Forum Index > Historical Arms Talk > Tassets Reply to topic
Michael Curl
PostPosted: Sat 21 Feb, 2009 9:37 am    Post subject: Tassets         Reply with quote
The seem redundant if worn with a cuisse, Yet I see the two worn together all the time. Whats the point?
E Pluribus Unum
Ben P.
PostPosted: Sat 21 Feb, 2009 10:44 am    Post subject:         Reply with quote
Well for one thing you have a huge gap between the cuirass and the Cuisse and even chausses an impact weapon can do a lot of damage to your leg
Bill Grandy
Reading list: 43 books
PostPosted: Sat 21 Feb, 2009 12:23 pm    Post subject:         Reply with quote
What Ben said. You need to be able to bend your legs where they meet the hip, and if you put the cuisse too high it will impede this movement. If you make the tasset too long, then it won't move properly, either. Put them together, and you have a very well covered leg.
HistoricalHandcrafts.com
Randall Moffett
PostPosted: Sat 21 Feb, 2009 11:27 pm    Post subject:         Reply with quote
You do see 2nd half of 15th german harnesses without tassets for this reason. On these the cuisses are multilamed up the entire leg and go well under the faulds. Unless this was done with the cuisses the tassets were still very important for the reasons Ben and Bill stated.
Michael Curl
PostPosted: Sun 22 Feb, 2009 12:27 pm    Post subject:         Reply with quote
Ok, cuz it looked like the fauld and cuisse covered it, but I didn't think about movement, thanks.
E Pluribus Unum
