Forum Index > Off-topic Talk > Lining for a bevor Reply to topic
Iain Ritchie
PostPosted: Thu 22 Mar, 2012 4:08 pm    Post subject: Lining for a bevor         Reply with quote
Hello everyone,
I own a replica (of course) 15th centuary suit of armour, The bevor is a single solid piece, should it be lined and if so how and what with?
Thank you in advance for any help.
Tjarand Matre
PostPosted: Fri 23 Mar, 2012 12:18 pm    Post subject:         Reply with quote
I sometimes use a bevor when I train and I would not line it. It sits on top of your gambeson and works like a condenser for the sweat escaping upwards. And your breath also condense inside the bevor accumulating epic amounts of fluid. Any lining would be saturated with body fluids very fast and become very very disgusting. I use a tight fitting wool hood (a 15th century fringed one) as it's easy to clean when it stinks too much and it covers both neck and head from chafing.
F Hynd
PostPosted: Fri 23 Mar, 2012 5:42 pm    Post subject:         Reply with quote
I would second not lining the bevor. After being used for a little while it gets rather damp in both the bevors I regularly use. I've only seen one lined bevor and it only gets ponced about in
Jeffrey Hedgecock
PostPosted: Sat 24 Mar, 2012 12:57 pm    Post subject:         Reply with quote
Bevors MUST be lined to work properly. The protective value of a bevor is determined by its remaining in position. If it's not lined, it will shift out of position and not absorb (deflect or redirect) impact, which is the purpose of ALL armour.
It's ridiculous that a bevor would not be lined because of sweat or condensed breath. You can't think of armour in modern reenactor terms, but you must think of armour in terms of its ability to keep you alive (even if it means replacing linings, straps etc-- armour requires regular maintenance and is consumable). A sweaty liner can be cleaned or replaced..........your throat can't, if it's been cut or smashed.
A stuffed and quilted linen liner is typical for bevors, with a strap around the back of the neck. They work fine if executed properly. An unlined bevor just dangles around like a necklace, offering little or no real protective value.
Jeffrey Hedgecock
Historic Enterprises, Inc.
WorldJoust Tournaments™
Eric Hejdström
PostPosted: Sat 31 Mar, 2012 7:16 am    Post subject:         Reply with quote
I recently lined my old bevor and have to second Jeffreys statement. I lined the cup and partially the lower plate. Ofcourse this makes a bit tighter when using a gambeson but it's no problem. Generally using a heavy gambeson is not necessary when wearing plate. But as seen in several paintings the bevors are used combined with a helmet only, no other armour or gambeson visible. A simple but very efficient protection to the head.
My liner is made from linen and stuffed with raw linen fibres (as used for sealing small cracks and holes in timber buildings) and then stitched to a strip of heavier linen cloth that's riveted to the metal. Linen have the amazing quality to not absorb odours much and it takes quite a while for it to get nasty. And if needed I can just cut the thread and wash it. As said, just the regular maintenance...
Mark T
PostPosted: Sat 31 Mar, 2012 4:49 pm    Post subject:         Reply with quote
Hi Iain,
Do a search for Sean Flynt's threads on lining a sallet and bevor ... here are a couple, but I think there was one other also:
http://www.myArmoury.com/talk/viewtopic.php?t...ight=bevor
http://www.myArmoury.com/talk/viewtopic.php?t...mp;start=0
There's also an old thread by Bill Grandy which contains a historical image of a lined bevor: http://www.myArmoury.com/talk/viewtopic.php?t...ight=liner
Hope that helps,
Mark T
Schallern sind sehr sexy!
Thomas R.
Reading list: 17 books
PostPosted: Sun 01 Apr, 2012 1:25 am    Post subject:         Reply with quote
I second that. I've seen far too many photos in which people wear their bevor like a necklace. It has to be worn very tight around your chin and neck. It's very restraining and very often you are no longer able to nod. And if the bevor is fixed on your breastplate, you won't be able to turn your head sideways, too. You'll have to turn your whole upper body then. And if your sallet and bevor are not fitting well, you'll get problems with your vision or the pieces will clank together all the time.
Thomas
William P
PostPosted: Mon 02 Apr, 2012 7:32 am    Post subject:         Reply with quote
i understand its meant to be tight but also may i ask, what the difference is between a gorget and a bevor...
all the books ive read are very ambiguous
Mark T
PostPosted: Tue 03 Apr, 2012 3:43 am    Post subject:         Reply with quote
Another nice shot of a modern repro lined bevor is in this thread.
Reading list: 7 books
PostPosted: Fri 13 Apr, 2012 5:48 pm    Post subject:         Reply with quote
The impression I get is that gorgets tend to be tucked under the breastplate, while bevors are worn over it. Especially when the two are worn together (such as in jousts).
