Harry Marinakis
Roger Hooper
Posted: Fri 07 Jun, 2013 11:03 am Post subject: |
Referring to the article, besides locket, I have heard that area of the scabbard also called the throat. Is that wrong?
Posted: Fri 07 Jun, 2013 11:24 am Post subject: |
Roger Hooper wrote: | Referring to the article, besides locket, I have heard that area of the scabbard also called the throat. Is that wrong? |
All scabbards have throats. It's what you first stick the sword into. Not all have lockets, which are metal bits sometimes found at the throat. That's my take, at least.
Matthew Bunker
Posted: Fri 07 Jun, 2013 12:41 pm Post subject: |
Chad Arnow wrote: | Roger Hooper wrote: | Referring to the article, besides locket, I have heard that area of the scabbard also called the throat. Is that wrong? |
All scabbards have throats. It's what you first stick the sword into. Not all have lockets, which are metal bits sometimes found at the throat. That's my take, at least. |
In the study of scabbards of the early medieval (ie pre-1066) and earlier periods, the term usually used is 'mouth-band', in English at least.
T.F. McCraken
Posted: Sat 08 Jun, 2013 11:16 am Post subject: |
On the scabbard, you have...(and these are MY terms)
The scabbard body
At the throat you have either a locket, if it is terminated, or an integral rainguard. You can have a terminated throat without the locket.
At the tip of the scabbard, you would put a chape (or, chappe) to protect the tip.
A scabbard's belt, I call "The Suspension" and suspensions come in different styles. Knotted, frogged, strapped, buckled, etc. These transition between belt and scabbard.
Hope I've helped.
Murphy
aka "Murphy"
See ya at Bristol Renaissance Faire!
The decisions we make, dictate the life we lead.
"I drank what?" -Socrates
www.celticfuryproduction.com
Kel Rekuta
Posted: Sat 08 Jun, 2013 4:22 pm Post subject: |
None of the assemblages illustrated above are period so don't spent a lot of effort defining the details. They are lovely modern interpretations. Ewart Oakeshott did a chapter of one of his books on scabbards and suspension so its probably easiest to use his terminology. Most people interested in the topic are familiar with his works and can relate immediately to his terminology.
Between the related websites "Effigies and Brasses" and "Miniatures and Illuminations", a researcher should be able to find sufficient period usage illustrated. Definitions are a modern hangup.
Mark Griffin
Posted: Sun 09 Jun, 2013 6:34 am Post subject: |
Agree with you on the first 2 Kel but the last Albion one? That not based on a variety of effigies, statues, ms illustrations etc?
Kel Rekuta
Posted: Sun 09 Jun, 2013 2:11 pm Post subject: |
Yeah, the last one is well done. For some reason my tablet didn't load that one this morning. Service has been kinda wonky while I'm traveling. Gotta update the software or something.
Leo Todeschini
Posted: Sun 09 Jun, 2013 3:34 pm Post subject: |
Harry Mariankis wrote Quote: | I am sure that the craftsman of the Medieval period had names for all of these parts. |
I have a feeling that if you ever managed to find a document that discussed the making of them, it would say something highly unuseful like "and make the belt in the usual way". That killer phrase pops up in all manner of written descriptions from cooking to wheelmaking.
Scabbards did come in a variety of layouts and they came with variations and makers would have local words or indeed their own words and then there are language differences also.
As a modern example. In an old job I used to use a toughed acrylic adhesive made by 3M. It could be called 3M410 (or whatever it was), it could be called acrylic adhesive, semi structural adhesive, toughened acrylic; all would work and all are right. It was however called 'Death glue' because it stank so bad it had to kill you. All special effects and model makers in London call toughened acrylic adhesive, 'death glue'. I bet its not called that in Paris, Solignen, Toledo or NY.
I suspect there were multiple words used for all the parts and none standard across the board.
www.todsworkshop.com
www.todcutler.com
Harry Marinakis
Posted: Tue 11 Jun, 2013 1:53 pm Post subject: |
Kel Rekuta wrote: | Ewart Oakeshott did a chapter of one of his books on scabbards and suspension so its probably easiest to use his terminology. |
I have many of his books on my shelves. Do you remember which book specifically?
Kel Rekuta
Posted: Tue 11 Jun, 2013 3:22 pm Post subject: |
Sorry Harry, my library is in Toronto & I'm not this week. Wild guess would be The Sword in the Age of Chivalry. If no one pops up the answer, I'm back home next Tuesday.
Harry Marinakis
Posted: Wed 12 Jun, 2013 8:41 pm Post subject: |
Kel Rekuta wrote: | The Sword in the Age of Chivalry. |
Ah! The one Oakeshott book that I don't have!
Glen A Cleeton
Posted: Thu 13 Jun, 2013 3:05 am Post subject: |
Harry Marinakis wrote: | Kel Rekuta wrote: | The Sword in the Age of Chivalry. |
Ah! The one Oakeshott book that I don't have! |
If you have Archaeology, read through chapter 14 The Sword In Wear
He referred to most metal bits (aside from buckles or rings) as mounts
Regarding the use of the term locket
Middle French loquet latch, from Middle Dutch loke; akin to Old English loc
First Known Use: 1679
Those fittings used in a frog or baldric with a stud or hook to secure in the carrier.
GC
