Matthew Bunker
![](images/avatars/10670347205a63c7172f251.jpg)
Posted: Fri 04 Mar, 2016 12:31 am Post subject: |
Kristjan Runarsson wrote: | [
If you have no facing, putting reenforcing bands on the back and making the shield "double boarded" i.e. plywood as specified in the Gaulažing laws will do more to keep it together in the event of a blow that would have split a singe boarded shield than a rawhide rim. Hurstwic did some shield tests and posted the results on their page:
I've read the Gulatingsloven, and whilst it does specificy that a shield should have three iron bands to reinforce it, I can find no reference to the practice of 'double boarding' or painting shields red...every reference to this that I have found is online and points back to the Hurstwic site.
Hurstwic themselves state that it's from a 'later revision' ...does anybody know what that is, because the version that I've got is based on the 11th century laws?
Anything post that is irrelevant to a discussion on Viking Age shields so I'm not sure why Hurstwic include it.
Viktor Abrahamson
Posted: Fri 04 Mar, 2016 12:53 am Post subject: |
Regarding rims on the shield, this picture shows some edge clamps from Birka shields.
Look at 5b, the description say it is a wood core faced with leather on both sides, and a leather rim under the metal clamp.
Abe Zettek
![](images/avatars/13036672554a023a3b99c09.gif)
Posted: Tue 13 Nov, 2018 10:18 am Post subject: |
Interesting topic! In regards to:
The grave shields from Gokstad in Norway had rim holes but they may also have been built specially for the burial because their plankswere painted. Thus they cannot have had a facing since if they had one the decor would have been painted onto the facing and not the wood planks.Therefore these shields cannot be considered representative of combat shields. There is evidence of leather shield facing from Birka and from Anglo-Saxon Britain... |
I should mention that there was an article written, from Sweden I believe, that mentioned animal 'gut' being used to face a shield find. This might not have been in a viking context, but I think it was - I will try to find it to reference here.
There was some confusion with the translation as to whether it was stomach or intestine being referred to, but in either case those materials are usually very thin and - depending on preparation - almost completely transparent.
This means that a shield may have been painted or otherwise decorated directly onto the wood, yet still have the advantages that a thin facing offers, as discussed in this thread.
I have not seen anyone use 'gut' on a shield in this way in a modern context, but if anyone knows of an example, please post it!
Sounds like I just gave myself a new project...
Kristjan Runarsson
Posted: Tue 13 Nov, 2018 10:55 am Post subject: |
Abe Zettek wrote: | Interesting topic! In regards to:
Sounds like I just gave myself a new project... ![Wink](images/smiles/icon_wink.gif) |
Until more evidence presents itself I've concluded that these shields were mostly similar in construction to the heater shields during the later middle ages based on the hypothesis that they changed the shape of the shields but not the basic method of construction. These later medieval shields were made of butted planks glued together on the edges just like the viking age ones. They had a rawhide facing front and back, not the manuscript parchment some people use, but rather the nice thick tough stuff they use for doggy bones. Also I am not of the opinion they used tanned leather which is soft as opposed to rawhide which becomes tough, kind of like that plastic they use for cutting boards, when it is dry and takes hours of soaking in water before it becomes soft and flexible. The rawhide would have been glued on or just fastened with a pattern of nails like it is on many of the surviving heater shields. The the front facing overlapped the edge onto the back and was probably either nailed or sewn in place with rawhide strips or sinew. There are also a few other variations I'm open to such as plywood construction, lenticular shields, and fabric faced shields. There is also some surviving evidence (that I cannot pinpoint at the moment) that suggests that at least some viking age shields may have had a layer of gesso or something similar applied to the front, over the rawhide, which was then painted. The designs appear to have ranged from simple 'slice' or 'swirl' designs in two or more colours to pretty complex pictorial designs.
M. Oroszlany
Location: Czech Republic / Slovakia / Hungary Joined: 12 Jan 2009
Posted: Wed 14 Nov, 2018 3:27 am Post subject: |
Very interesting read. I'm also thinking about constructung a viking style shiled of my own, and it's really hard to find reliable information. I have some questions that I couldn't find answers to, so I guess I might as well ask them here.
We see in a lot of depictions longships, with a row of shields hung on the outside, and archeological finds seem to support the idea that shields used to be hung on the outsides of ships. This suggests to me, that the shields were somehow made waterproof. How would you achieve this with period materials?
