Forum Index > Historical Arms Talk > Measuring curved blades Reply to topic
Sam Arwas
PostPosted: Mon 11 Jan, 2016 7:43 pm    Post subject: Measuring curved blades         Reply with quote
I have found specifications listed by vendors to be highly unreliable and have decided that the only way to get reliable measurements is to do them myself. It's easy to measure straight blades because the distance between the base and the tip is the same as the total blade length. But it's not so simple with curved blades. Anyone know of a system/formula to get an accurate measurement?
J. Nicolaysen
Likes: 31 pages
PostPosted: Mon 11 Jan, 2016 8:38 pm    Post subject:         Reply with quote
Here's how to do it on a Japanese sword. http://www.japaneseswordindex.com/measure.htm
The same method applies to other curved swords, but the terms will be different.
Glen A Cleeton
PostPosted: Mon 11 Jan, 2016 8:46 pm    Post subject:         Reply with quote
Curved blades are generally measured from the guard to the point in a straight line.
GC
Sam Arwas
PostPosted: Mon 11 Jan, 2016 9:12 pm    Post subject:         Reply with quote
GC
But would it not be somewhat misleading to describe the blade length as such?
Nat Lamb
PostPosted: Mon 11 Jan, 2016 9:37 pm    Post subject:         Reply with quote
Only if you think it is misleading to describe a persons height not taking into account the curvature of their spine.
If you were talking about the length of the cutting edge, then yes, you would measure differently (and from memory that is a measurement taken for nihonto) but that would be different from the blade length for straight bladed swords as well (and flammmards would be a nightmare to discuss).
Andrew Gill
PostPosted: Tue 12 Jan, 2016 12:52 am    Post subject:         Reply with quote
GC
Remember that from the perspective of someone who would use the sword in a life-and-death confrontation, the distance at which you can cut or stab with the sword is what is important - not the exact length along the curve of the blade, which is unlikely to have as large an effect on one's ability to use the weapon.
