Never base a purchase, especially a substantial one like this, on one person’s opinions. Read many, watch many and try before you buy if you can.
Intro:
Darksword Armory, a few months back, asked for people to help review some swords due to controversy in some circles with their products and business practices. I try to stay removed from drama as much as possible, so I contacted them and said I was interested with the caveat that I could not keep the sword and I would be sending the sword back in pieces, if they were all right with that, than I would love to take part in a review. They sent me their “Dark Knight Sword” (reviewed elsewhere on this site). The starting price point for this sword which they call their “Black Knight Sword” is $360.00 (US).
A brief telling of who I am before I being: I have been involved in WMA/HEMA for ten years, over the years I have handled A LOT of swords, both high end custom pieces, as well as low end cheap pieces all the way to originals (composites and 100% original). My passion in this study and collecting is history and…well...I’m a geek. My career is film and television, (you have probably watched entertainment I’ve produced) and I dedicate at least an hour every day to the study of arms and armor no matter how busy I am. I also like to dismantle and do improvements on swords as many on this site do, and have dived into doing my own forging recently.
Initial Impression
Communication with Darksword was prompt and speedy. The sword did take a while to ship as they said they were busy with client orders, I can forgive this. The sword was well packaged in bubble wrap and plastic with a rubber tip protecting the point. It took forever getting the sword out of the packaging but when I did I found these stats: (please note the difference to other reviews)
Total Length: 36”
Blade Length: 28”
Blade Width at Base: 1.85”
Weight: 2.5 pounds
POB: about 3” from guard
Here's a shot of the sword next to the Windlass Type XIV:
I was disappointed to see that the sword had a very obvious fantasy cross guard, but was pleased with how light and balanced the sword was. The whole sword seemed to be really tightly put together and had a nice ring to it when hit, indicting a supposedly tight assembly. The sword is well balanced and lively in the hand, the tip tracks well, is accurate in the thrust and has immense cutting power. We’ll see how far my initial impressions actually last as we break down each component:
Blade:
My first impression of the blade was that it was very shiny, but that I really liked the profile and geometry. Thankfully there was no heavy oil on the blade like the grease I find on a company of a similar price range. The blade has a slight hollow grind and has a noticeable distal taper.
Whoever is heat treating their blades is doing a wonderful job, for the life of me I could not break it. I nearly bent it in half a couple times, and after doing the normal cutting tests moved on to 2x4’s, stumps and concrete board and it wouldn’t scratch, dent, chip or bend. They get very high marks on making a very strong blade. The steel that is used is high quality with an excellent temper.
Initially I was very impressed by the blade; however, in the daylight some harsh flaws began to present themselves.
First off the sharpened edge was very inconsistent (before cutting), it appears they did a single pass over the wheel and left it at that, with no double check. The tip is just slightly off kilter from center, one side is ground more than the other.
The hollow grind is very uneven when viewed down the spin, the spine itself is also very wavy, these things are very subtle and wouldn’t be noticed by the average user I think. The tang is part of the blade and not welded on, so that’s a plus, the tang was CUT from the blade with a saw, it is easy to see where the saw teeth hit to make the shoulders because of an overcut.
The spine was ground down to make the guard fit, (more on that later). The tang is also slightly crooked, but was very subtle and something that likely occurred during heat treat.
If their other sword blades are similar in quality, they would make phenomenal project blades. All in all for the price point a great blade with a few flaws that could be remedied easily.
Let’s talk about the hilt.
As I’ve mentioned a few times I was disappointed that the guard was fantasy style. With a proper guard it would be a very fine looking sword. I don’t understand why they would take this route when the blade and the pommel are so well shaped. The guard also has a very high level of polish that some may find attractive, though I prefer a more matte finish. The peen block is part of the pommel and not separate, but I really wasn’t expecting that for the price point, the pommel has very crisp lines and is very striking and well thought out.
I decided to really examine the hilt when the pommel came slightly loose after my extreme blade and cutting tests.
Before tearing in, I will say, the handle was by far the best part of the hilt. It was appropriately sized and had nice even risers under the chrome tanned brown leather.
The stitching was great, and the best I’ve seen at the price point, it was done correctly and tight in nice even rows, I only wish I could make a grip wrap like this.
Even then, it wasn’t without flaws, the opening for the tang in the handle was over cut and too large, they back filled the extra space with epoxy before sticking it on.
As I mentioned before, the pommel came loose, so naturally, I took it off to investigate. The pommel was screwed on, I’m not exactly ok with that and what made it worse is that it appears that they made an insert for the pommel for the threads, so the pommel itself isn’t threaded, but the insert, I don’t understand shortcuts like this at this price point.
The guard exhibits indications of casting, the opening was overcut and filled with epoxy to secure, leaking out a little. To be very fair, they point out that the guard is fantasy based on the sword description on their website, so if you ordered from their site, and are surprised or put off by it, you ordered the wrong sword, or didn’t read the description carefully.
The spine of the blade was ground down to make the guard fit, this makes the blade (almost) unusable for remounting purposes.
The guard and pommel show machine marks, but they are easily dealt with if they really bother you.
Conclusion:
If this sword is an indication of their more historical models, I wouldn’t hesitate to recommend buying from them, over some other popular brands, for a sword enthusiast that’s just starting out. However, for high end collectors after flawless pieces I would look elsewhere. I would also say that for DIY’ers, if you come across a sword that strikes your fancy for a good price, to go for it, the blades are stellar. Previous reviews I’ve seen have talked about the indestructible nature of Darksword’s blades, and I can now attest to that claim.
Pros:
• Good steel and temper in the blade
• Amazing grip and stitch job
• Good distal taper and geometry
• Nice proportions
• Handling is nice
Cons:
• Sharpening
• Fittings (with the caveat I wouldn’t have ordered a fantasy piece)
• Blade finish (most people would overlook what I found)
• Epoxy in hilt
• Machine marks on fittings
• Balance is a little off, but isn’t bad.
Bottom line is that I feel the sword is a little overpriced, and they still need to work on their marketing strategy, but the blade is a strong step in the right direction. I understand the need for some shortcuts in a sword at this price bracket, so a lot of things I’m able to overlook knowing how much I would pay for it if I did in fact I buy it. I would buy this over a certain US based company that is roughly in the same price bracket…
I hope I don’t come across as too harsh, I ty to pick out the positive in life, but I am also a realist. As mentioned at the beginning of this review: these reviews are MY observations and opinions. Please read more than one review and if you can, try before you buy, everyone is different in their opinions. I can’t thank Darksword enough for allowing me to be brutally honest in this review, and that alone should speak loads for their company and how much they stand behind their product, which to me, is worth a lot.
