Brandon Gray
Posted: Fri 06 Apr, 2012 7:57 pm Post subject: Medieval Swords with Threaded Tangs? |
I've recently read that swords with threaded tangs existed at least as far back as the Renaissance, which surprised me because I've always thought of it as a modern construction method. However, the only examples I can find are hangars and military sabers.
While reading the review of Del Tin 2150 I noticed that "a pommel nut and rosette-shaped plate adorn the top of the pommel" (in reference to the original). Is the "nut" in this case a piece of hardware which secures the tang to the pommel or some sort of decorative piece? When exactly did this type of construction arise?
Elling Polden
Posted: Fri 06 Apr, 2012 8:21 pm Post subject: |
In the Gladiatoria manual (mid 15th c), there is a plate showing a heavy fighter unscrewing his pommel and throwing it at his foe...
The merit of the tactic aside , it certainly shows that the consept of threaded pommels was known.
Brandon Gray
Posted: Fri 06 Apr, 2012 9:35 pm Post subject: |
I apologize, I didn't think to use the search before I posted this.
