Bryan W.
Posted: Wed 22 Apr, 2009 5:58 pm Post subject: Custom Blade Makers |
This may be better suited to "off topic" but I'll let the fearless moderators decide if this needs to be moved.
I was thinking of comissioning a mid-high level custom smallsword project. The maker(s) I was originally trying to contact (no names to protect the innocent as I'm sure he/she/they're just busy) have not responded over the past month so I've decided to start shopping around again in the event they don't respond at all (and if they do, the information obtained likely won't go to waste for the future and may help someone else as well!)
While looks are always important, like many of the people on this board I'm primarily concerned with solid construction and good handling (ie: total weight, balance, etc) so ideally if someone has any experience with those involved in creating custom blades that would be most helpful to hear about. There are quite a few creators out there but my experience is limited.
Thanks in advance.
Taylor Ellis
Posted: Wed 22 Apr, 2009 6:43 pm Post subject: |
My advice would be to contact Kevin Cashen:
cashenblades.com
Gabriel P. Hagai
Posted: Thu 23 Apr, 2009 7:02 am Post subject: |
You should try Tinker Pearce:
www.tinkerswords.com
Pugna pro Causam, Victoria Justis.
Bill Grandy
Posted: Thu 23 Apr, 2009 7:13 am Post subject: |
For smallswords in particular I'd recommend Old Dominion Forge, as they specialize in 18th century items, though I'm not certain if they're taking orders right now or not.
I'd also highly recommend Arms and Armor. I have a custom smallsword from them that I think is leaps and bounds better than almost any other moder made smallsword I've ever seen in terms of both function and aesthetics/historical accuracy. They definately understand how a smallsword is supposed to handle and look.
One of my big complaints about modern made smallswords is that they're typically too bulky in the fittings. If its important to you that it captures the same look as antiques, make sure the maker you go with has really studied originals.
HistoricalHandcrafts.com
