Forum Index > Off-topic Talk > Question about broken sword Reply to topic
Angel Vasilev
PostPosted: Mon 28 Sep, 2015 7:15 am    Post subject: Question about broken sword         Reply with quote
At least i think may be broken...
when i hit the pommel and the blade starts to shake, the sword starts to make one sound like there is something loose...whole handle was moving and the pommel...
so i glue it up with resin. the pommel and the handle to the cross guard is glue up with resin
but still something sounds like loose. around the cross guard
it is possable to tang be broken somewhere at the middle of the handle and still holds up?
Gabriele A. Pini
PostPosted: Mon 28 Sep, 2015 8:36 am    Post subject:         Reply with quote
I would suggest to not use it anymore. Can you post some photos?
Angel Vasilev
PostPosted: Mon 28 Sep, 2015 9:35 am    Post subject:         Reply with quote
its a hanwei hand and a half sword
he makes a sound of something loose around the guard. Because i glue it up only outside the handle. and inside may be is still have space between guard and the blade. But i am not sure . i need to cut the wooden handle to see...
Strange here , is when i put the sword on the ground and hold it in my hand with his point on the ground...he don't make sounds of loose parts....
Jeffrey Faulk
PostPosted: Mon 28 Sep, 2015 10:19 am    Post subject:         Reply with quote
If this is an old Hanwei, like this model:
http://kultofathena.com/product.asp?item=SH2365
Then I would not have used it much to start with!
This is a much better and more reliable product:
http://kultofathena.com/product.asp?item=PC2034
Either way however if the blade is able to move, that means your tang is almost certainly severed at some point within the handle. It should not be considered a functional sword in any sense and be restricted to display only unless you can disassemble it and have it properly welded together by an experienced metal-worker.
Angel Vasilev
PostPosted: Mon 28 Sep, 2015 10:42 am    Post subject:         Reply with quote
the model is from 2013 or 2014 i both it at begining of this year
is this one
http://www.theknightshop.co.uk/catalog/practi...34227397fb
maybe is not broken just have space between cross guard and the blade inside the handle, if the tang is broken i thing the blade will fall off. i dont know.
but still i hope is not broken,
