I think that it is way too long. As you can see, the bottom of the coif overlaps the collar on my gambeson. When I bend my head forwards and then backwards again, the coif bumps into the collar and causes the coif to shift forward. Very annoying.
Also, the tie doesn't press against the underside of my chin. Instead it presses backwards into my adam's apple which, as you can imagine, is very uncomfortable.
So, is it too long? And if so, how much should I shorten it? Anyone got pictures of a padded coid that does fit well with a collared gambeson?
Additionally, it first appeared to me that the coif has been put together inside-out. The (thick) seams that hold the three coif panels together are on the outside of the coif, not the inside. I have seen a few other Matuls padded coifs and they all have the seams on the outside as well, so I am guessing this is intentional. But I'm not sure. I'd thought I'd ask anyway, since I have to take the coif apart in order to shorten it anyway.
Thanks in advance!
padded coif, side view.
