Thrand Godfrey
Posted: Sun 02 Aug, 2015 1:40 am Post subject: The Sword Cast Blow compared to Spear Overarm Slide! |
I did a video comparing Roland Warzeca's Historical researched Cast blow with Viking age and Migration period sword designs to my concept of the Overarm throwing slide with one handed spear. The techniques are very similar in generating power from weapon acceleration and extreme power at that. If anyone has references to these techniques historically through ancient text depictions art work or even modern surviving combat forms that or historical based please post here.
Here is the Video of my test cutting and thrust comparing these too reconstructed techniques That I and Roland believe were commonly used historically.
Roland Warzecha's Cast Blow Sword Technique Similar to Thrand's Overarm Slide Spear Technique?
https://youtu.be/y8tmoTu_8AA
I am a arms and armour tester and experimental archeologist trying to rediscover ancient and medieval combat methods and tactics.
Thrand Godfrey
Posted: Mon 03 Aug, 2015 9:40 am Post subject: |
Has any one else tested these techniques or have references to their use historically?
Stephen Curtin
Thrand Godfrey
Posted: Mon 03 Aug, 2015 9:52 am Post subject: |
Thanks I will check it out now
Herbert Schmidt
Posted: Mon 03 Aug, 2015 10:40 pm Post subject: |
This is not really new. There is pictorial evidence, some of which you showed yourself in your video.
It is, however, only part of the story. We know from later sources that you change your grip constantly when using a sword. This is equally true for one handed swords as for swords gripped with both hands.
Unfortunately we don't have any Fechtbücher for the early middle ages when these swords would have been in use.
So we really don't know how they used it, all we can make are educated guesses.
I think that this way of holding the sword and "throwing" a strike was done but it was only one of the many ways it was gripped and used, as in later periods.
But it is good to have at lease one, isn't it.
www.arsgladii.at
Historical European Martial Arts
Thrand Godfrey
Posted: Tue 04 Aug, 2015 12:58 am Post subject: |
Herbert Schmidt wrote: | This is not really new. There is pictorial evidence, some of which you showed yourself in your video.
But it is good to have at lease one, isn't it. |
I my self use many different grips and proficient with all of them. This is not about one grip but how the sword was designed to be used and what was most common for the era and sword types. I believe all cuts and grips were know but only a few would be most commonly used with certain sword types and shield types, although all will work or can be applied. The Large center grip flat round denoted a certain type of use so the sword would have to comply with that fighting style. It changed as shields and styles changed to more of a sword fencing style. the early shields were the primary defense. I will do a video of other common grips that can be useful in transitional cuts with Viking and migration era swords and I believe were used as well.
