Posted: Sat 22 Feb, 2020 4:05 am Post subject: |
I encircled the part where I see the pattern welding if that helps anybody...
Attachment: 122.91 KB
Tyler C.
Posted: Tue 25 Feb, 2020 8:17 pm Post subject: More pictures and a some new information! |
I have just found that on the back of the blade there is a simple design cut into the flat. There is a large perpendicular cut which is immediately obvious, but on closer inspection there are other cuts behind the large cut (closer to the handle) that from a cross between two lines, and other lines that extend forward from the larger cut. I highlighted these cuts in the pictures below.
I have seen similar designs on the back edge of seax blades. Could this be evidence to support the idea that this could be a repurposed seax, or are similar designs found on medieval blades too?
Attachment: 70.43 KB
Back of blade with cut designs.
Attachment: 69.57 KB
Back of blade with cut designs highlighted.
Attachment: 146.71 KB
Back of blade with cut designs. Large [ Download ]
Attachment: 143.14 KB
Back of blade with cut designs highlighted. Large [ Download ]
Mikko Kuusirati
Posted: Tue 25 Feb, 2020 8:55 pm Post subject: |
It could easily be post-Medieval, too. Might even be Scottish - not the stereotypical Victorian dirk, but some older styles feature organic hilts with blades exactly like this.
Mikko Kuusirati
Posted: Sat 29 Feb, 2020 2:46 am Post subject: |
BTW, here's one example of 18th Century twisted steel with a similar pattern: http://www.oriental-arms.co.il/item.php?id=3837
Sean Manning
Posted: Mon 02 Mar, 2020 10:52 am Post subject: |
The other thing which occurs to me is that a full-length whittle tang peened over a washer is a relatively fancy feature, most knives have just enough of a tang to anchor the blade in the grip. That supports the evidence of the blade shape that this dates sometime after 1300.
I get the impression that there were a lot of 14th century hilts carved or turned from wood/horn/ivory which don't fit nicely into our categories.
www.bookandsword.com
Tyler C.
Posted: Tue 03 Mar, 2020 6:09 pm Post subject: |
Sean Manning wrote: | The other thing which occurs to me is that a full-length whittle tang peened over a washer is a relatively fancy feature, most knives have just enough of a tang to anchor the blade in the grip. That supports the evidence of the blade shape that this dates sometime after 1300.
I get the impression that there were a lot of 14th century hilts carved or turned from wood/horn/ivory which don't fit nicely into our categories. |
Sean, I imagine you are right, but I have not seen any examples of 14th century blades that would fall into the 'other' category. Do you know of any examples?
Sean Manning
Posted: Thu 05 Mar, 2020 11:26 am Post subject: |
Tyler C. wrote: | Sean, I imagine you are right, but I have not seen any examples of 14th century blades that would fall into the 'other' category. Do you know of any examples? |
Hi Tyler,
the Fashion in the Age of Datini page for Knives (Fighting) will get you started.
Tyler C.
Posted: Thu 19 Mar, 2020 8:30 pm Post subject: |
Hi Tyler,
the Fashion in the Age of Datini page for Knives (Fighting) will get you started. |
Sorry about the hiatus.
Sean, That is a great resource! Thank you for posting. It really got the gears turning to see the many variants pictured.
Before I started this thread I thought I had seen a lot of rondel and bollock daggers. Since my last post I have been scouring the internet and books for every picture and bit of evidence that I can find. Still no examples of similar daggers with pattern welding, but after considering the many possibilities I think that the blade form makes the most sense combined with a late 14c style bollock dagger handle. There are certainly many other options that I think could also be plausible, but bollock won out in my mind. Here's a very quick sketch I did to visualize it. Time to get working on the recreation I suppose .
Attachment: 33.3 KB
Bollock handle.
