Note: The smaller image to the side is a badly drawn look down at the pommel. Try to imagine it a bit more angular and not a oval. Also, the triangular portions on the pommel are supposed to be raised and not a flat pattern, whereas the design on the riser should be indented grooves.
These are roughly the stats I'm looking for (Keep in mind I suck at art and am only a dabbler in Paint, so above picture is hardly to scale):
Total Length: 4'
Grip Length: 9.25"
Pommel Length: 2.25"
Blade Length: 36"
Crossguard Width: 7.5"-9"
P.O.B: 3.5"-4.5"
Weight: 2.5-3.5 pounds
Given that I'm no expert on swords, it wouldn't surprise me to learn that some of the desired stats would be difficult to produce or would result in a frail or unwieldy sword. Therefore all stats are open to alteration if needed.
I want a Sempach type blade, somewhat akin to the Albion Sempach found here: http://www.albion-swords.com/swords/albion/ne...photos.htm
Major differences are that I would prefer a slightly wider shallower fuller and a ring of metal in the middle of the hilt as a riser, say about 3.75" below the hilt. Given my tastes, I may want to go with a slightly more cutting type blade, but I'd prefer to keep it primarily a thrusting sword.
Now, my first question to the board is this: Is this sword more or less historically accurate, or does it incorporate elements not normally found together in a sword of the Sempach era?
My second is more open-ended: What is your opinion on the sword concept? I.E. What would you change? What is wrong with X or Y? Etc, etc.
Edit: It occurred to me when messaging someone else about this design that I didn't say that the hilt is supposed to be leather-wrapped. My drawing being less than perfect, I just thought I'd make that clear.
