Forum Index > Historical Arms Talk > Your Opinion On A New Sword ProjectDIY Project Reply to topic
This is a standard topic Go to page Previous  1, 2, 3, 4, 5
Maurizio D'Angelo
Likes: 3 pages
Reading list: 3 books
PostPosted: Wed 08 Jul, 2009 2:23 pm    Post subject:         Reply with quote
hi,
It appears from a great builder of swords.
Bravo Sean.
2 my usual questions. Happy
1) have you calculated the weight, before you build?
2) I thought you'd preferred a longer pob. Just a little bit.
Have more authority in the cut. But it is only my personal opinion.
The sword is in your hand, you say. Or just personal preference?
Ciao, Sean Wink
Maurizio
This photo has inspired me, for a longer pob.
 Attachment: 92.4 KB
Last edited by Maurizio D'Angelo on Wed 08 Jul, 2009 8:30 pm; edited 2 times in total
PostPosted: Wed 08 Jul, 2009 7:29 pm    Post subject:         Reply with quote
Maurizio D'Angelo wrote:
hi,
Bravo Sean.
1) you have calculated the weights first?
Ciao, Sean Wink
Maurizio
When I started this project I had no idea where the balance and COP would be. Nor did I have any idea about weight. The original sword did not feel good in my hand, and gave no clues. I knew the pommel would provide a significant counterweight, and that suggested the need for a long grip. That led me to the artwork that served as my inspiration.
One of my options was to move the pommel closer to the cross, which would move the POB down the blade for a more aggressive cutting attitude. A lower balance point wouldn't be a bad thing, but it might make the sword less of a pleasure to move without necessarily contributing much to the power of a cut. I decided to emphasize the thrust by leaving the pommel farther away. It is a relatively narrow blade, after all. Still, I had to use about one inch more of the blade for tang than I had planned, and I think I would like to have that extra inch and the very slightly lower POB that would come with it.
I find it interesting that so many decapitation scenes of this period show the use of such blades. They don't seem to have the ideal mass, profile and section for that (as judged against the dedicated execution swords of later years) but I guess the speed and accuracy of the strike compensate for that.
Maurizio D'Angelo
Likes: 3 pages
PostPosted: Wed 08 Jul, 2009 8:49 pm    Post subject:         Reply with quote
ok. I understood. You're right. Move the POB does not necessarily improve the cutting.
I felt that it was the only way. The blade was already built.
However, to be a publisher, your building has really surprised me.
Incredibile
Julien M
PostPosted: Thu 09 Jul, 2009 12:56 am    Post subject:         Reply with quote
Nathan Robinson wrote:
Really, that type of thing needs to be done before dying and finishing. Doing it now would not result in crisp details.
Yeah I'm sure that must somehow rule out carving, but surely the leather even if finished would take stamps (the leather looks thick and fat enough in that case). Simple stuff, such as the one showed below (I like the idea that the common soldier would personnalize it's own scabbard during the calmer times of a campaign).
J
 Attachment: 69.83 KB
PostPosted: Thu 09 Jul, 2009 6:45 am    Post subject:         Reply with quote
One more.
 Attachment: 105.96 KB
Tim May
PostPosted: Thu 09 Jul, 2009 4:39 pm    Post subject:         Reply with quote
Brilliant, Sean, really outstanding work. I've been watching it come together, and the finished product is better than your projections.
One question, how does the scabbard wear while the sword is unsheathed? It seems as though it would hang oddly, but I'd be more than happy to be proven wrong.
PostPosted: Thu 09 Jul, 2009 5:08 pm    Post subject:         Reply with quote
Sean, that last photo is particular excellent.
It's best to do all that pre-dying and certainly pre-finishing of the leather. This what is technically correct, but certainly not the only way to do it. Leather, at any stage, can be compressed and manipulated, but it will produce much better results before it's been dyed or finished.
PostPosted: Thu 09 Jul, 2009 6:59 pm    Post subject:         Reply with quote
Sean, that last photo is particulary excellent.
Thanks! I had my G10 for that one. Battery died after a couple of shots and I switched to an old Nikon I've forgotten how to operate. Blush
PostPosted: Thu 09 Jul, 2009 7:11 pm    Post subject:         Reply with quote
Thanks, Tim! It hangs more or less straight down when empty, as is often depicted in artwork showing this type of suspension (see the execution image on the previous page). With the sword in the scabbard, the pommel tips everything slightly forward and the knot helps keep it that way because the weight of the sword is sufficient to keep tension on the belt. Keep in mind that the belt is worn quite loose, so when the sword is out, the weight of the scabbard is free to hang and the knot configuration no longer keeps the scabbard at an angle because there's not enough weight in the scabbard to keep tension on the belt.
On a related note, I find that the weapon must be worn not exactly on the side or slightly to the rear as I expected, but slightly to the front of the hip. That keeps the scabbard clear of the legs and the grip clear of the arm when walking. The weight is hardly noticeable.
PostPosted: Thu 16 Jul, 2009 6:51 am    Post subject:         Reply with quote
Another interesting image, ca. 1516. Note the pommel shape, grip length, scabbard attachment, belt and buckle. As for that blade...Is that a fuller or the flat of a hexagonal section? If it's a fuller, I wonder if a reproduction Oakeshott Type XIV or XVI blade could be adapted for a project of this much later period. Hmmmmm....
 Attachment: 169.21 KB
PostPosted: Wed 19 Aug, 2009 11:31 am    Post subject:         Reply with quote
I notice that the Saxon Hilt Sword is back in the Deal of the Day bin at MRL today. Still only $97, an incredible bargain for a project sword. If I didn't have so many projects on my bench already I'd grab another one!
Page 5 of 5 Reply to topic
Go to page Previous  1, 2, 3, 4, 5 All times are GMT - 8 Hours
