Michael Curl
Posted: Fri 19 Jan, 2018 4:40 am Post subject: Speed of projectiles upon impact. |
Hello all,
I am doing some research for a hypothetical pre-gunpowder weapon (fiction work) and was wondering how fast something like an arrow or javelin might be travelling when it impacts its target. For reasons I don't want to go into, the initial velocity doesn't matter, but I am looking for final velocities right before impact by various missile weapons. I have a reconstruction of a sharp weapon which would hit the target at 32mph and I need to now if that is fast enough to actually do anything. It weighs 75-110g by the way.
Thank you all for your input.
E Pluribus Unum
Lin Robinson
Posted: Fri 19 Jan, 2018 5:05 am Post subject: |
If you want actual data, try using a modern chronograph setup to register the speed of the missile at the point of impact. That will be difficult unless the weapon is extremely accurate or you can fire it accurately enough to put it through the field measured by the instrument. Chronographs used to be terribly expensive but over the years cost has come down dramatically. I am also uncertain as to the ability of the chronograph, ordinarily used to record the speed of bullets, to pick up other kinds of projectiles. If you have a trusting friend who will loan you a chronograph to try before you buy, that would be helpful.
Lin Robinson
Tom King
Posted: Fri 19 Jan, 2018 6:13 am Post subject: |
you're talking a ~1100-1700 grain projectile going 47 feet per second /14 meters per second for a grand total of 5-8 ft lbs of kinetic energy
a standard ~300-320 grain arrow from a longbow will go about 150fps and have about 15 ft lbs of KE
http://archerycalculator.com/archery-kinetic-...alculator/
in comparison a modern hunting crossbow throws bolts with somewhere between 80-150 ft lbs of KE and a compound bow throws arrows with 60-80 ft lbs of KE.
Timo Nieminen
Posted: Fri 19 Jan, 2018 3:29 pm Post subject: Re: Speed of projectiles upon impact. |
| Michael Curl wrote: | | I have a reconstruction of a sharp weapon which would hit the target at 32mph and I need to now if that is fast enough to actually do anything. It weighs 75-110g by the way. |
That's about 10J of energy. It won't go through armour (compare with the 100J arrows used, often unsuccessfully to try to pierce armour). It's enough to go through skin, as long as the geometry and motion suits, and the "sharp" is sharp enough.
10J is enough to be dangerous to bare flesh. Under 1J will put a point through skin. 10J can put a knife point through ribs. But this isn't as dangerous as fast arrows, heavy throwing knives, etc. Your weapon sounds like a shuriken or a hand-thrown heavy arrow, or a hand-thrown light knife.
Try it on a suitable target. I grabbed a junk 6" boning knife (a junk knife from a junk knife set) and tried throwing it. Probably not as fast as your mystery projectile. It will penetrate 5" into soft ground easily. If you have something that sort-of matches your intended target, and something to throw with about the same point/edge geometry as your weapon, you will very quickly find out whether it might be effective.
Further reading:
https://arxiv.org/abs/0811.3955
https://www.ncbi.nlm.nih.gov/pubmed/27503509
Michael Curl
Posted: Fri 19 Jan, 2018 4:01 pm Post subject: |
Damn, sounds like it is barely within the range of usability. For those interested, I'm writing a novel and the story is set in a stone age aquatic setting. The weapon is powered by buoyancy, and is basically a buoyant plumbata that's about two feet long. I have found some buoyancy calculations and got the weapon travelling at 32mph. One of the neat things about it is that buoyancy doesn't run out like the force of an arrow or javelin would, so the "torpedo" will travel at 32 mph over its whole trajectory. (Technically the buoyancy will get better as it approaches the surface as the water pressure weakens and the internal air expands to displace more water).
However this does sound like it is just barely acceptable as a lethal weapon. Admittidly armor is rare-ish (think aztec instead of medieval) and metal is non-existant, so the thresholds I need are lower, but I'm not sure if this is enough. I am going to try to calculate another weapon which has more internal area for displacement, but now I have to find the volume of things like bowling pins and juggling bats! Thank you all for your help.
E Pluribus Unum
Timo Nieminen
Posted: Fri 19 Jan, 2018 4:16 pm Post subject: |
I'll be more dangerous than a thrown object of that speed and weight (and sharpness). As you say, it won't "run out" of force, while a thrown object is limited to the energy it has at impact. Your floater will keep exerting a force (as long as it's still underwater), even after it slows down after impact. This might not be enough to do anything useful. Try the experiment! Simulated point against simulated target (just in air, point above target). Put a weight on the point to push it down with a force equal to the buoyancy driving the "real" weapon upwards. See what happens.
