Forum Index > Historical Arms Talk > Need help with maces Reply to topic
Jorge Santos
PostPosted: Tue 11 Aug, 2009 12:11 pm    Post subject: Need help with maces         Reply with quote
iīm from Portugal....and i built replicas of swords and daggers from X to XVI cent......i would like to ask if someone can help mein a question............how did they make the maces of blades..... thank you!
jorge santos
Gavin Kisebach
PostPosted: Tue 11 Aug, 2009 3:03 pm    Post subject:         Reply with quote
Hello Jorge, and welcome to the forum. I think you are describing a flanged mace head like the one below, is that correct? I've often wondered about this myself.
By the way this is a great source for mace information (and it is where I got the image)
http://otlichnik.tripod.com/medmace3.html
 Attachment: 60.89 KB
Jorge Santos
PostPosted: Tue 11 Aug, 2009 3:47 pm    Post subject:         Reply with quote
hello gavin....!!!!! thank you for the reply...... yes youīr right thatīs the type of mace!....and the problem is....how did they do this weapon..... the blades are temperated steel.!!! so they could not make the piece by casting the iron....welded????? i d 'ont think so.....there's no way....!!!! i've tried before...the steel loses the temper.....it's a real mystery....all the other weapons are possible to reproduce......but the mace......itīs the big challenge!!!!
jorge santos
Matthew Fedele
PostPosted: Tue 11 Aug, 2009 4:04 pm    Post subject:         Reply with quote
Jorge,
I wondered the same thing for a long time. The flanges were brazed on. Think about it and it's about the only thing that makes sense besides casting. You can even see the copper in the seams on the above picture.
Matt
Jorge Santos
PostPosted: Tue 11 Aug, 2009 4:28 pm    Post subject:         Reply with quote
hello mathew.......and welcome to the discussion............ yes in the case of the mace in the picture ,,,you'r rigth........there's copper alright.....but i've seen others were theres no trace of copper....or any kind of welding.......and thatīs wath makes me crazy!!!!!!!!!!!!!......see book " WEAPON"....Richard Holmes...in association with ROYAL ARMOURIES MUSEUM.....page 137 and you'l l see wath i mean.....cheers..
jorge santos
Matthew Fedele
PostPosted: Tue 11 Aug, 2009 4:53 pm    Post subject:         Reply with quote
Jorge,
Thank you for the welcome. Keep in mind they've found bronze-age rings that required a microscope to find where it was brazed together (I often find those bronze age guys were a lot cleverer than I.) Without the piece in your hand it may be difficult to see any signs of brazing. The only other thing that I can imagine is dovetailing it in, but dismissed it as too much work when you can just braze and have a very high tensile strength.
I've chewed the issue over with two other blacksmiths and it has been the only thing has made sense. Maybe someone else here has a better theory?
Cheers!
Matt
Gavin Kisebach
PostPosted: Tue 11 Aug, 2009 5:01 pm    Post subject:         Reply with quote
Jorge this has puzzled be for some time, and the only method that I can come up with I have illustrated below. I'm sure there is some method that I would never imagine that was actually used, but I think I could make this work.
Step 1: Hammer weld L shaped flanges onto a flat sheet.
Step 2: Bend the sheet around into a tube.
Step 3: Hammer weld the edges of the sheet
 Attachment: 6.91 KB
D. Austin
PostPosted: Wed 12 Aug, 2009 6:47 am    Post subject:         Reply with quote
I like Gavin's idea and wouldn't be surprised if it had been tried at some stage, but I'd have to say that in almost every case, the flanges were brazed to the shaft.
Jorge, you're right in thinking that this would prevent hardening of the steel. Fortunately, a mace doesn't have the same requirements as a sword, for example, and really doesn't need to be hardened.
Matthew Fedele
PostPosted: Wed 12 Aug, 2009 7:14 am    Post subject:         Reply with quote
Yup, that would do it Gavin. Never thought of that. Very cool.
Matt
Ken Nelson
Reading list: 12 books
PostPosted: Wed 12 Aug, 2009 8:41 am    Post subject:         Reply with quote
Brazing may have been a very popular way of putting the flanges on, but do not count out welding.
