I have a question about Albion's Next Generation Viking blades:
How is the transition from blade shape to tang shape made? This transition is clearly seen on Gaddhjalt blade, where the fuller is narrower than the tang.
But it seems the transition is a bit different on other Viking blades with fullers almost wider than the tang.
Fuller ends much more abruptly, or it would be seen on the tang even more. And it seems to me that the blades are inset into the cross quite deeply, otherwise the fuller would weaken the tang too much. Below is my guess of the fuller length and shape of the blade inside the cross of Gotland sword. Green lines represent shape of surviving swords (as far as I know), and the red lines the shape that I think Albion blades have. Can we have some info on that, or maybe even a photo of a blade without the cross?
I don't know, blade with fuller that runs under the cross looks hm, great IMHO, but the engineering part of me screams "This is the weakest part of the blade, isn't there anything that can be done to strengthen it?"...
Gaddhjalt blade, fuller is narrow and it runs quite deeply into tang
Gotland sword, my guess of blade & fuller shape inside the cross.