Michael Curl
Posted: Sat 20 Jan, 2018 2:33 am Post subject: |
Interesting idea, I wish I had like a deep pool or something which I could try it in, I'd need like a scuba kit to do so, but I once got hit by a kick board that really took the wind out of me (we were holding them underwater and then releasing them horizontally, and the surface area prevented them from just rising so they launched underwater like a wing and would ram into people. (Dumb kid stuff).
Anyway, anecdote aside, I'm not sure how the continued pressure would do much, other than perhaps sustaining the penetration for longer during the initial push. The momentum would still be lost even if the propellant is still at work.
E Pluribus Unum
Peter Lyon
Posted: Sat 20 Jan, 2018 11:34 am Post subject: |
This is an interesting gag for the book (and I mean gag in the movie sense here).
A couple of considerations come to mind.
Streamlining will increase the speed; you don't need more bouyancy if the extra bulk becomes self limiting; a long, streamlined bag with a weight at the base to keep it travelling perfectly upright, and the spear or whatever at the upwards end. I don't know how fast it could go, but energy increases with the square (or cube?) of velocity, so a little extra speed makes for more punch. The deeper it is released the better, up to the point where bouyancy balances out with drag.
The weapon itself might injure or kill the opponent on its own, but there is another thing that could do the job. In humans, rapid depth changes by scuba divers cause air embolisms that can cause permanent damage or even death, so dragging the opponent to the surface could be nasty too. Technically it is nitrogen narcosis, where the nitrogen from air dissolved in the blood stream comes out of solution, so relies on air atmospheric mix and doesn't apply to all animals - whales don't have this issue and dive deep then come up fast. It may be related to continually breathing from a pressurised tank, so could be specific to humans doing scuba. Would these factors work in your world?
Still hammering away
Michael Curl
Posted: Sat 20 Jan, 2018 3:31 pm Post subject: |
Humans aren't around in my world but different species of fish are and the bends is something that happens with swim bladders, cuz rapid depth changes will cause them to rupture. So is your idea to have a buoyant net which will drag people to the surface?
My main problem with that idea (which I already am using) is that most sea life lives in shallow waters and so do most cities and so on, so deep water fights are going to be more like fighting in a dungeon. Happens all the time in roleplaying games, but pretty rare in real life. It's fiction so whatever the plot needs it'll get, but I am trying to work out as many reasonable weapons as I can in an aquatic setting. Besides for nets which are powered by weights/floats, I also have the torpedo (mentioned above), and bows (which are rare hunting weapons rather than proper combat weapons, and that's it besides melee weapons. However I am all ears.
E Pluribus Unum
Peter Lyon
Posted: Sun 21 Jan, 2018 11:02 am Post subject: |
A net would do it, but I had been thinking about the weapon itself (spear or whatever) hitting the opponent, sticking in, and also dragging them to the surface. Even if bends don't happen, your opponent has lost their ability to dive and avoid, and is in a lot of pain, so at a big disadvantage even if the weapon didn't disable them.
Michael Curl
Posted: Sun 21 Jan, 2018 6:40 pm Post subject: |
Ah, so a harpoon pilum hybrid. Head will be barbed obviously. Evil plan sir.
E Pluribus Unum
Gregory T Kallok
Posted: Mon 22 Jan, 2018 12:32 pm Post subject: |
I have tested this formula and it seems somewhat accurate for a longbow You add 115 fps "feet per second" to the bows draw weight. This is for an arrow length of between 28-30 inches. So I take my 90 longbow shooting a 30 inch arrow and add the 115 fps so.. 90+115 = 205 fps plus or minus 10 percent. This is a reasonable figure. Bare in mind the modern compound bows and crossbows are much different and generally shoot much lighter arrows faster then your typical longbow shooting a wooden arrow with a bodkin style step ahead..
Keep your nose in the Wind and your eye on the skyline.
Del Q
Eirik R. F.
Posted: Mon 22 Jan, 2018 2:35 pm Post subject: |
You could use the data from The Great Warbow on page 411. It's the only scientific experiment I know of measuring arrow speed at max distance. They used a Doppler radar.
I KE = Initial kinetic energy
MD KE = Max distance kinetic energy.
