Forum Index > Historical Arms Talk > Albion NextGen weights? Reply to topic
Einar Drønnesund
PostPosted: Sat 05 Jun, 2004 1:12 pm    Post subject: Albion NextGen weights?         Reply with quote
Some of the weights on the Albion NextGen swords have to be wrong. Like the Regent which is listed as: "3 lbs 8 oz (1.25 kilos)". Which is it? 3 lbs 8oz is closer to 1,6kg as far as I can calculate.
Howard Waddell
PostPosted: Mon 07 Jun, 2004 10:58 am    Post subject: Re: Albion NextGen weights?         Reply with quote
My fault -- it is 1.59 kilos... I am going to go through and correct them. Please feel free to list the ones you see in error just in case I miss any.
Thanks for the head's up!
Best,
Howy
Albion Swords Ltd
http://albion-swords.com
http://filmswords.com
Markus Haider
PostPosted: Mon 07 Jun, 2004 11:23 am    Post subject:         Reply with quote
Yes, >1,5kg is the correct number (I weighted mine with 1520 g).
Howard Waddell
PostPosted: Mon 07 Jun, 2004 12:44 pm    Post subject:         Reply with quote
I am afraid. like most Americans, the metric system is still somewhat of a foreign language for me -- but I am learning, slowly. Feel free to point out my errors -- I'll never learn otherwise!
Best,
Howy
Albion Swords Ltd
Roger Hooper
PostPosted: Mon 07 Jun, 2004 4:57 pm    Post subject:         Reply with quote
I use this online inch/metric converter all the time -- http://www.convert-me.com/en/
Nathan Bell
PostPosted: Tue 08 Jun, 2004 4:00 am    Post subject: Re: Albion NextGen weights?         Reply with quote
Having handled the Regent, I have to say that regardless of actual weight, it feels as if it weighs far less than either 1.6 kg. or 1.25 kg.
Erik F
PostPosted: Fri 11 Jun, 2004 12:18 pm    Post subject:         Reply with quote
Hello im thinking of buying a Albion sword but i wonder if the next generation swords are peened or are they threaded and peened as the first generation swords?
Roger Hooper
PostPosted: Fri 11 Jun, 2004 12:54 pm    Post subject:         Reply with quote
The Next Gen swords are hot peened. This article will give you the details - http://www.albionarmorers.com/functional.htm
I don't think the First Gen swords were constructed this way in the past, but they are hot peening them now.
Erik F
PostPosted: Fri 11 Jun, 2004 1:10 pm    Post subject:         Reply with quote
Ok, but looking at this picture of a sword here I cannot see that it has been peened: http://www.albionarmorers.com/images/swords/a...embly2.jpg
Bill Grandy
Reading list: 43 books
PostPosted: Fri 11 Jun, 2004 1:19 pm    Post subject:         Reply with quote
From Albion's website:
...the end of the tang that shows at the top of the pommel is heated and then gently hammered and expanded (often into a recess in the top of the pommel) to form the "peen block," which is then either blended and polished into invisibility or filed and shaped depending on the demands of the period.
So it is peened, you just can't see it because it's been polished.
Howard Waddell
PostPosted: Fri 11 Jun, 2004 1:34 pm    Post subject:         Reply with quote
Yes it is peened and blended into as invisible an effect as we can (considering you are blending too different alloys of steel). If you look at this photo as well, you can see that it would be impossible to screw the pommel on to the tang -- the wide shoulders of the tang go way up into the pommel in a matching rectangular space.
 Attachment: 26.37 KB
Albion Swords Ltd
