Forum Index > Makers and Manufacturers Talk > Available: Pattern Welded Spear Head Reply to topic
J Helmes
PostPosted: Tue 20 May, 2014 5:20 am    Post subject: Available: Pattern Welded Spear Head         Reply with quote
Hello,
Forge welded construction, brazed wings. Wings and socked of wrought iron, 1000+ layer edge, core of antique steel, iron and high carbon steel. The core is4 bar so the pattern runs in the same direction on both sides of the spear head. OAL 37 cm
Jeff
J Helmes
PostPosted: Tue 20 May, 2014 9:25 am    Post subject:         Reply with quote
Sold . Thank you kindly folks!
Carl W.
PostPosted: Wed 21 May, 2014 5:21 am    Post subject:         Reply with quote
Wonderful work. Thank you for making & sharing it.
G Ezell
PostPosted: Thu 22 May, 2014 12:27 am    Post subject:         Reply with quote
That is some extraordinarily beautiful steel, it really does capture the look of pre-industrial bloom. Well done man!
" I have found that it is very often the case that if you state some absolute rule of history, there will be an example, however extremely unusual, to break it."
Gabriel Lebec
https://www.facebook.com/relicforge