150 lbs bow, 33", 95.9 gram arrow
53 m/s = I KE 134.69 Joules
43.3 m/s = MD KE 89.9 Joules
Retained KE = 66.74 % ~ 67 %
Retained Velocity = 81.69 % ~ 82 %
Average range = 237.7 meters
150 lbs bow, 33", 86.6 gram arrow
53.55 m/s = I KE 124.167 Joules
43 m/s = MD KE 80.1 Joules
Retained KE = 64.5 % ~ 65 %
Retained Velocity = 80.29 % ~ 80 %
Average range = 233.6 meters
150 lbs bow, 33", 74.4 gram arrow
57.8 m/s = I KE 124.279 Joules
44.9 m/s = MD KE 75 Joules
Retained KE = 60.34 % ~ 60 %
Retained Velocity = 77.68 % ~ 78 %
Average range = 259.1 meters
150 lbs bow, 33", 57.8 gram arrow
62.25 m/s = I KE 111.989 Joules
48.3 m/s = MD KE 67.4 Joules
Retained KE = 60.18 % ~ 60 %
Retained Velocity = 77.59 % ~ 78 %
Average range = 297.5 meters
150 lbs bow, 33", 53.6 gram arrow
64.3 m/s = I KE 110.804 Joules
48.9 m/s = MD KE 64.1 Joules
Retained KE = 57.84 % ~ 58 %
Retained Velocity = 76.04 % ~ 76 %
Average range = 318 meters
150 lbs bow, 33", 108 gram arrow, 52 m/s = 146 Joules
If you make a graph of this you'll see that the 86.6 gram arrow is outside the graph because it was a "blunt" arrowhead. 53.55 m/s is too slow with a sharp arrowhead. It should be around 54 to 55.1 m/s or there about and 126.26 to 131.45 Joules and maybe around 44 to 44.5 m/s at max distance and around 83.82 to 85.74 Joules. This will give retained KE = between 65.22 and 66.38 % and retained velocity between 80.76 and 81.48 %.
60 Joules at max distance does not seem to be much, but it's equal to lifting a 6.8 kg (15 lb) hop bar/digging bar 0.9 meters above ground and letting it drop. This will crush ice and go into soft ground enough to not fall over.
mgh
6.8 * 9.81 * 0.9 = 60 Joules.
The bar will strike the ground at
Sqrt 2gh
Sqrt 2 * 9.81 * 0.9 = sqrt 17.658 = 4.2 m/s
It's also equivalent to a 20 oz (0.566 kg) hammer at 14.6 m/s.
Both the digging bar and hammer have more momentum, but the kinetic energy is the same.
Posted: Tue 23 Jan, 2018 6:35 pm Post subject: |
| Michael Curl wrote: | Damn, sounds like it is barely within the range of usability. For those interested, I'm writing a novel and the story is set in a stone age aquatic setting. The weapon is powered by buoyancy, and is basically a buoyant plumbata that's about two feet long. I have found some buoyancy calculations and got the weapon travelling at 32mph. One of the neat things about it is that buoyancy doesn't run out like the force of an arrow or javelin would, so the "torpedo" will travel at 32 mph over its whole trajectory. (Technically the buoyancy will get better as it approaches the surface as the water pressure weakens and the internal air expands to displace more water).
However this does sound like it is just barely acceptable as a lethal weapon. Admittidly armor is rare-ish (think aztec instead of medieval) and metal is non-existant, so the thresholds I need are lower, but I'm not sure if this is enough. I am going to try to calculate another weapon which has more internal area for displacement, but now I have to find the volume of things like bowling pins and juggling bats! Thank you all for your help. |
So If I'm visualizing the weapon correctly it would be some sort of spear with an inflatable or rigid floatation device that would push the released spear upward towards the surface ?
To use it one has to be below the enemy target and release it at the right time to intercept someone swimming above.
The trajectory would be also completely vertical except at very close range where it might be possible to aim at an angle.
Kinetic energy would be marginal unless very heavy but with a big enough buoyancy to compensate and reach your estimated 32 mph.
Now, one also has to be able to release these while already inflated, and if one was carrying many of them it might be difficult to not be dragged up when holding on to them ...... Unless one tied some heavy ballast around one's body, or they where secured on the bottom by rope(s) around a heavy rock or something, to be released by cutting the rope(s).
These might work defensively to protect the perimeter of an underwater settlement ?
I think that with questionable kinetic energy one must go with extreme pointedness and/or sharpness, and maybe enhanced by being poisoned at the tip so that even a scratch would be dangerous.
One could go in the reverse direction by having the flotation device near the surface holding a very heavy spear or even a heavy stone, and released by cutting a rope so that the spear, or stone, can travel down and pick up speed ...... I see these more useful if one thinks of them as traps or mine fields with some set up on the bottom to rise and other set up near the surface to sink.
I don't see then being that useful as hand weapons ?
