Forum Index > Historical Arms Talk > Læwatan; Staffordshire Hoard Wælseax Reply to topic
Aed Thompson
PostPosted: Mon 28 May, 2012 5:49 am    Post subject: Læwatan; Staffordshire Hoard Wælseax         Reply with quote
I couldn't resist posting some pics of my dad's latest project; an attempt to reconstruct the seax that the famous style-II Staffordshire Hoard seax hilt-platek567 would've adorned.
The blade is 35cm long, comissioned from Paul Binns to fit k567 exactly and falls into Schmalsaxe type-1 of Schmitt's typology. The blade was produced by twist-welding two bundles, each composed of 9 layers, with a steel edge hammer-welded on afterward.
The lower-guard was produced by George Easton of Danegeld, and the k567 replica is precisely to scale.
The handle is made from English wallnut and cow-bone sheet, while the atrophied "upper guard" to protect the end of the handle and accommodate the cnæpp was produced from copper-alloy and buffalo-horn matching the lower-guard and corresponding sword.
The cnæpp is a mini replica of the fascinating Staffordshire Hoard piece k711, in gilded copper alloy.
And, as a bonus, here's a simple triangular buckle for a sword-strap I threw together this weekend.
Aed Thompson
Thegns of Mercia
David Clark
PostPosted: Mon 28 May, 2012 7:49 am    Post subject:         Reply with quote
That is gorgeous! I am really loving the plade profile. What is the blade-spine width?
And the buckle is awesome too.
Tim Lison
PostPosted: Mon 28 May, 2012 8:14 am    Post subject:         Reply with quote
Magnificent! This is top notch! What will you do for a sheath?
Aed Thompson
PostPosted: Mon 28 May, 2012 9:49 am    Post subject:         Reply with quote
Thanks very much for the positive comments!
The blade is a little over 4mm thick, and 36mm wide, to fit neatly into the 4.5x37mm triangular slot in the hoard k567 hilt-plate.
I'll definitely post pictures of the sheath when it's done. I believe the plan is to use thick vegetable-tanned leather lined with lamb skin to further cushion the blade. We toyed with the idea of making a wooden-core sheath for it, but decided this would be a bit bulky for a seax of this size. The decoration of the sheath should be impressive, though I don't want to give too much away Wink .
Aed Thompson
Thegns of Mercia
Paul Mortimer
PostPosted: Mon 28 May, 2012 12:23 pm    Post subject:         Reply with quote
Looks excellent Aed. Please give your father my congratulations.
Paul
Sam Barris
PostPosted: Mon 28 May, 2012 4:24 pm    Post subject:         Reply with quote
Ooo! Yes, please. Happy
That's wonderful work.
Pax,
Sam Barris
Matthew Bunker
PostPosted: Mon 28 May, 2012 9:47 pm    Post subject:         Reply with quote
What a lovely looking beast. Nice work from all concerned.
Aed Thompson wrote:
. I believe the plan is to use thick vegetable-tanned leather lined with lamb skin to further cushion the blade. We toyed with the idea of making a wooden-core sheath for it, but decided this would be a bit bulky for a seax of this size .
I don't understand this. If you use the right materials (1.5 mm/2mm thick wooden lathes and 1mm leather ), it needn't be bulky at all, any more than a properly made sword scabbard would be. The trick is getting the right sort of skin to line it with. Sheep or lamb skin from modern breeds tends to be too curly in the fleece and thick in the skin, which does lead to a bulky object overall.
Look to an old breed (like a Ouessant, or even afghan goat) which has the thin skin and long straight hairs of ancient animals or go for a different animal altogether (I used beaver in Paul's new SH scabbard).
Plenty of evidence for wood cored seax sheaths, none I can think of for fleece lined leather ones.
Bruce Tordoff
PostPosted: Tue 29 May, 2012 11:40 am    Post subject: Staffs Seax         Reply with quote
Hi Aed,
Gotta say, that looks really nice, as you know I made a replica of the 'other one', so its really nice to see one, using these fittings. I think the overall effect is real pretty, so as Matt said, good show, to all concerned.
I hope your scabbard does it justice, good luck.
Bruce
David Huggins
PostPosted: Wed 30 May, 2012 11:06 pm    Post subject: Seax         Reply with quote
Indeed. I spotted this on George's FB site and was pleased to see his fine work hilting Binnsy's excellent blade. Congratulations to Dr.Thompson and well done, it's good to see another interpretation of the magnificent Hoard
artifacts realised.
best
Dave
Aed Thompson
PostPosted: Tue 17 Jul, 2012 1:20 pm    Post subject:         Reply with quote
Pseudo-gravedig. Here's pics of the sheath.
The chape is based on (though not an exact replica of) the c8th Westminster Bridge "zoomorphic scabbard fitting" (by George Easton, once again), while the embossed decoration based on a biting beasts motif from the book of Durrow bridges the gap between the wolf's head and the simpler biting-beasts on the STH hilt plate. Together, it's hoped the seax and sheath will help illustrate evolution of this particular aspect of Style-II.
Aed Thompson
Thegns of Mercia
Tim Lison
PostPosted: Tue 17 Jul, 2012 1:30 pm    Post subject:         Reply with quote
Wow! That is really good! I love the wolf head! Tremendous stuff.