The welding I am speaking of is forge welding. Our ancestors were working with wrought iron, and steeling it. Compared to modern steels it welds like a dream. There is even a type of welding referred to as pinch welding, where the pieces are broungt up to welding temperature in the forge and literally pinched or squeezed together while still in the fire, instead of being hammered. While pinch welding can be done with modern steels, it is difficult. Wrought iron can actually take temperatures that allow the scale to melt away, and then can be joined in the fire without flux, and into a seam that has full strength.
Hardening and tempering of the flanges would have been done last, once the head was together, so the temperatures used during welding would not remove the temper, as the temper wasn't there yet.
Ken Nelson
Iron Wolf Forge
"Live and learn, or you don't live long" L. Long
PostPosted: Wed 12 Aug, 2009 12:55 pm    Post subject:         Reply with quote
From my review of the Windlass Steelcrafts German Mace:
"Historically, it seems that these often were brazed to a separate piece of metal and then attached to the shaft as a single piece. Alternately, they were attached by projections in their bases that corresponded to holes in the shaft, then secured in place by brazing."
If I remember correctly, that's according to Oakeshott.
This could explain cases in which we don't see the brazing--it's inside the shaft (?).
Matthew Fedele
PostPosted: Wed 12 Aug, 2009 3:02 pm    Post subject:         Reply with quote
Running with Gavin's idea you could also:
1) Hammer 4 v-shapes into a swage so it looks like #2
3) Forge weld the "V"s down
4) Wrap it around and weld it like they would a pipe.
Sorry the drawing is a little crude. Drawing with a mouse is like drawing with a brick.
Matt
 Attachment: 15.08 KB
Gavin Kisebach
PostPosted: Wed 12 Aug, 2009 3:25 pm    Post subject:         Reply with quote
I'm glad this topic came up. I wasn't really familiar with brazing, and certainly would have thought it a modern technique.
I'm also glad that someone likes my idea even if it isn't historical Big Grin
Jorge Santos
PostPosted: Wed 12 Aug, 2009 4:45 pm    Post subject:         Reply with quote
Hello people!!!!! and thank you all for the help you give me.......your fantastic!!!!! .....Sean...what you say makes sense....!! i'm going to try that...... i guess now we are thinking like a midlle age swordsmith would do and following the same steps when they tried to make the first mace....and we are facing the same problems they had before finding the right way to do it..............a big...embrace to you all....and now ...........let's make the envil sing!!!!
jorge santos
Jorge Santos
PostPosted: Thu 13 Aug, 2009 5:26 am    Post subject:         Reply with quote
Hello Austin!!!!!............thank you for your reply.....! but i'm afraid i can not agree with you.... i can assure you that maces were hardened....!!!! i have the fortune of had some original pieces in my hands ....for study...and they were hardened allrigth...that i'm certain.... cheers... Jorge Santos
jorge santos
Jorge Santos
PostPosted: Thu 13 Aug, 2009 3:29 pm    Post subject:         Reply with quote
Hello Gavin.............just to say that i find your idea very interesting......that could really work !!!!!...maybe you found it!!!!.........thank you for the suggestion............ cheers to you!
jorge santos
Fabrice Cognot
PostPosted: Fri 14 Aug, 2009 10:49 am    Post subject:         Reply with quote
Hi Jorge
Ou of curiosity, how do you know the maces you handled were hardened ?
Most - if not all - maces I saw had the flanges brazed on BTW. Copper brazing the said flanges required a great mastery of the brazing process and work enironment.
PhD in medieval archeology.
HEMAC member
De Taille et d'Estoc director
Jorge Santos
PostPosted: Fri 14 Aug, 2009 5:36 pm    Post subject:         Reply with quote
Hello fabrice....!!!!..your question is interesting.... all along the past years iīve built many swords and daggers too...... i work with my forge and my envil and in my case i can feel the hardened steel by the touch and the sound of the metal if you give a gentle touch using a small hammer.... but there are other ways......with a pocket knife passing in the edge of the blade...the tempered steel looks like glass..!!!... canīt live a mark on it.....but wīre talking of very old and priceless pieces..you must be very careful.!!!!!...... Cheers....Jorge Santos
jorge santos
