S. Andrew B.
Posted: Mon 31 Aug, 2015 8:06 pm Post subject: Heater Shields, Planks or Plywood? |
Hello all,
I'm getting ready to build a jig to make my heater shield and I've found two good-looking sites, and I'm wondering which method of construction is more historically accurate for around 1320-1350.
This one http://www.yeoldegaffers.com/project_shieldpress.asp from Gaffers uses plywood, while this one I found over at the Armour Archive http://forums.armourarchive.org/phpBB3/viewto...p;t=167321 uses butted planks, and uses Der Mittelalterliche Reiterschild as reference.
Is there any historical evidence to support the use of plywood? Or is that a modern convenience?
Thanks all!
see you space cowboy...
Mart Shearer
Posted: Mon 31 Aug, 2015 9:34 pm Post subject: |
Medieval shields use planks. Plywood is a modern convenience. Some of the Roman scuta from Dura Europos used plywood construction and leather facings, though. You might want to search for: Hilary and John Travis, Roman Shields.
Jeffrey Faulk
Posted: Tue 01 Sep, 2015 7:47 am Post subject: |
If you want to be strictly historically correct, use butted planks. Some shields use 2 or even 3 layers of (very thin) planks, set cross-wise to each other; this can be viewed as a historic form of plywood. 1 layer is the norm though from what I understand, generally reinforced with heavy cloth or leather.
Plywood is used nowadays because it's simply easier to use. As long as you're only bending it in one direction, it's absurdly easy to construct a press, slather some glue and press a couple of layers together. Butting planks together in a *curve* is more complicated than doing so in a flat plane and requires some woodworking expertise; a shield press can be made with less. You can also 'mass produce' with plywood if you are so inclined, as the press is basically a form on which you can reproduce the same basic shape as often as you like (as long as the press lasts anyway).
A press does represent a certain investment though, which is the downside for most people if you're only making one or two and don't expect to make more anytime soon.
Mart Shearer
Posted: Tue 01 Sep, 2015 9:43 am Post subject: |
You could always go to your nearest barrel maker......
S. Andrew B.
Posted: Tue 01 Sep, 2015 11:23 am Post subject: |
Thanks, everyone.
The decision is made, I'll be going the plank route. That was the notion I had for how these shields were constructed to begin with, but then I saw how neat that plywood press looked. At any rate, I have a fair amount of woodworking experience so this shouldn't be too difficult. It looks rather fun in fact.
I think I'll reach out to Gerhard von Liebau over at the Armour Archives and see if I can get more detailed information on how he constructed his press.
Craig Peters
Posted: Wed 02 Sep, 2015 9:41 pm Post subject: |
Would someone mind sketching the assembling of a shield from butted planks? It doesn't need to be the whole process of shield making; just showing the planks being placed together in shield shape would be fine. It would help me, and others, better visualize this process.
Mikko Kuusirati
Posted: Thu 03 Sep, 2015 1:53 am Post subject: |
Well, Liebau's thread over in The Armour Archive (already posted by Andrew in the opening post) has photos of the whole process, including that part.
You don't actually assemble the planks in shield shape, it would just be needlessly tricky; you glue them together into one large piece of wood first and then measure, draw and cut the shield shape out of that.
Gregory J. Liebau
Posted: Thu 03 Sep, 2015 3:58 pm Post subject: |
Hey Andrew,
I'm glad you've found some use from my step-by-step. I literally just typed a long message about how the shield press was constructed, and then I went and looked at the photos of the press... The description was way more confusing than the photos, so I'll let you ask particular questions in order not to muddle things up. What part of the construction process are you interested in knowing more about? Honestly the photos show just about all of the details. I used oak floor panels for the tension boards on either side of the press, which were very strong and took a lot of pressure (that being ideal).
Cheers!
-Gregory
