get a reasonably soft fabric...
Personally, I never had problems with itching. But it can get a bit hot after a while.
Gordon Clark
Posted: Fri 15 Jul, 2005 12:32 pm Post subject: |
Joe Fults wrote: | Gordon Clark wrote: | Joe Fults wrote: | So here's an oddball question.
Not too bad?
Well, I can wear wool dress pants without any discomfort - some people can't. If they can't do that, I would not recommend living in wool for a weekend. Also quite temperature dependant - if it is over 70 degrees, I get a lot more itchy...
W. R. Reynolds
Posted: Fri 15 Jul, 2005 7:40 pm Post subject: |
I do 15th C. and have worn woolen hosen in all kinds of weather hot and cold without discomfort. When I first started this game I thought wool would be terrible, especially since I don't od heat very well. Properly constructed period clothing is no worse in hot weather than modern clothes. Elling is right, it has to be a finely woven wool if it is going to be worn next to the skin with any degree of comfort. Be sure you pre shrink it if you are going to try and do it yourself. Google medieval hose and search through the sites. There is plenty there that will help you.
Bill
"No matter who wins the rat race.......they are still a rat."
Bob Uhl
Posted: Sat 16 Jul, 2005 2:46 pm Post subject: |
Joe Fults wrote: | All this wool, how do you keep from scratching yourself to death? |
Believe it or not, good wool's really not all that scratchy. Some wools are very soft and pleasant--others aren't so much so. Sure, Army wool blankets are scratch fests, but one can get used to even that.
And after having worn linen and wool, I never want to wear cotton again, and I never will wear polyester or nylon anything again. Synthetic fibres are less than worthless: they're actively bad.
Joe Fults
Posted: Sat 16 Jul, 2005 9:12 pm Post subject: |
Bob Uhl wrote: | Joe Fults wrote: | All this wool, how do you keep from scratching yourself to death? |
And after having worn linen and wool, I never want to wear cotton again, and I never will wear polyester or nylon anything again. Synthetic fibres are less than worthless: they're actively bad. |
So the trick is to get the right wool.
Fine weave then.
Bob Uhl
Posted: Sun 17 Jul, 2005 11:39 am Post subject: |
Joe Fults wrote: | So the trick is to get the right wool. |
Yup.
I don't think that it's the weave so much as the thread used in the weaving. But a very fine weave will probablt use good, soft threads.
Chuck Russell
Posted: Mon 18 Jul, 2005 5:07 am Post subject: |
Not too bad?
if your wool is super scratchy it isnt 100%. that is the KEY! 100% wool isnt as nasty as people think. i thought the same thing when i started in 15thc. ug wool hosen i'm gona be raw. but i was not and it was cooler than shorts would be.
Gordon Frye
Posted: Tue 19 Jul, 2005 5:58 pm Post subject: |
Chuck Russell wrote: |
if your wool is super scratchy it isnt 100%. that is the KEY! 100% wool isnt as nasty as people think. i thought the same thing when i started in 15thc. ug wool hosen i'm gona be raw. but i was not and it was cooler than shorts would be. |
My own experience is that any wool is very good to wear next to the skin if the temperature is low... but as it gets higher, the greater the need for finer weaves of wool. But I've certainly worn LOTS of woolen trousers in hot weather with no real discomfort, and in fact wool is MUCH better at wicking away the sweat from your legs than cotton jeans are! Yuck!
I have to agree on synthetic fibres being a tool of the devil though... that stuff is indeed BAD for you, especially in hot weather! Give me heavy woolens in the heat over synthetics, at least those woolens will absorb sweat and turn your clothes into a swamp cooler, LOL! Hot , but at least your skin is still breathing.
Gordon
Gonsalo Jimenez de Quesada