The planks can be glued together with casein glue, which is water resistant, and the iron bits will last quite a while before rusting away, so the basic construction is not really a problem. Casein glue doesn't stick well to anything other than wood though, so the rawhide facing must have been glued on with some kind of hide glue or fish glue I suppose, which is not water resistant at all. (maybe pine sap?) Rawhide itself would stand up to a little bit of rain, but it soaks through fairly fast. Paint or gesso as suggested in the previous post is as water resistant as the binder used, which is probably not very much. A liberal amount of grease on top of it all would pretty much solve the issue, but then you wouldn't really want to wear the shield slung over your shoulder I guess, so it doesn't stain your clothing. Any ideas?
The other question I have is about the bosses. I've read and heard in several places, that the surviving historical bosses were a lot thinner than what's commonly used for reenactment shield bosses, but I can't find any actual measurements. The reenactment boss I bought is 2mm mild steel, and I don't think I could put much of a dent in it with a sword or a spear, maybe a bit of a dent with an axe, but some historical bosses show quite extensive battle damage right through the ages. Anyone knows where I could find accurate data about the actual viking era finds?
![](images/avatars/702889275502f42e10c850.jpg)
Posted: Wed 14 Nov, 2018 1:37 pm Post subject: |
A shield is going to get soaked in water regardless of whether it is outside or inside the ship.
Casein glue isn't waterproof; it is water resistant and salt lowers that resistance even more.
M. Oroszlany
Posted: Thu 15 Nov, 2018 5:59 am Post subject: |
Well, yes, that was kind of my point, it seems extremely impractical to keep your shields from getting wet on a sea voyage in an open ship, or on the march if it's raining. It also seems quite improbable to have shiploads of norwegian vikings disembark in Ireland only to find out they are unable to fight the local militia that scrambles to meet them, because their shields fell apart on the way. Both Scandinavia and Britain see a fair share of rain throughout the year, so in my fairly strong opinion, there had to be a way to make these shields to some degree waterproof.
Posted: Thu 15 Nov, 2018 1:18 pm Post subject: |
Why? Instead of relying on glue, all you need is some nails - just like the ship itself. In the ship's case, the wood needs to be wet so that it can swell and tighten the joints. This swelling might prove beneficial for shields too. Keep in mind that a shield was only meant to last for a few seasons and to be repaired after every encounter. Re-enactors tend to over-build everything because they don't want the hassle and expense of routine maintenance and regular replacement of their kit.
M. Oroszlany
Posted: Fri 16 Nov, 2018 1:47 am Post subject: |
Because nails other than the ones holding the boss/handle are just not really present in any period finds as far as I know.
Graham Shearlaw
Posted: Fri 16 Nov, 2018 5:28 pm Post subject: |
Metal nails where expensive, not outlandishly so but shield finds only have a dozen nails or so.
Shields where semi disposable, duels give people three shields so clearly there not expecting one to last.
And that's in single melee combat, in a battle with arrows and javelins flying you might have all sorts of damage.
Philip Dyer
Posted: Fri 16 Nov, 2018 8:44 pm Post subject: |
M. Oroszlany wrote: | Because nails other than the ones holding the boss/handle are just not really present in any period finds as far as I know. | iron was relatively expensive back then and nails are super useful, I wouldn't Ben surprised of the metal parts of a shield were recycled over and over again. Nails would definately get this treatment because nails can used for a ton of different items.
Sean Manning
Posted: Sat 17 Nov, 2018 1:10 am Post subject: |
I am not an expert on European plank shields, but they appear at hundreds of sites across more than a thousand years and I do not know any which had traces of nails joining the plans to one another, and usually the nails survive better than the board.
M., I would write to people and groups like Hurstwic and Roland Warzecha and ask for a reading list on Viking shields.
www.bookandsword.com
Sean Manning
Posted: Sat 17 Nov, 2018 2:22 am Post subject: |
And here is a post by Roland Warzecha with specifications for one 8th century boss from Saxony https://www.patreon.com/posts/thickness-of-22696471
Getting real information requires either borrowing a lot of technical archaeological reports in different languages, or talking to people like Roland who visit museum back rooms and measure finds.
Graham Shearlaw
Posted: Sun 18 Nov, 2018 11:25 am Post subject: |
I'm just thinking here but surely nails have a risk of spitting the wood and with the thinner wood by the edges even more so.
M. Oroszlany
Posted: Mon 19 Nov, 2018 2:46 am Post subject: |
Thanks Sean, that's a very interesting link. I'm not a historian or archeologist, so I unfortunately do't have the connections to get access to archeological records, so it was very useful.
