Julien M
Posted: Tue 05 Jan, 2010 9:23 am Post subject: |
Great stuff Sean! I really really like this one.
Facet grip, clean pattern on the rainguard...you have not looked for the easiest approach and it really paid off. That's exactly the kind of work that draws me back to my workbench really looking forward to see the sword complete.
If you are willing to share, could you post a pict of you custom swivel knife?
J
Posted: Tue 05 Jan, 2010 9:40 am Post subject: |
| Julien M wrote: | Great stuff Sean! I really really like this one.
J |
Thanks! I meant to get a shot of my chisel setup and forgot to do it. I'll get that ASAP and post. I thought folks might appreciate that trick
Luke Zechman
Posted: Tue 05 Jan, 2010 9:45 am Post subject: |
Looking good Sean!!! That pattern on the rain guard reminds me of a quilting pattern of a Byzantine soldiers kavadion (gambeson). Can't wait to see it finished!!!
Posted: Wed 06 Jan, 2010 1:12 pm Post subject: |
Here's the chisel I rigged for the leatherwork on the chappe. All you really need is a thin strip of wood. I used this piece as I found it just because it was the right thickness (about .25"). I clipped the corners so I could more easily see the ends of the blade--those have to be placed precisely so they don't stray into the horizontal band at the bottom of the chappe.
Attachment: 133.21 KB
Attachment: 154.63 KB
Attachment: 119.84 KB
Thom R.
Posted: Thu 07 Jan, 2010 12:35 pm Post subject: |
ah nice technique on the chisel - thanks for sharing that tip! I like how your project is turning out. nicely done all around. you really have gotten the chappe making down. looks good.
not to hijack but here is where I am with mine. I am going for more of a Dordogne River find look with style 11 cross. have been trying to figure out a facted pear pommel but in the end I think I am going to keep the original and mate it with the t-11 cross, waist the upper part of the grip, new cord wrapped leather cover grip, with wire wrap on that waisted upper half.
Thom R.
Posted: Thu 07 Jan, 2010 2:22 pm Post subject: |
make it? its my usual hacker job on an old windlass cross (can't remember the name of the sword). it was a fantasy scottish claymore SLO. too big for anything until this one. but is appropriately proportioned with this fat type XVIIIa. I had it in mind when I bought the Erbach and I think it works aesthetically. All of my 15th c stuff is 9 and 11 crosses with J, V, and T pommels. (Albion Constable for example). I thought it would be cool to add a beater Windlass sword for less than 200 bucks to the mix.
I have another one of these I am going to do as a fantasy sword as well for friend who is into that kind of stuff. as you mentioned - I think it's one of the better Windlass blades in awhile. tr
Posted: Tue 02 Feb, 2010 7:51 am Post subject: |
The sword is finished but for some minor finish work on the peen block. Here are a few quick shots. I'll get a proper series of photos after I finish the scabbard and suspension--maybe another week or two. You can see the difference between my last Type XVIII project--a riding sword--and this war sword. Similar length and style, but very different in the hand. Both feel right for the blade type. This broad blade feels very authoritative but well-balanced.
Attachment: 182.93 KB
Attachment: 173.31 KB
Attachment: 171.21 KB
Attachment: 160.14 KB
Nathan Gilleland
Posted: Tue 02 Feb, 2010 7:57 am Post subject: |
that is some brilliant work Sean!
I am green with artistic jealousy. I keep meaning to try my hand at some sword modifications, but then I realize that I don't have the equipment to re-peen the hilt, I get too nervous about bending a cross, etc.
It's great to see your work so I can get the itch to try it again for myself.
Seek Honor before Wealth,
Truth before Honor,
God Before all
David Etienne
Posted: Tue 02 Feb, 2010 9:35 am Post subject: |
The way you turned that 'cheap' sword in a much more elaborate and beautiful one is just outstanding, Sean. I really like your improvments. Congratulations !
David
Jason Mather
Sean,
You should catalog and publish a record of your projects. You have inspired many people on the forum to modify stuff, I think you could reach more people with a feature on your work.
Jai
To be nobody but yourself in a world that's doing its best to make you somebody else, is to fight the hardest battle you are ever going to fight. Never stop fighting.
Posted: Tue 02 Feb, 2010 11:30 am Post subject: |
The problem with my old projects is that they're my learning projects. I look back and think, "why did I do it that way?" I'll know I've arrived when I can't improve from one project to the next (in other words, "never").
I find that it helps to do several similar projects in a row. You not only immerse yourself in a given period, which helps you get a feel for the aesthetic, but you also get to refine specific technical skills--re-curving a cross or making a tubular chappe are good examples of this. This has also helped me gain insight into construction and design. Do something once and it's easy to just get it done and forget about it. After the third or fourth time, I start to understand why something should be done a particular way.
Given my interests, I will probably want to learn welding eventually. That would open up some wonderful possibilities. Quick, somebody, tell me that I can get started with $50 and ten minutes of self instruction (and NOT burn my face off).
Eric Hejdström
Posted: Tue 02 Feb, 2010 1:45 pm Post subject: |
Sean, unledd you got very girly hands that seems to be a quite massive blade! Very nice job though. It's nice to see the chapes you make, they look really nice. Gives an extra touch to the whole impression of the sword.
And why would you want to weld stuff? I admit it comes in handy when you need to repair your car or stuff like that.. Learn forgewelding! Just kidding. An electrical welding machine is not that expensive and most info you need can probably be found online. Get some scrap metal and start practice. The drawback is all the slagintrusions unless one is careful. Gaswelding is better but a bit harder. Do you know any bikers or truckers? They usually know people who weld stuff
Posted: Tue 02 Feb, 2010 1:59 pm Post subject: |
Yeah, it's a big sword. Not especially long, but very broad. The hollow grinding makes it feel lighter than it looks. I haven't weighed it yet, but it'll certainly be over 3 lbs.
Where I live, probably half the people in the neighborhood can weld I could probably get welding done inexpensively, but there's nothing like the smell of your own burning flesh to make you appreciate the work. The challenge is a big part of the attraction in these projects. But I have a guard that could use a single weld to be more historically authentic. That would be an interesting test-project for later this year. All I would need is the weld. All cleanup and filing I can do myself.
Julien M
Posted: Wed 24 Feb, 2010 9:17 am Post subject: |
More shots please!
This might be the best work I've seen from you here Sean...
Why stop at the buckle though??? Compared to the amount of work invested in this project this makes little sense to overlook that very last bit
Anyway...cheers and well done.
J
Is that belt another dog leash?
Peter Johnsson
Posted: Wed 24 Feb, 2010 9:36 am Post subject: |
Good work Sean!
You captured style and period nicely. You´ve got a good eye for character.
