Forum Index > Historical Arms Talk > 15th c. Bevor Question Reply to topic
PostPosted: Tue 25 Mar, 2008 1:46 pm    Post subject: 15th c. Bevor Question         Reply with quote
Should the straps go inside or outside of the main plate of a northern Italian bevor of ca. 1450-1480? The rivet holes of originals make clear where the straps attached, but don't indicate whether they were mounted inside or outside. I've seen both methods on good-quality reproductions, but original examples are extremely rare (In fact, I haven't seen a bevor of this period with working-life straps). Are both methods correct? I'm inclined to mount the straps inside the main plate.
Gordon Frye
Reading list: 15 books
PostPosted: Tue 25 Mar, 2008 10:21 pm    Post subject:         Reply with quote
Sean;
This is a rather nice reproduction armet and wrapper by Stanislav Prosek in CZ belonging to a friend of mine. It has the straps on the inside, and it looks proper to me. I suspect that you're right, though I have no proof either.
Cheers!
Gordon
 Attachment: 61.95 KB
Gonsalo Jimenez de Quesada
Russ Thomas
Reading list: 43 books
PostPosted: Wed 26 Mar, 2008 3:54 am    Post subject: Bevor straps         Reply with quote
Hi Folks ,
I always fit my straps on the inside of the bevor for the same reason that Gordon mentioned; it gives less for a lance to purchase on. But as to the originals, well Churburg is probably the place to look for an original still in situ.
An interesting thing though concerning straps on sallets, there is always a bit of a problem with getting the sallet and bevor to stay in place relative to each other. There are many medieval images that show the nose protruding between the lower edge of the sallet and the upper edge of the bevor. And in my own experience, often the straps of the sallet are a bit in the way of the top of the bevor. Have any of you noticed the picture on the back of David Edge & John Miles Paddocks book 'Arms and Armour of the Medieval Knight' ? The straps of the bevor go over and around the front of the bevor. This is the only image, of the top of my head, that seems to show how they solved the problem in the 15th century.
Russ
Carpe diem, quam minimum credula postero !
http://www.living-history.no
PostPosted: Wed 26 Mar, 2008 6:21 am    Post subject:         Reply with quote
Thanks, folks! I think that satisfies me. Inside it is.
I, too, noticed the tapestry on the back of Edge's book. That's the only instance of that method I've seen.
As for the fit between bevor and sallet--my set consists of the bevor and what was a visored export sallet by Patrick Thaden. I removed the SCA-type visor to create a nice open-face Italian sallet, so the protrusion of the bevor isn't an issue. I assume it fit well even with the visor, though. The bevor fits easily into the bowl of the deep sallet but it's a close fit that doesn't allow much swiveling of the head. I suspect that's appropriate, if strange to a modern wearer. I can certainly appreciate the vertical top lame of many bevors made en-suite with visored sallets. I can also appreciate why even some wealthy men preferred the open-face sallet and bevor combination. It protects very well and allows almost full protection of the face when "ducking".
I strapped my sallet with close attention to where the upper edge of the bevor would rest, but even so the bevor contacts the straps because the straps come toward the chin at an angle. This doesn't interfere with fit or motion at all. In fact, the contact against the straps probably helps maintain tension and stabilize both helmet and bevor. I'll be adding two holes near the apex of the lower lame, not because I intend to wear the piece regularly but for the sake of authenticity. If I get around to making a jack I'll secure the bevor to the jack with points and see how that affects fit and mobility. Seems like, ideally, the neck strap just keeps the bevor from falling forward, while the points or spring pins or buckles, etc. actually do the work of supporting the weight of the bevor and keeping it at the proper height. I'm aware that many bevors had no such suspension system, though.
Matt Bayley
PostPosted: Wed 26 Mar, 2008 10:16 am    Post subject:         Reply with quote
Gordon Frye wrote:
Sean;
Cheers!
Gordon
That particular helmet is by Thorkil http://thorkil.ovh.org/
Nathan: there's another example of the salet stapped over the bevor, i've just got to scour my archive to fin it. Sad
Matt
