The Sempach is a late Medieval long sword made by Albion. Its a long, heavily tapered sword that's primary purpose would be to thrust and stab. According the Albion Europe's website its usage would have fell in the period 1355 to 1425 when armor began advancing to include a lot more plate. Doing damage to a heavily plated soldier with a sword primarily designed to cut was probably not the best tool. Swords that are stiff and with excellent points designed to puncture gaps in armor became more and more prominent. The Sempach is an excellent and classic example of such sword types.
Purchasing/shipping
The sword was purchased directly from Albion and arrived in the usual Albion white box with no issues.
Specifications
Overall length - 45 5/8"
Blade length - 36"
Blade width at cross - 1 3/4"
Grip length - 6 3/4"
Weight - 3 lbs (from Albion's website)
POB - 4 1/2"
Blade
This blade is very stiff. It's classified as an Oakeshott XVII and has a very interesting hexagon cross section. The first 1/3 of the blade starting from the cross has a well defined fuller that terminates softly into the flat hexagon section of the blade. From that flat section the edge bevel drops down to the edge proper with no secondary bevel. The sword came sharp and the edge is very nice and extremely clean. The overall profile has a significant taper, is of a basic triangular profile with long straight edges all the way to the point where it finally turns to a slight convex curve to the point for the last few inches. The last 1/2 inch of the tip shows the flat of the hexagon section turns into a diamond. The Sempach has a very stout tip. It reminds me of an ice pick, not so much the shape but the design of it in relation to its purpose. This tip I am pretty confident could easily punch holes.
Grip
The grip is in Albion's red and is very nicely done. The seam can be seen and does wander around a bit. Some other Albions I own have less visible seams. Also there is some dark almost black colors around the seam area, most likely from the gluing process. The seam cannot be felt. Overall I like the leather work on the grip quite a bit. The seam area which you could argue is not pristine visually does not detract much at all from the sword and is not anything I would consider a big deal. Its plenty long, especially with the pommel shape to achieve comfortable two-hand usage.
Pommel
The pommel is probably an Oakeshott type T2. It is in the scent stopper family of pommel types and has a lot of interesting facets and faces to it. The very bottom where the peen is has several decorative cutouts or grooves. The peen is excellent and is almost invisible.
Cross Guard
The cross is of octagon cross section and is slightly down turned. Its widest at the blade and flares slightly towards the ends. The blades slot is excellent and with in extremely tight tolerances to the blade.
Performance
The sword feels good in hand. It feels quick but it does not float. There is a considerable amount of blade presence for a sword with such a radical profile taper. It certainly feels like a sword meant for fairly heavy work. The distal taper is not nearly as aggressive as what I have seen on some earlier types made by Albion. This makes sense when you are trying to achieve a sword that remains very stiff in order to increase its effectiveness in the thrust. That blade thickness makes for a sword that while thin in profile section, still has a substantial amount of steel present all the way along its length and that amount of steel translates to a sword that has good blade presence. I did not cut with the sword so can't comment on its cutting. It feels lively overall.
Overall
I like this sword a lot. For me personally it is a departure from the area of interest most of my collection fits which are earlier, more dedicated cutter type swords. This is a very interesting sword. The blade geometry and the pommel are the highlights for me. Both are visually very interesting with various facets and angles that taken as a whole make for a really elegant longsword but in hand that elegance starts to fade as you realize that this stiff and thick blade was designed with some serious brutality in mind. When in hand it feels great but I can't help also feeling like this is a seriously specialized tool, a tool, like an awl or ice pick that is designed to puncture and stab.
