Forum Index > Off-topic Talk > Sword Fuller, how do i make it?? Reply to topic
Sergio Luiz Marquart Roma
PostPosted: Wed 01 Jul, 2009 6:12 pm    Post subject: Sword Fuller, how do i make it??         Reply with quote
Hello every one!!
My name is Sergio, and i´m from Brazil!
I´m having trouble making a Fuller on my swords.. how is the best way to do it??
Make a specific tool, grind it of with a file??
any help is realy apreciated!! Big Grin
Sergio Roma
www.armaduras.com.br
Matt Lewis
PostPosted: Wed 01 Jul, 2009 7:21 pm    Post subject:         Reply with quote
Hey Sergio,
There are a couple of things you can do , assuming you don't have a power hammer, you can either forge in the fuller using top and bottom 'fuller' tools, one for the hardy hole and one on a handle usually, some people prefer to use a smithing magician or a kinda sprung tool that mirrors the function of the top and bottom fullers, you can grind them in using a grinder with a small belt or if it is a narrow fuller I think those can be done with a sort of draw knife.
hope that helps
Matt,
"Perfection is not when there is nothing left to add, but when there is nothing left to take away."
PostPosted: Wed 01 Jul, 2009 8:30 pm    Post subject:         Reply with quote
Thanks for the reply Matt!!
I am glad that my line of thought was not wrong!!
I´m traing to make a Type Xa sword, so i´m going for the broad fuller.
I will try to make the sprung like tool, if you or anybody have some more tips or perhaps a guide on how to build such tool i will be verry grateful!! Big Grin
http://www.flickr.com/photos/sergioroma
Matt Lewis
PostPosted: Wed 01 Jul, 2009 8:50 pm    Post subject:         Reply with quote
This it , more or less not quite how I would do one , but you get the idea.
Matt
 Attachment: 24.68 KB
Sprung fuller hardy tool
PostPosted: Thu 02 Jul, 2009 4:55 am    Post subject:         Reply with quote
Thanks for all the help Matt!!
Cool
M. Oroszlany
PostPosted: Thu 02 Jul, 2009 5:34 am    Post subject:         Reply with quote
If you don't frown upon the use of power tools, a fuller could be easily created by an angle grinder. The width of the fuller can be controlled by changing the angle between the grinder plate and the blade. Grinder parralel with the blade will result in a very narrow channel, perpendicular in a broad one.
This image might help
You might also want to see the other pictures from that page, they follow the whole aprocess of making a basic sword with modern tools:
http://www.regenyei.sg18.net/hu/making_sword.htm
PostPosted: Thu 02 Jul, 2009 7:58 pm    Post subject:         Reply with quote
thanks M. Oroszlany
This method realy worths giving a try... i´m only concerned if it will give an even concave surface, but the method it´s realy simple!!
Thanks once again!! Big Grin
Charles Bsy
PostPosted: Thu 29 May, 2014 4:44 am    Post subject:         Reply with quote
Hi Sergio,
I came across this set of instructions for making a fuller that you might find helpful:
http://sword-site.com/thread/117/grind-fuller-on-sword-knife
Ryan Renfro
PostPosted: Thu 29 May, 2014 10:19 am    Post subject:         Reply with quote
Hi Sergio,
Dave Stephen's jig here looks quite useful: http://www.bladesmithsforum.com/index.php?showtopic=22814
