my new sidesword and dagger
hello to everyone,
i wanna share with you the pic of my new sidesword and matching dagger custom made by
darkwood armoury, what do you think about ?
 Attachment: 125.62 KB
Very nice! Congrats on your new acquisition!
Beautiful! Congratulations on two nice new blades. What level of finish did you get on the hilts?
Jonathan
Beautiful pair of blades and lots of luck with them. I especially like the bluing on the hilts. What length are the blades on both the dagger and the side sword?
Jim Holczer – Student
Umbs School of Fence / Martinez Academy of Arms
thank you for the comments, the blade is a standard darkwood bated rapier blade with fuller, regarding
the dagger blade i have asked for a heavier and stiffer blade respect to the standard darkwwod
daggers otherwise the measurements are the same. the beautiful bluing of the hilt is due to the initiative and
skill of scott wilson as i asked him nothing more than a standard finish !!!
Nice! :)
Though, is it correct to call this sword a sidesword if it has a rapier blade? I was under the impression that the sidesword was so to speak a cut-and-thrust "older brother" of the rapier, with a heavier blade.
Anders Backlund wrote:
Nice! :)
You're right. Sideswords are generally broad-bladed rapier-like swords with more robust hilts, most of which are early attempts at the swept hilt.
Of course, there are exceptions as some rapiers (particularly pappenheimers) have broader blades that could cut and still retain the title "rapier".
Really, theres real distinction when it comes to a rapier blade as many times they were swapped around on different hilts or cut down from previous broad blades, etc, etc, etc. So really most dont REALLY know what they're talking about.
Nice! :)
Not exactly. The term "sidesword" is not a period term at all, though most modern people use it to describe any sort of complex hilted sword with a slightly broader blade for cutting and thrusting, many of which have blade which are not too different from medieval arming swords. However, the word "rapier" meant quite a lot of different people at different times. It covered what many today call "sideswords", it covered longer thrust oriented blades that could still cut reasonably well (which is what most modern people use reserve the word "rapier" for), and it eventually also was used to describe smallswords.
These days I'm using the term spada da filo, or "edge sword", to describe what I used to call a sidesword, as it is a much more period correct term... though truth be told, even that is a very vague, general term that can mean a lot of things.
Actually, rapiers that *couldn't* cut tend to be the exceptions, not the other way around. Historical rapiers of the 16th and early 17th century were definately edged, and the vast majority of rapier texts describe cuts and use them frequently, even if they had a preference for the thrust.
The problems with classification is that it breaks down at the boundaries. We can all agree that the weapon shown in the sword and buckler section of Talhoffer (1467), with a broad blade and a total length of 55% of the height of the wielders is a sword and that the weapon shown in Capo Ferro (1610) with a much narrower blade and 78% of the height of the wielder is a rapier. Clearly there was a change in weapon form between these two authors. But where do we classify Agrippa's weapon with a narrower blade than Talhoffer, but broader than Capo Ferro and a length 65% of the height of the wielder? Agrippa called it a sword, but in England the same weapon may have been called a rapier.
Ultimately it's a bit pointless to argue at the boundaries. It's like arguing whether the end of the middle ages was at the Battle of Bosworth in 1485 or when Charles VIII invaded Italy in 1494. Clearly 1400 is medieval and 1600 is early modern and somewhere between those dates a bunch of stuff changed. Nobody woke up one morning, turned to his wife and declared, "strewth love, we've slept through the alarm and missed the start of the Early Modern Period".
Single handed swords made for civilian use changed gradually over a period of about 100 years and became something quite different to what people had previously used. You can call the transitional weapons 16th century swords, early rapiers or spada da filo. There is no absolute right or wrong answer and getting hung up over it is not terribly productive. There are some things you shouldn't call them. Sidesword appears to be a curatorial term from the early 20th century and should probably be avoided, though I find it a useful term as everyone understands what you mean. Cut and Thrust Sword is a term used in the 18th century to describe spadroons. As the term was not used in the 16th century but WAS used later to describe a different type of sword it should definitely be avoided as potentially leading to enormous confusion.
Oh, and what Bill said about rapier cuts is correct. The masters taught cuts and anyone who thinks that you can slam three pounds of steel into someone's head without diminishing their fighting ability has clearly never been hit with a rapier in a bout.
Stephen
what are you saying is basically true, i have termed my sword "sidesword" because i have ordered
this weapon mainly for studying the metod of Agrippa , and so for rapresent a mid 16th century sword that it's not completely evolved into what you call rapier (a term that doesen't exist in italian terminology "striscia " is more correct).
I think the set looks very nice...especially for a standard finish.
Very beautiful... Quite simplistic, not at all overly decorated like so many similar types from the period they're emulating.
I like them. I hope they help your skills improve. After all, that's what we really want our swords to do, right?
